Scotty's 93 GTO - it's time ! *crickets chirping*
ANG #3 Media & Aftermath *tumbleweed passing by*
Favourite quote: (GTOX) - Apart from the knocking noise it was running 110% and pulling like a champ.
If you want positive stories check out and subscribe to my restoration at Rebuild
I've not tested the speed limit thing since I have the new ECU, pretty sure the cruise still only goes to 110, Pete was saying something about the ecu supplying the current speed to the cruise module?
Re: Re: Cruise control speed limits and 180km/h limit
Can you test your cruise control and see if it's still limited? That would effectively rule out the ecu.
Can confirm the AUDM is 110 limited. And its bloody annoying.
Something else that just came to mind, if you cut pin 66 (ecu speed input) will the AWS still work? Does it have an external speed input or get it from the ECU?
I will have to test the cruise on my oz delivered car, hardly ever use it. Does the ECS take speed so it can change to sport mode over a certain speed? anyone know what speed ?
Anti-Rolling Control
CONTROL START
Change to a higher damping force according to the control map for the vehicle speed and steering wheel angular velocity which depends on the operation of the steering wheel.
CONTROL HOLD
After switching to a high damping force and holding that condition for 1 second, return to normal damping force (SOFT).
High Speed Response Control
CONTROL START
When vehicle speed exceeds 130km/h (81 mph) in the TOUR mode, the damping force changes from SOFT to MEDIUM to improve high speed stability.
CONTROL HOLD
Damping force which is changed to MEDIUM is held while the vehicle speed is over 120km/h (75 mph) but when it falls to 120km/h (75 mph), the damping force returns to SOFT.
Anti-Diving Control
CONTROL START
When the stop light switch goes ON, the ECS control unit calculates deceleration from the change in vehicle speed. As a result, after the stop light goes ON, if deceleration calculated within 0.4 sec. exceeds 0.15G, the shock absorber damping force is changed to MEDIUM. If the stop light switch is ON and the computed degree of deceleration exceeds 0.4G, there will be a change to HARD.
CONTROL HOLD
The damping force after changeover is held while calculated deceleration is over 0.15G and when it falls below 0.15G, the damping force returns to normal (SOFT).
Anti-Squatting Control
CONTROL START
When the accelerator pedal is pressed (returned), it changes to a higher damping force through map control of the vehicle speed and speed change in throttle opening (closing). There are 2 control maps - when the accelerator pedal is pressed and when it is returned (throttle opened and closed). Furthermore, when the throttle position sensor output voltage stays over 4.0V for more than 1 second at vehicle speed of 3 - 100km/h (2 - 62 mph), it
is judged that there is full throttle acceleration and the damping force is switched to MEDIUM.
CONTROL HOLD
After changing from a high damping force, there is first a 1 second hold in that condition and then the suspension reverts to the normal
damping force (SOFT). When full throttle acceleration is judged, the suspension reverts to the normal damping force (SOFT) in one second after the control conditions are not satisfied.
Pitching/Bouncing Control
CONTROL START
When the ECS control unit judges that there is serious pitching and bouncing of the vehicle (washboard road driving) via the output of the G-sensor, the damping force is changed to HARD for a flat and comfortable ride with no vehicle pitching and bouncing.
CONTROL HOLD
When the ECS control unit judges that there is no more pitching and bouncing of the vehicle via the output of the G-sensor, normal damping force (SOFT) takes over at the same time.
Bad Road Response Control
When the ECS control unit judges that there is fine pitching and bouncing of the vehicle (bad road such as gravel road, etc.) via the output of the G-sensor, the suspension is changed to MEDIUM for improved riding comfort and bad road driving even if the damping force should be set to HARD by some other control.
Pete - The HKS FCD raises the fuel cut limit. When the car hits the 180km/h speed limit is uses the fuel cut method so it makes sense that it also increases the limit. To what point I don't know. Not sure how it effected the cruise control. Was your cruise control limited before installing the FCD? If it was then we can safely assume it's the ECU controlling the speed limit.
There is a member on here using the HKS SLD and has confirmed it works [removes 180km/h speed limit].
I can also confirm that when I had the speed converter chip installed I was able to reach speeds over 180km/h also. I just want to test my theory about connecting it to pin 66. I need a guinea pig. I have a spare chip here. If it works you can keep the chip.
