Coil pack...not firing/92 GTO - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Go Back   3000GT/Stealth International Message Center > Regional Discussions > International(NON USA) > Australia
Old 08-11-2007, 07:15 AM   #1 (permalink)
nemesis101 is an unknown quantity at this point
Feedback Score: 0 reviews
Default Coil pack...not firing/92 GTO
Hi guys
I have recently experienced problems with my 92 mitsubishi GTO, after having it for about 4 weeks....
One day just driving home it was suddenly misfiring and running on 4-5 cylinders...
Changed the leads and spark plugs for the front part of the engine, as the back to hard to get to....and i found that did not solve the problem.....
In this process though i have found out that the front left cylinder while removing the spark plug was not working by looking at the state of the spark plug
So i removed the spark plug leads while the car was runnin on this particular coilpack(middle coilpack) and BINGO one output does not work
I then went to AFI and bought that exact same coilpack(C9223)...
On the process of installing it i have come accross numerous problems
I lost the nut to connect the coil pack to the cables.....I used duct tape to hold it into place....another foolish mistake was i left the spark plug leads disconnected from the coilpack
also forgot to put the air filter piping back ..
Then started the car and turned over once for 10seconds out of 10 times ive attempted...
I then resolved the problems by getting a new nut, connecting the spark plug leads, and connecting the air intake piping back on....Now the new coil pack does not distribute any spark on both outputs
Any advise??
I think its time i will bring this to a workshop, please advise me if you have a workshop anywhere in sydney who knows what they are doing with their GTO's
This is more then likely an electrical problem
any solution??
cheers
and now the car turns over, but the new coil pack does
nemesis101 is offline   Reply With Quote Quick reply to this message
Old 08-11-2007, 07:46 AM   #2 (permalink)
Doin stuff
GTO Assassin's Avatar
Drives: 1993 Mitsubishi GTO
GTO Assassin Level 1GTO Assassin Level 1GTO Assassin Level 1
Feedback Score: 46 reviews
Default Re: Coil pack...not firing/92 GTO
Try Pro Concept at West Ryde. Phone number is 9807 4488. Joshua is the head mechanic there and can help you.
If you're going to change the plugs and and leads, you should really do the rears aswell. Yes it takes more time, but very worthwhile.
Scotty
Scooter
GTO Assassin is offline   Reply With Quote Quick reply to this message
Old 05-14-2008, 06:57 AM   #3 (permalink)
kuroiknight's Avatar
Drives: 1992 Sandstone VR4
kuroiknight is an unknown quantity at this point
Feedback Score: 6 reviews
I know this was a while ago, but what turned out to be wrong with your car? I am having the same issue.
kuroiknight is offline   Reply With Quote Quick reply to this message
Old 05-14-2008, 09:58 AM   #4 (permalink)
Drives: 1990 GTO
aussie_will is an unknown quantity at this point
Feedback Score: 5 reviews
Wow, yeah it was a while ago.
I had a similar problem and it was solved by replacing the ignition module. Looks like this little gem and is hidden under the coils.
Ignition Module PTU DOHC*-*Mitsubishi 3000GT*/*Dodge Stealth
The coil packs themselves were fine.
I've also read that a bunch of other users were experiencing similar problems and it turned out to be either a faulty ECU, crank sensor, ECS computer or TPS sensor in their case.
aussie_will is offline   Reply With Quote Quick reply to this message
Old 05-14-2008, 07:52 PM   #5 (permalink)
Paid Member
Drives: 98 3rd Gen GTO
TrueblueGTO is an unknown quantity at this point
I had the same problem I posted it somewhere on the forum. It was the Power Transistor Unit. The most sensible thing to do is take out the coil and the PTU and bench test them as described in the repair manual ie with a volt meter and the resistance or not across the terminals will tell you which one is faulty.
If its your coil pack they are only avail from Mitsu as a single unit or you can go after market. Same with the PTU but I don't know if aftermarket ones are available but I did see something on the Haltech web site that looked like it might work.
If you haven't got acess to a repair manual I'll scan the pages and send them to you.
Of course it could be the ecu, apparently early ecus had leaking capacitors but I'd look at the ignition system first and rule it out before I started on the ecu.
By the way I did all the things you have done before doing the bench tests, changed plugs leads and coil pack put it all back together just to find it still didn't work. Then I got smart.
TrueblueGTO is offline   Reply With Quote Quick reply to this message
Old 11-27-2008, 03:56 PM   #6 (permalink)
91RT's Avatar
Drives: 91RT
91RT is an unknown quantity at this point
Feedback Score: 4 reviews
Think i have a similar problem. I get juice from the PTU when the car is in the "on" position but no sparks are firing as i try to start it. Just keeps cranking. Already took out the ecu. Found it was a little dirty but cleaned it and since i'm getting juice at the PTU that means it's ok right? Would u mind scanning me those manual pages TrueBlue. thanks for any help
91RT is offline   Reply With Quote Quick reply to this message
Old 11-27-2008, 05:25 PM   #7 (permalink)
4L 6G74 Stroker FWD NA
TUFFTR's Avatar
Drives: Mitusbishi Magna
TUFFTR is an unknown quantity at this point
Feedback Score: 13 reviews
After seeing how cheap they go for on here, I'll be buying a few spares. Seems as though this part is often one to fail and replacements are expensive....Just a thought.
1993 Mitsubishi Magna
- Bored and stroked 11:1 6G74 DOHC (Now 4L)
- Ported heads
- Custom camshafts
- Titanium valvetrain
- Chrome ECU
- One off intake Manifold
- 560cc Evo Injectors/Evo MAF
- Extrators/3" exhaust
- 3000GT 1st/2nd gen brake setup
- Enkei Kojin 18x8.5's
- Rebuild FWD Box with WaveTrac LSD
- E85 Flex fuel Ready
- Evo 3 RECARO's/Ralliart Magna MOMO Steering wheel.
Now to sort out the respray.
TUFFTR is offline   Reply With Quote Quick reply to this message
Old 11-27-2008, 09:47 PM   #8 (permalink)
Paid Member
Send me a PM with your email and I'll email them I seem to be having a problem getting them into a message on the forum.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Date of Birth
Month Day Year
Privacy
Log-in
Random Question
