#52 (permalink) |
''the professor''
nice! seems like supermac is the only non-chickenshit shop we've got on 3si.
cheers to fabrication skills ![]()
Maddog Performance Engineering
the gas pedal does nothing ![]() ![]() Last edited by i3igpete : 08-11-2007 at 08:39 AM. |
#53 (permalink) |
TEXAS!! FIGHT!!
Can't help but notice that you used round tubing... Clearly, the inlets of the lower intake manifold are not round. How are you smoothing this transition?
PEARL WHITE '93 VR-4 // Under Construction. Looking forward to lighting up the drag radials
E16G's: 10.573 @ 135.01 (Trevor owns me )E16G's: 11.28 @ 124.7 (Pure pump gas ET record )14B's: 11.10 @ 127.3 (AWD 14B ET record. Take THAT, Trev! 9B's: 12.78 @ 107.1 Congrats to the current top 10 members!! DynamicRacing: US 3S Top 10 Fastest List |
#55 (permalink) | ||
Supermactastic
sorry i havent tested the tec strut bar. i dont have any experience with it at all really. although by looking at pics i doubt it would clear any better than our strut bar. there is very limited space under the hood and our bars are cutting it pretty close as it is
#56 (permalink) |
Uber-Nerd
So if you dremel the lower plenum, does that mean we are going to have to dremel out lower plenum to fit right? Or do we need to send our lower plenum in to you guys to have it done right?
![]() 1996 Black/Green Pearl VR4... Recently upgraded... Poster child for the Intake Pressure Test |
#58 (permalink) |
SOHC you in the FACE
I used round pipe and just reshaped the lower plenum. With a good carbide bit (get this at a tool supply store) and lubrication (keep the bit lubed and stuff wont get stuck in it and it will eat the aluminum like crazy) you can do it in 5 minutes if you do a good job marking off where you need to cut.
I do think its cool to use all new upper plenum pipe. Then you can determine the diameter of the upper runners and maybe taper down @ the lower for velocity blah blah blah ![]() I still think everyone goes too small on the surge tank and a bit to long on the runners. I guess the corner of the valve cover gets in the way so some configuratios fit better then others.
Brent
1992 Duster -12.7@114 - 14psi boost -13.9@107.4 - 5psi - 6g72 3.13L "built" SOHC, Precision T67 P-trim, Tial 38mm open dump, 3" downpipe, 20x12x3" evo style intercooler, 7:1 compression, balanced, shot peened rods, heavily ported heads (+40% on flowbench), Ferrea Competition Plus +2 +1 stainless valves, Nielson Vintage 278 duration custom turbo cams, RPW Cam gears, Custom Ram Style short runner intake manifold, Walbro 255hp, 6*47# injectors, +0.096" Forged Venolias, Total Seal chrome gapless top rings, Fidandza Flywheel, Clutchnet 3 puck solid hub, OBX Helical LSD, Zeitronix wideband/EGT/Boost sensors, 100watt DevilsOwn Meth Kit. 1994 Spirit - 13.987@101.89 - 5psi- 6g72 SOHC, K27 Turbo ![]() |
#59 (permalink) |
Supermactastic
no you wont have to dremel your lower plnum unless you really want to. what i ment by us dremeling out the plenum is that we try to match up the ports on the plenum to the lower intake. once everything is installed you wont really have a need for dremeling anything though. the fit is pretty nice and you wont get any block air paths from the plenum.
#60 (permalink) | |
Regards,
Leonel |
| Thread Tools | |
