#31 (permalink) |
single terbow
http://store.summitracing.com/egnsea...115+4294844063
you could use one of these just install it in the upper radiator hose and get a diamante filler neck. trust me there are ways around that problem ![]()
camera phone pic ![]() |
#32 (permalink) |
Livin' the dream
no worries your rad. overflow should suck and deposit fluid as needed unless you choose to purge your whole system and fill up again. if its such a big hassle then they should just offset the TB to the front or back a few inches for clearance. no big whoop...
Looks dang nice though. how much will this run? $$$
![]() 1967 Dodge Charger (440)... 1969 Dodge Charger SE (383)... 1972 Dodge Charger (400)... 1992 Dodge Stealth R/T TT (Daily Driver) 1992 Dodge Stealth R/T TT |
#33 (permalink) |
''the professor''
maybe we can have a microsoft paint sketch of what your final design is going to look like?
Maddog Performance Engineering
we are not mitsubishi trained technicians nor certified getrag rebuilders ![]() |
#35 (permalink) |
''the professor''
the only problem i forsee with the zesty manifold is that he can't reuse the end of the stock plenum and that might make it pretty pricey. fabbing those up might be pretty involved since the bolt holes go through the surgetank. with a modified stock plenum, you can simply cut off the end section that has the mounting bolts and weld a tank onto that... which is probably why everyone's custom plenums are modified stock plenums.
#37 (permalink) |
single terbow
for single turbo would be the main/only reason. and there seems to be alot more interest in single turbo lately. also about the zesty design i dont think it would be too insanly hard it is just that the bolts would go through the actual surge tank as seen in the zesty pic. you might be able to literally cut off the old plenum flange off the stock plenum... i think the hardest part about that design would just be fitment because it will have the clear the hood and both valve covers which might be very difficult. here are a few pics of some cool plenums
![]() ![]() ![]() ![]() ![]() ![]() ![]() on the last 2 photos there is a price written on that piece of paper of 899 and yes i know they arent around anymore i just thought it was interesting enjoy |
#38 (permalink) |
By the power of Grayskull
i think it should be dynoed on a stock car or at least very close to stock
![]() ChrisEs1984 : theres alot of pushrod lovers Galganaban : i love to push my rod into your mom shawnisworking : lol shawnisworking : 0wn3d |
#40 (permalink) |
*** Member #5912
a close to stock car should not be looking at upgrading the plenum. it wouldnt make sense. these car make BIG power with the stocker. Even me, with the stock heads/cam, shouldnt be looking at a plenum.. i should be going with heads/cam first.
John Servidio - 94 VR4
