Go Back   3000GT/Stealth International Message Center > Supporting Vendors > Ultimate Performance
Old 06-28-2008, 03:46 PM   #181 (permalink)
AEM Veteran
FWombat's Avatar
Drives: '94 VR-4
FWombat Level 2FWombat Level 2FWombat Level 2
Default Re: Manifold To Access Rear Plugs
This was with the stock throttle body, correct?
Brian Geddes
'94 Danube Blue VR-4
Replacing everything that moves.
'94 Pearl Yellow VR-4
It's dead, but its drivetrain lives on!
FWombat is offline   Reply With Quote
Old 06-28-2008, 11:56 PM   #182 (permalink)
Supermactastic
supermac's Avatar
Drives: 94 RT/TT & 03 Evo 8
Trader Rating: (33)
supermac is an unknown quantity at this point
Correct. We used the stock throttle body.
We will be testing out Q45 90mm throttle body on the plenum later on when we get all the other parts ready to go onto the car.
supermac is offline   Reply With Quote
Old 06-29-2008, 03:27 PM   #183 (permalink)
Patryn's Avatar
Drives: 3000gt VR4
Trader Rating: (26)
Patryn Level 7Patryn Level 7Patryn Level 7Patryn Level 7Patryn Level 7Patryn Level 7Patryn Level 7Patryn Level 7Patryn Level 7Patryn Level 7Patryn Level 7
For racing it is a nice increase when you stay in the upper rpms. What about the HP and TQ hit you take between 1500 and 5200rpm? Are the lower and mid rpm HP and TQ always sacrificed with aftermarket plenums? How does the plenum with the larger tank and longer runners you make compare to this plenum?
1998 VR4: SS Downpipe, Borla Cat-Back, Open Element Air Filter, ACPT CFDS, DN Intake Pipes, Front & Rear Strut Tower Bars, Deftracing 575 Hood, Blitz DSBC, Vacum Redution, Krank Vents, Titan Headers w/ Big TD05 16G Turbos,
Patryn is offline   Reply With Quote
Old 06-29-2008, 03:33 PM   #184 (permalink)
AEM Veteran
FWombat's Avatar
Drives: '94 VR-4
Take a look again. The only place he lost torque was a few ft-lbs between 1000 and 1750. Other than that, he picked up torque everywhere. Especially good gains from 5250 to redline.
Old 06-29-2008, 05:32 PM   #185 (permalink)
Supermactastic
supermac's Avatar
Trader Rating: (33)
the loss of power down low around 1500rpm is soo small you will never even notice it. esspecially when the power in the mid range kicks in.
and like i said. this is all based on a stock car. with mods the amount of power you gain is higher.
Old 06-29-2008, 07:02 PM   #186 (permalink)
Patryn's Avatar
Drives: 3000gt VR4
Trader Rating: (26)
What would it take to push the Red line up closer to the stock blue line or above it at all points on the HP & TQ curve? I might be interpreting the dyno run wrong. Just look like the gap is pretty big from 2K to 4.5K, smaller differences everywhere else. Is they a plenum setup that will give you the best of both worlds or would that be just wishful thinking.
Old 06-29-2008, 10:12 PM   #187 (permalink)
Patryn's Avatar
Drives: 3000gt VR4
Trader Rating: (26)
Correction noted, I was reading it as plenum vs plenum not TQ and HP increase. Supermac how does this compare to the other plenum that you made (I beleive you had a different version in the past) TQ and HP curves?
Old 06-30-2008, 12:47 PM   #188 (permalink)
Supermactastic
supermac's Avatar
Trader Rating: (33)
the small thin lines are the stock setup, and the darker lines are the new plenum.
Old 06-30-2008, 11:52 PM   #189 (permalink)
Dont f#@k with me I own a
Overboosted's Avatar
Drives: 1991 Stealth TT AWD
Overboosted is an unknown quantity at this point
Wow for a completly stock car that's amazing results. I would love to see what this manifold will do on a highly modded car.
Good work
Overboosted is offline   Reply With Quote
Old 07-08-2008, 03:10 PM   #190 (permalink)
streamlnauto's Avatar
streamlnauto is an unknown quantity at this point
This kind of makes me laugh a little, not that there is anything wrong with the design and this is no way a dig against you guys making these, but that there are that many people out there that are so lazy that they don't want to take the manifold off to access the rear plugs, c'mon guys it takes 20 min tops to take the mani off, jeeeze!! Performance should come before easy access and lazyness lol.
Just something thta kind of urks me because I have read it at least a couple dozen times throughout the forum.
streamlnauto is offline   Reply With Quote
« PRI Orlando | - »
