#141 (permalink) |
3/S tech
![]() 2 wheels spinning 4 wheels winning 1992 red RT (Original owner) 1994 RT TT (750 WHP) 1994 platinum RT TT (twin 20g coming soon) 1992 green VR4 (16g beast) 1998 GST eclipce (built & modded to hell) 1993 red SL bomex body kit 2001 BENZ E320 4 MATIC 2001 JAGUAR S-TYPE |
#142 (permalink) |
Supermactastic
well guess ill go back to the drawing bored then and make the plenum look more like that box shaped thing. but it still probably wont fit under a stock hood. there is only about an inch or 2 of clearance under there.
#145 (permalink) | |
single terbow
oh ok well nevermind then
just an FYI for you and others i found some good reading that a member posted awhile ago. maybe try sticking to these principles would be good?Quote:
#146 (permalink) |
Supermactastic
Just a quick note. with the boxed shaped plenum that everyones been posting... keep in mind that you will have to replace your factory outter studs in order to bolt this down. we will be able to suppoly hardware to install a neew plenum, but you will still have to remove the studs from your factory plenum.
if you dont understand y... then you probably shouldnt be removing the plenum for a new one. thanks, chris |
#147 (permalink) |
*** Member #5912
Keep up the good work Chris. You have A LOT of suggestions and ideas being thrown at you.. and I know you are trying to please everyone, and thats not easy.. especially in with this platform. Im sure the final product will be great, with either design.
John Servidio - 94 VR4
#148 (permalink) | |
fast and low
Your hard work is not without appreciation. Dartvdr ![]()
The money pit:
'70 Challenger convt. (almost done) '65 Dart convt. (my pride and joy) '00 2500 cummins 500+ horses of twin turbos '94 VR-4 (work in progress ) |
#150 (permalink) |
Supermactastic
that box style might fit under the stock hood but it wont fit the the stock radiator fill neck. there is no way it would ever clear that.
also. we spent all day trying to figure out a way to make a plenum that woudl actually be benificial to the car and still clear the hood while having a drivers side Tb and im sad to say its just not going to happen. even on teh passenger side without removing the fill neck it just cant be done like what people want. it would have to be less than 6 inches wide and less than 2 inchess tall to even fit under the hood, and then you have the tb to deal with the fuel rails, the fill neck, the hood liner, just lots of things that dont make it possible. we will continue to do our short runner manifold to access the rear plugs, but the super short plenum on top of the lowe intake just isnt going to happen unless people want to modify the hood. we will make them for people on a special order basis only. and we can even do them out of aluminum. so... from now on. we will be focusing on doing the regular plug access plenum only. thanks, chris |
