Go Back   3000GT/Stealth International Message Center > Supporting Vendors > Ultimate Performance
Old 09-24-2007, 09:45 PM   #121 (permalink)
leonel's Avatar
Drives: Fast
Trader Rating: (15)
leonel is an unknown quantity at this point
Default Re: Manifold To Access Rear Plugs
Originally Posted by supermac View Post
it will bolt up just like a stock plenum. we have made a flange for it to sit on and the tubes will hold the surge tank up away from the bolts allowing clearance for all the bolts and 2 side nuts. it will install very very easily. the only issue is the hood clearance. and the IC pipes routing to the TB. this will need a cutom intercooler and setup. we are designing the TB plate to use a stock TB however, it will still require some modification to make everything work (piping wise).
thanks,
chris
p.s. im an idiot and forgot to get some snaps of the plenum in progress. so ill have to get some tomorrow. ill make a note and hopefully i wont miss place it
I know that this is not a unit that Im interested in but I got an idea to make it close the hood...
Why not make the surge tank sort of like an oval flattish shap and flange off the TB out a little bit more past the cam covers, this way all will fit..
Just an idea, hope it helps
Regards,
Leonel
leonel is offline   Reply With Quote
Old 09-24-2007, 11:33 PM   #122 (permalink)
Dive Deep
Honda Hunter's Avatar
Drives: TT Stealth
Honda Hunter is an unknown quantity at this point
Must fit under stock hood.
Honda Hunter is offline   Reply With Quote
Old 09-25-2007, 01:56 AM   #123 (permalink)
Supermactastic
supermac's Avatar
Drives: 94 RT/TT & 03 Evo 8
Trader Rating: (33)
supermac is an unknown quantity at this point
cause in order for it to cover the fuel rails and still sit low enough to fit under a stock hood. it would be about an inch tall and need to be nearly 8 inches wide to get the volume. then the flow would be all messed up and would require a crazy adapter for the TB.
simple fact of the matter is... you want a drivers side TB plenum that sits on top of the lower runners... you must modify the hood.
even teh zesty plenum everyone is talking about needs a modified hood. look at the pics... it shows a cowl scoop and all the under bracing for the hood is removed.
if people dont want this. then im not gunna wast money welding it up. ill stick with a traditional plenum that allows access to the plugs.
supermac is offline   Reply With Quote
Old 09-25-2007, 02:08 AM   #124 (permalink)
Dive Deep
Drives: TT Stealth
I dont understand the need for a drivers side plenum but that's just me. I just want a intake that wont lose power, access to rear plugs, and fits under stock hood. But that's just me. Keep up the good work. I know LT1 owners would kill to have someone fab them some intakes for a good price seeing as they have no options at all.
Old 09-25-2007, 02:43 AM   #125 (permalink)
Supermactastic
supermac's Avatar
Trader Rating: (33)
this is a 3d drawing of what we are working on for an on top super short runner style plenum. the fual rails will sit right next to the runners, and under the TB is where the fuel rail loop will sit.
Old 09-25-2007, 02:52 AM   #126 (permalink)
Dive Deep
Drives: TT Stealth
Im sure this has been answered but why do some want the drivers side setup?
Old 09-25-2007, 03:06 AM   #127 (permalink)
Dive Deep
Drives: TT Stealth
Nevermind. Found the answer on the first page. Would it be possible to have a throttle body on both sides and have a turbo feed into each or would the air hitting each other from each side cause a issue? Would also take some crazy fab work for the throttle cable to control both throttle bodies. would be neat to see a no wire setup like the new corvettes and new ls2 setups.
Old 09-25-2007, 05:41 AM   #128 (permalink)
I am the king.
OBXboost's Avatar
Drives: A pair of Nikes.
Trader Rating: (30)
OBXboost Level 7OBXboost Level 7OBXboost Level 7OBXboost Level 7OBXboost Level 7OBXboost Level 7OBXboost Level 7OBXboost Level 7OBXboost Level 7OBXboost Level 7OBXboost Level 7
how would that bolt down?
'06 Hayabusa LE (9" over) 164.3 RWHP 99.7 ftlbs *RIP* 8/30/07
should anyone want to get ahold of me:
cell: 252.982.6404
OBXboost is offline   Reply With Quote
Old 09-25-2007, 09:41 AM   #129 (permalink)
Supermactastic
supermac's Avatar
Trader Rating: (33)
it bolts down just like a stock plenum. there just arent any bolt holes in the 3D drawing.
Old 09-25-2007, 10:55 AM   #130 (permalink)
single terbow
Trader Rating: (10)
pearlwhitwin Level 1pearlwhitwin Level 1
lets get some pics of the actual product
camera phone pic
pearlwhitwin is offline   Reply With Quote
