#43 (permalink) |
never a dull moment
I wish you would of posted this in general, first I have seen it and want it. Prob is I didnt budge for it and now I cant have it for a while. Deff on the must have list.
Coop
![]() To many mods to list. |
#46 (permalink) | |
I would start low and work you way up but me I wouldn't go with a 100 or 125 shot unless you had some sort of progressive controller to bring it on gradually instead of a violent rod snapping onslaught of 100+ being brought in in the blink of an eye.
His - Red 93 RT/tt
Mods: Hallman's MBC @ 16 psi, turbo XS type H BOV, stillen dp, custom exhaust, Spec stage 2 clutch, RPS FW, 3sx lightweight crank pulley, BCP7RES-11 @ .030 gap, autometer gauges, slightly gutted mas, dsm SMIC's, ACPT 1 piece CFDS, Tein S springs, pte 580 inj's, safc neo/SITC, 13t's, hotwired walbro, maximal performance solid motor mounts, DR plenum spacer. Hers - BPU Green 94 vr4 |
#50 (permalink) |
I've been flirting with the idea of using Additional fuel injection, a feature available on blue emanage and ultimate emanage. This essentially allows you to keep stock injectors for perfect drivability, and when your stock injectors are maxed out, the additional injectors come online and provide the extra fuel required. Generally 1 or 2 large fuel injectors are plumbed into the intake manifold, but it's very difficult to find space to accommodate. This is where your induction plates could make the process easier.
Currently my car uses 550cc injectors x 6 = 3300cc. Replacing the 550cc with stock 360cc injectors would require 1140cc to make up the difference. Could your induction plate handle that kind of extra fuel requirement? If not, could you make something similar to accomplish my goal? Perhaps an induction plate that allowed someone to install an injector or two. Tuning would be super easy to do compared to all previous methods we're accustomed to on the 3S platform. Part throttle would be perfect no need to touch that, and only high boost WOT needs to be dialed in. Low boost WOT can be left alone and high boost WOT is the only parameter that needs tuning. |
