Go Back   3000GT/Stealth International Message Center > Supporting Vendors > Ultimate Performance
Old 09-15-2007, 03:15 AM   #21 (permalink)
Supermactastic
supermac's Avatar
Drives: 94 RT/TT & 03 Evo 8
Trader Rating: (33)
supermac is an unknown quantity at this point
Default Re: Direct Port nitrous induction plates
just got the parts back from being water jetted the other day and man these things are looking nice i should have some completed pics up shortly. They are ready to sell if anyone wants one.
Thanks a lot,
Chris
Supermacnum1@aol.com
supermac is offline   Reply With Quote
Old 09-15-2007, 06:06 AM   #22 (permalink)
Damn It!
3startuna's Avatar
Drives: Without Traction
Trader Rating: (14)
3startuna Level 33startuna Level 33startuna Level 33startuna Level 3
holy shit thats bad ass
96 3000GT FWD TT -Rebuilt 2 bolt 8:1 block, balanced stock internals, valve job, 99 Lifters, Maximal Performance Motor mounts and valve cover!! Quaife LSD, ACT Max Extreme 6 puck, RPS flywheel, Greddy emanage with all harnesses, custom fuel system i designed my self, profec B spec2, walbro 255lph, stock turbos, Nitrous, KNN FPIK, FMIC, FM oil cooler, cusco Oil catch can, stillen DP, IPS 3" single, Full AC delete, stripped interior, Corbeau Forza 2 seat, 2 inch harness, ALL Greddy electronic gauges, brakes: 4 piston calipers from Yogurts TT, Hawk pads, Valvoline DOT 4, Russells steel lines
Coming soon: Tranny number 3
Special thanks: IPS, Maximal Performance, 3SX, Evans Performance and all 3si and FL3s members that sold me parts
3startuna is offline   Reply With Quote
Old 09-21-2007, 06:45 AM   #23 (permalink)
CI Member
The Twins's Avatar
Drives: 96 VR4
Trader Rating: (9)
The Twins is an unknown quantity at this point
next check i will be getting one
www.controlled-insanity.net
The Twins is offline   Reply With Quote
Old 10-06-2007, 09:43 PM   #24 (permalink)
Supermactastic
supermac's Avatar
Trader Rating: (33)
Ok guys. i finally took some video of the nitrous plates in action.
these vids were done using a small 50hp jet nozzle hooked up to a horn switch from int eh car. no big fancy nos kits or anything like that to create the flow. just a simple bolt on fogger system.
this is a perfect example of why a direct port plate is better than a fogger in the intake pipe.
RIGHT CLICK SAVE AS.
http://ultimateperformanceacc.com/vi...%20%282%29.AVI
http://ultimateperformanceacc.com/vi...rs%20video.AVI
Old 10-07-2007, 01:16 AM   #25 (permalink)
ZoomZoom?
HumanVr4's Avatar
Drives: 97 VR4
HumanVr4 is an unknown quantity at this point
The videos don't work for me, I get sound but no picture. but sometimes its because im useing a Imac pc. I will try my laptop tomorrow.
97 Black 3000GT VR4
New stuff not installed, DR Stage 3 heads, IPS stage 3 shortblock with Pauter forged rods, CP pistons and more.
Fast Stuff: IPS Stage 3 block with Pauter forged rods, DR Stage 3 heads with High Rev Valve Spring Kit and Titanium Retainers AND Rays head lift fix , IPS EVO 3 kit with turbo porting and Ceramic coating, IPS 272 Cams, IPS Fuel rails, fuel rail loop, Aeromotive A1000 FPR, PET 780CC Injectors, South Bend Stage 4 FE clutch, IPS NO-MAF intake pipes, 2 AEM Dry flow filters, AEM EMS, AEM map sensor, AEM IAT sensor, IPS intercooler kit w 750hp Spearco core, RPS flyweel, 2 HKS BOV, MSD 8.5MM wires, MSD Coils, Stillen downpipe, 3 inch custom exhaust W Apexi N1 tip, 3sx aluminum crank pulley, Walbro fuel pump, hotwire fuel pump kit, solid motor mounts, EGR block off Kit, red top Optimia battery, Flexalite twin 12" fans, Koyo aluminum radiator, polished front/back valve covers, polished plenum, polished throttle body, IPS polished coolant pipes, manifold / downpipe turbo hot side polished ceramic coating, Turbo intake side polished.
Interior&Audio System: Corbeau CR1 Seats In Black, Corbeau Black 3Point Harnesses, Apexi AVC-R Boost Controller, Apexi Turbo Timer, Defi-Link Meter BF Gauges In White, Boost/Psi, Water Temperature, Oil Presure, AEM Wideband, SmokingVR4 Duel 10Inch Sub Box, 2 PPI 1000 Watts RMS Subs, Alpine IVA-D901 In Dash Flip Out Screen With Nav.
Suspension: KYB Struts, Tien S. Tech Springs, 19X9 SSR D5R in bronze with a polished lip, 245/35/19 Toyo Proxes T1R, Proracer Racing Lug Nuts in red, Rear Strut Bar.
Body: Viper alarm system, 8,000k HID.
www.ipsmotorsports.net
www.dynamicracing.com
www.kormextrans.com
HumanVr4 is offline   Reply With Quote
Old 10-07-2007, 09:32 AM   #26 (permalink)
Damn It!
3startuna's Avatar
Trader Rating: (14)
would you mind if i post the videos on youtube?
Old 10-07-2007, 12:38 PM   #27 (permalink)
Supermactastic
supermac's Avatar
Trader Rating: (33)
go for it man. i would do it myself but i dont know how.
Old 10-07-2007, 01:40 PM   #28 (permalink)
Damn It!
3startuna's Avatar
Trader Rating: (14)
ok their up just waiting on them to process then ill post the links.
Ill see if i can grab one of these off you this month.
Old 10-07-2007, 01:58 PM   #29 (permalink)
Damn It!
3startuna's Avatar
Trader Rating: (14)
here are the links
Old 10-07-2007, 11:08 PM   #30 (permalink)
Supermactastic
supermac's Avatar
Trader Rating: (33)
hey man thanks alot. they work great.
