#1 (permalink) |
Supermactastic
ok heres a nice little good for you boys & gals running nitrous fogger systems.
the point of this plate is simple... spray each intake runner with equal amounts of nitrous to insure a perfect mist amount into your engine. the problem with typical fogger systems is that they must be plumbed into your intake tube and when you spray most of the mist is dissapated into your plenum and randomly sorted into each runner before hitting the combustion chamber. well... not anymore. We designed a plate made from 6061 aluminum that sandwiches between your upper and lower intake plenums. you simply install the plate and screw your nitrous line to the provided fitting. then its spray juice time. you will get an even spray pattern and amount everytime you hit the juice. Price is $200 shipped ![]() ![]()
#3 (permalink) |
Paternus Expectus
WOW! Looks good! Are there any concerns with uneven spray b/w ports?
I got two speeds... Faster than you... and KICKING YOUR ASS. 1995 Dodge Stealth RT/TT - Black/Tan Leather (1 of 10) '99 Front end conversion with a thing or two... |
#6 (permalink) |
Supermactastic
added a pic of the plate installed.
also i just wanted to let people know that this is a rough model we worked up for testing and pics and such. the actual product once we start making them will be water jetted from 6061 aluminum and will be much nicer. |
#7 (permalink) |
Its Z06 Time now...
badass! Im in for videos too...
Rolls are for fat bitches... Ya dig?!?
![]() -2004 GMC Yukon XL Denali - Black on Black Leather - Fully Loaded -2001 Chevy Corvette Z06 - 12.30@114 1.75 60ft BONE STOCK -1991 Dodge Stealth RT Twin Turbo - Black on Black Leather - Project car for sale! lots of extra parts! PM me! |
#9 (permalink) |
DSM GURU
Excellent idea, would be a great way to set up direct port methanol/water injection also
1992 Mitsubishi 3000GT VR-4 RIP 3/06
1990 Eagle Talon TSI AWD - 11.29@126 - SOLD 1991 Dodge Stealth RT/TT - Traded 1992 Eagle Talon TSI AWD - Where fast really is cheap |
#10 (permalink) |
Supermactastic
you can control the amount of flow with your nitrous hose fittings. most nitrous kits include a step up jet in 50 75 and 100hp increments. you simply install the jet into your nitrous line and it does the regulating for you. all this plate does is make sure you have an even spray into all your cylinders. we also use a specific hole size on the inner line to maximize how much spray can go through. we have this prototype plate set at 125 hp. (providing thats what size jet you were using).
