#1 (permalink) |
I dont really understand this at all. I would like the 8000k bulbs for both low and high beams for a 96 3000gt. If you could PM me back and explain to me or whatever i have to do to get these. Thank you very much
In the process of a big build ask if wondering My myspace is www.myspace.com/starbuks
My name is kyle m kilmore also on facebook 96 3000gt panama green- mod list ![]() Corbeau fx1 pro seats and harnesses fav upgrade thus far!!! carbon fiber hood, 3sx lightweight pulley, straight pipes, lightweight flywheel, fidenza 3.2 stage clutch, gutted, no cruise control or a/c, 3sx solid motor mounts, deft racing aero latches, megan coilovers, toe and camber kit for the rear, from and rear sway bars, frnt and rear strut bars, rear spacers, bf goodrich g-force kdw 245/40, kazera 18s, short shifter, performance steering wheel, 3sx custom dual pass radiator! As of 11-28-08 Corner Balanced, toe and camber setup professionally!! Only weighs 2773lbs! to be exact |
#2 (permalink) |
I dare you to take it!!!
Actually i wouldent recomend HID for your high beams. Just for the fact that it takes them a while to warm up, so if your flashing them off and on ex.( driving on the road with highs then turning them off when a car goes by then back on) This will shorten the life of the ballast i believe. Personally i would just get the HID for the low beams and some bright sylvanis for the highs. Anybody else wanna chime in on this subject?
Is trying to keep the mod bug at bay for a while longer!
| Thread Tools | |
