Go Back   3000GT/Stealth International Message Center > Supporting Vendors > Mod Express Inc.
Old 05-22-2008, 09:21 PM   #1 (permalink)
9B's Try me in 3rd!!!
ES 3000TT's Avatar
Drives: ES 3000TT
Trader Rating: (25)
ES 3000TT is an unknown quantity at this point
Default 9006 bulbs with Regular HID Plug?
Hey do you make any 9006 Bulbs with the Regular HID Plug? or can you source an adapter for them? I have Lexus Igniter's and would like to use them on my vehicle but need 9006 bulbs instead of modding the housings to use the regular d2r bulb.
thanks i appreciate it.
ES 3000TT
Soon something else!!
2 of 2 in the US!
ES 3000TT is offline   Reply With Quote
Old 05-24-2008, 11:33 PM   #2 (permalink)
ES 3000TT's Avatar
Drives: ES 3000TT
Trader Rating: (25)
Default Re: 9006 bulbs with Regular HID Plug?
Anything guys?
Old 05-25-2008, 01:50 AM   #3 (permalink)
Paid Member
ganesht's Avatar
Drives: 3000gt vr4
ganesht Level 1ganesht Level 1
I would recommend that you replace your halogen projectors with a set of hid projectors, their cutoff is setup properly for hid lighting, so you wont be blinding other drivers. you can pick up a set of 04 or 05 acura tsx projector housings for about 170 shipped, and they are of similar dimensions to our projectors, so the mod isn't that hard to do.
ganesht is offline   Reply With Quote
Old 05-25-2008, 02:00 AM   #4 (permalink)
Paid Member
ganesht's Avatar
Drives: 3000gt vr4
oooooo.. i forgot, your running 1gen pop ups, i tried using one of those plug and play hid kits, which have the modified base, but trust me its so not worth it, first of all the light goes everywhere!!! the right night i had them i got pulled over by a cop because i was blinding everyone.
i have a 1g 3kgt which i replaced the pop ups with the 2nd gen lexan lights, and did the tsx mod on them, it did cost a lot but it was worth every single penny...
cost break down:
lexan lights: 400
paint, and sanding/buffing supplies : 25
tsx projectors: 162
hid kit w/d2s bulbs: 300 from mod exp
welding, bondo, and repainting the hood: 10
the hardest part of all this is getting our hoods to conform to the new headlights, but i think that my car looks much much better, and it no longer has an out dated look.. at the same time i got rid of the 'humps' on both sides of the hood and molded an smoother fiberglass overlay, not as sleek as the stock 2g hoods, but eons better than the 1g.
Old 05-25-2008, 01:20 PM   #5 (permalink)
ES 3000TT's Avatar
Drives: ES 3000TT
Trader Rating: (25)
Actually the 99 headlights are made similar to higher end projector units like the TSX units. Also the 99s don't have a slit for low beam like the lexan/glass units previously did.
anyways mod express any luck input info thanks. bump
Old 05-25-2008, 02:00 PM   #6 (permalink)
Paid Member
ganesht's Avatar
Drives: 3000gt vr4
the fastest way to get your answer would be to give them a call, (626) 715-9289. if i remember correctly their open 10 to 5.
