Go Back   3000GT/Stealth International Message Center > Supporting Vendors > Supercar-Engineering
Old 03-20-2008, 08:12 AM   #1 (permalink)
Boost Happy
Black_Sunshine's Avatar
Drives: a japanese dodge
Trader Rating: (62)
Black_Sunshine Level 3Black_Sunshine Level 3Black_Sunshine Level 3Black_Sunshine Level 3
Default rotor/caliper question
our stock tt rotors measure 30mm wide. do you think we could use 32mm rotors without spacers in the stock caliper? i asked this in the general forum, but i'm guessing no one knows. hope to get an answer from the road racing masters
Black_Sunshine is online now   Reply With Quote
Old 03-21-2008, 09:25 AM   #2 (permalink)
Super Member
Boostaddict's Avatar
Drives: First e16g 3/S
Trader Rating: (38)
Boostaddict is an unknown quantity at this point
Default Re: rotor/caliper question
I personally can't tell you the 100% answer to that (and I'm certainly not a road racing expert). My assumption is based on my own experience though. I don't think a new set of standard pads would fit with 32mm rotors (its just too tight). However, some pad clearancing aught to get you there (just don't breathe the brake dust).
Quaife Front LSD for AWD
Ksport Suspension Kits
Specializing in 3/S Suspension, Billet Transmission Shift Forks, 300M Output Shafts, Front AWD and FWD LSD, Transmission Rebuild Parts, STOPTECH Brake Kits, Big Reds, and Custom Brake Upgrades! More Products to Come.
1993 3000GT-VR4: AEM EMS, etc
663 awhp, 607 tq (retired tdo5-e16g's)
10.835@132.69 -26psi
Boostaddict is offline   Reply With Quote
Old 03-21-2008, 12:34 PM   #3 (permalink)
been here way too long
Turbo Powered's Avatar
Drives: Slower-@#&! Points!
Trader Rating: (18)
Turbo Powered Level 3Turbo Powered Level 3Turbo Powered Level 3Turbo Powered Level 3
The WIDE rotor kit comes with machined spacers that fit between the two caliper halves (and extra req'd O-rings). SCE sold me an extra set to put into a spare caliper set, maybe they'd sell you just those pieces. Very easy to install. Depending on where the centerline of the rotors is, you may need the spacers for the caliper mounts that also come in that kit.
Turbo Powered is online now   Reply With Quote
Old 03-21-2008, 03:02 PM   #4 (permalink)
Boost Happy
Trader Rating: (62)
thanks. i think the WIDE kit is 35mm tho right? i'm looking to use a 32mm rotor.
Old 03-24-2008, 12:44 PM   #5 (permalink)
Trader Rating: (18)
The whole idea is to be able to put new pads on and have them fit. The spacers for the 35 mm rotors will do that. The only issue is whether the caliper pistons will extend too far out when your pad wears down to the backing plate metal. Maybe SCE can answer that question for you. Or you could take the spacers for the 35 mm rotors and machine them down thinner to be the perfect size for a 32 mm rotor.
2 mm is only 0.079 inches, so that's less than 0.040" per pad clearance lost. Are you sure the stock calipers and new pads won't clear that with the pistons fully depressed?
Old 03-24-2008, 01:05 PM   #6 (permalink)
Boost Happy
Trader Rating: (62)
that's what my question is . i have no idea if it would or not. lol
