Go Back   3000GT/Stealth International Message Center > Supporting Vendors > Supercar-Engineering
Old 07-08-2008, 11:44 AM   #1 (permalink)
2xmks's Avatar
Drives: 2007 Corvette
Trader Rating: (7)
2xmks Level 32xmks Level 32xmks Level 32xmks Level 3
Default Input Shaft Bearing
I have had a couple problems with two different Input shaft bearings that I purchased through you. I sent you a e-mail a week + ago, no response. Would you please be kind enough to respond to my e-mail.
Many Thanks,
Mike
1996 TD05 VR-4 SOLD
2007 Corvette
2xmks is online now   Reply With Quote
Old 07-09-2008, 01:51 PM   #2 (permalink)
Azkicker
Boostaddict's Avatar
Drives: First e16g 3/S
Trader Rating: (47)
Boostaddict Level 7Boostaddict Level 7Boostaddict Level 7Boostaddict Level 7Boostaddict Level 7Boostaddict Level 7Boostaddict Level 7
Default Re: Input Shaft Bearing
Please send the bearings back to SCE so we can address the issue with the bearing manufacturer. Philip will send you an email response as well. Regards,
Wayne
1993 3000GT-VR4: AEM EMS, etc
663 awhp, 607 tq (retired tdo5-e16g's)
10.835@132.69 -26psi
Now alive and kicking. Preparing to eat small children in '09
Badass Oil Pump Gears Available Now
The Best Valve Springs Money Can Buy
Boostaddict is offline   Reply With Quote
Old 07-09-2008, 04:01 PM   #3 (permalink)
2xmks's Avatar
Trader Rating: (7)
Thank you Wayne.
Old 09-19-2008, 12:45 PM   #4 (permalink)
AWD Road Racing Fanatic
Supercar's Avatar
Supercar Level 3Supercar Level 3Supercar Level 3Supercar Level 3
The manufacturer is inspecting the failed bearing that I received. Once I hear from them, I will post the results. The earlier reports were that such problems occurred several years ago and were contained. If they recurred, I will let you know.
I can't wholeheartedly recommend this product because of the known failures. The failure rate is still in single digits, so if you have no other options, like a good used bearing, you might want to give this a try. My only alternative is to pull the product off the shelves for good. I may have to do it, if this keeps hurting the SCE reputation. But then you won't be able to buy anything.
Supercar #1 - 1995 R/T TT
- 3SNG'08 Autocross 1st place and F.T.D.
- 3SNG'05 Autocross 1st place and F.T.D.
- 1:33 Lap Time at Gingerman
- 2:35 Lap Time at Road America
Supercar #2 - 1994 R/T TT <-- For Sale
Supercar #3 - 2000 Porsche 911
Supercar Engineering : http://supercar-engineering.com
* NEW Product! Dog Box Transmission
* NEW Product! Dry Sump system
* NEW Product! SCE Torsen Center Differential
* NEW Product! 380mm 6-piston StopTech Big Brake Kits
Visit our 3Si Vendor Forum and Supercar Engineering website to learn about our products:
STOPTECH Brake kits, custom brake kits, Ksport Suspension Kits and Ksport Brake kits
SCE Torsen Center LSD, Quaife and OBX Front LSD, KAAZ Rear LSD Differentials
Carbotech, Porterfield and Axxis Ultimate high-performance Carbon Ceramic and Kevlar Ceramic brake pads
APR Front Splitters and functional Rear Wings
SCE is a stocking distributor of Motul racing oils and brake fluids
New and Used Transmission Rebuild Parts, Cam Lockers, Billet Transmission Shift Forks, 300M Shafts, and more products to come.
Supercar is online now   Reply With Quote
Old 09-19-2008, 11:06 PM   #5 (permalink)
2xmks's Avatar
Trader Rating: (7)
Thank you Phillip. Your response is greatly appreciated.
Old 10-11-2008, 04:00 PM   #6 (permalink)
Supercar's Avatar
I have an update. The manufacturer has admitted problems with some of these bearings. Based on how many they sold, and how many they heard went bad, they are not producing them anymore. They would issue refunds for any of their failed bearing that was recently purchased (about one year, I was told).
If you recently bought any of these input shaft bearing from Supercar Engineering and they failed, please send them back, along with the note telling the date of purchase, and I will issue a refund. Thank you.
Mike, I sent you a private email about issuing a refund. You PayPal does now work, it appears. Thank you.
Philip
