Go Back   3000GT/Stealth International Message Center > Supporting Vendors > Supercar-Engineering
Old 07-08-2008, 10:44 AM   #1 (permalink)
2xmks's Avatar
Drives: 1996 VR-4
2xmks Level 12xmks Level 1
Default Input Shaft Bearing
I have had a couple problems with two different Input shaft bearings that I purchased through you. I sent you a e-mail a week + ago, no response. Would you please be kind enough to respond to my e-mail.
Many Thanks,
Mike
93mm Ross Pistons,Pauter Rods,3SX Port and polished heads,Webcams race cams,ARP main/head studs,South Bend Stage 4"FE" clutch,720 cc injectors,Supra fuel pump,IPS FMIC, IPS TD05 headers/EVO III turbo kit,Tanabe exhaust, Hiro Axis 19x9.5 rear 8.5 front, Toyo Proxes T1R 285 rear 245 front
2xmks is offline   Reply With Quote
Old 07-09-2008, 12:51 PM   #2 (permalink)
Super Member
Boostaddict's Avatar
Drives: First e16g 3/S
Trader Rating: (38)
Boostaddict is an unknown quantity at this point
Default Re: Input Shaft Bearing
Please send the bearings back to SCE so we can address the issue with the bearing manufacturer. Philip will send you an email response as well. Regards,
Wayne
Quaife Front LSD for AWD
Ksport Suspension Kits
Specializing in 3/S Suspension, Billet Transmission Shift Forks, 300M Output Shafts, Front AWD and FWD LSD, Transmission Rebuild Parts, STOPTECH Brake Kits, Big Reds, and Custom Brake Upgrades! More Products to Come.
1993 3000GT-VR4: AEM EMS, etc
663 awhp, 607 tq (retired tdo5-e16g's)
10.835@132.69 -26psi
Boostaddict is offline   Reply With Quote
Old 07-09-2008, 03:01 PM   #3 (permalink)
2xmks's Avatar
Drives: 1996 VR-4
Thank you Wayne.
