Go Back   3000GT/Stealth International Message Center > Supporting Vendors > Supercar-Engineering
Old 05-28-2008, 02:56 PM   #1 (permalink)
Unknown 3000GT VR4 :**
Dj_Frost's Avatar
Drives: 94 Rare VR4
Trader Rating: (29)
Dj_Frost Level 2Dj_Frost Level 2Dj_Frost Level 2Dj_Frost Level 2
Default Gear Selector
Hey Phil,
Are you able to get this part or do you currently sell it? I think I might need it for my car... its currently at the shop cause it got stuck in gear and it seems thats going to be the part to blame.
Thanks
Daily: 2002 BMW 330ci (Angel Eyes+HID, 19" Rims, aFe Stage 2 Intake, ACS Exhaust, Interior Detailing)
Wkend/Track/Kill Ride: Rare 1994 Custom Pearl White/Blue 3000GT VR4 - 82250 Miles - Weight: 3560lbs
Best 1/4 Time: 13.0@???MPH with a ?.?? 60' Ft
Click to read all about my rare 3000GT VR4 <---> Rate my vr4!
Dj_Frost is offline   Reply With Quote
Old 05-31-2008, 01:14 PM   #2 (permalink)
Dj_Frost's Avatar
Drives: 94 Rare VR4
Trader Rating: (29)
Default Re: Gear Selector
I guess the gear selector is called the shift forks and saw you offer the 6speed tranny ones but my vr4 is a 5 speed 25 spline. Do you offer those? I think that might not be needed though. My gears are being pulled apart right now and I'll be able to see what was grinded.
I want to order all the tranny bearings and seals and the only thing I see on your site is the Getrag Transmission Synchro Rebuild Kit - 1&2 Gears Only[TT-Synch12]. That kit brings the 1st /2nd friction ring but what about the inner and outer ring?
And it has the seals for the input shaft end plug, output shaft and left/right axle. But I know there are many more seals
Do you also have other parts like 3rd and 4th rings (inner, outer, friction)?
For bearings I see from a list I got from Autocraft that I need around 16 bearings (4 of the for a CONE? and 4 for a CUP? part) and 8 needle bearings. Do all of those come in the kit you offer? Getrag Transmission Bearing Kit[TT-BearingKt] (on the description it says 2 needle bearings)
Thanks for your help and if you have the parts but are just not listed on your site, please send me a quote for everything I need for 1st - 4th gear syncros (inner, outer, friction) and all seals and bearings possible.
If you need me to call in or something please let me know. I need to place this order this week asap so I can get my tranny back up and fixed. Thanks!
Old 06-11-2008, 04:26 PM   #3 (permalink)
Ninja vs Zombie the Movie
Boostaddict's Avatar
Drives: First e16g 3/S
Trader Rating: (62)
Boostaddict is an unknown quantity at this point
What is on the site is for the most part all that SCE has available. There are slim pickings available for our gearbox now. SCE does not currently offer the billet 5-speed shift forks. The only shift forks you'll find for the 5-speed going forward might have to be imported from Japan or find used parts (unless someone else still has some inventory left).
Statements made by Boostaddict are not necessarily the views/opinions of SupercarEngineering.
1993 3000GT-VR4: AEM EMS, etc
663 awhp, 607 tq (retired tdo5-e16g's, 2006)
10.835@132.69 -26psi (2006)
11.22@137.6 - what is traction? (2009)
New Cheap OEM Getrag Syncros (Limited Quantities)
Badass Oil Pump Gears
Badass Beehive Valve Springs
Boostaddict is online now   Reply With Quote
