#71 (permalink) | |
est. sept, 2000
yeah. the gears are always meshed but the whine is barely noticable unless loaded. i could live with straight cut 1,2, and 3
97 VR4 12.417@111.16 9b time. full weight almost BPU
95 mark viii. 14.35@98 03 cobra vert. 4 mods=118mph traps 91 stealth TT. td05 18G, heads/cams, 3000lbs 95 montero SR. factory rear locker. 3.5 DOHC ![]() |
#73 (permalink) |
AWD Road Racing Fanatic
Let me post some clarifications. No pics yet though, sorry.
It will be a dog box with all new gears. The gear ratios are TBD. The pricing is about the same that some of you guys were quoted, not more, but not much cheaper either. A dogbox is not a fancy mod for street ricers, so only those with a real need and money will be buying them. Therefore the emphasis is on quality, strength and (hopefully) better gear ratios. The first pilot is a 6-speed. The 5-speed is following in a short order though. There is quite a bit of similarities between the two transmissions, so a lot of engineering will be carried over. It's not sequential. A sequential gearbox would require a complete redesigh. At that point it would be easier to make a case from scratch and stuff it with off-the-shelf gears. The gears will be helical. Like Frank noticed, nobody breaks those gears, and the only reason to go with straight gears is tooth strenght, which comes at a cost of a a whiny transmission. Anyone cares to drive a car where the transmission is louder than the engine? If the tooth strength proves to be a problem in the future, which is unlikely given the 15 years of 3/S drag racing experience, then straight-cut 1st and 2nd gears can be made, no problem. I do not want to hear any "whining" then that the transmission is loud. The 3rd gear ratios will have to remain unchanged. The third gear meshes with the central differential body, so if the central differential is kept unchanged then the 3rd gearset will have to remain the same. The 1st gear will probably eventually be taller. Suggestions from drag racers are welcome, both 5 and 6-speed. The second gear is in between the 1st and 3rd. The 4th gear will be shorter. The tallest 5/6th gear is for cruizing. I personally like the "MR" 6th gear ratio where I cruise at 75-80 mph at 2500 rpm. This is also what appers the stock 5-speed ratio is. Any objections to that? I will have pics hopefully in a few days. A test drive is just around the corner. It is sooner than most think, but do not press me for a date as I do not want to rush or promise anything. I do not want to sacrifice any transmissions to a hasty development. The dog box is coming, that is for sure. Philip ![]()
Supercar #1 - 1995 R/T TT
- 3SNG'08 Autocross 1st place and F.T.D. - 3SNG'05 Autocross 1st place and F.T.D. - 1:33 Lap Time at Gingerman - 2:35 Lap Time at Road America Supercar #2 - 1994 R/T TT <-- For Sale Supercar #3 - 2000 Porsche 911 ------------------------------ Supercar Engineering : http://supercar-engineering.com * NEW Product! Dog Box Transmission * NEW Product! Dry Sump system * NEW Product! SCE Torsen Center Differential * NEW Product! 380mm 6-piston StopTech Big Brake Kits Visit our 3Si Vendor Forum and Supercar Engineering website to learn about our products: STOPTECH Brake kits, custom brake kits, Ksport Suspension Kits and Ksport Brake kits SCE Torsen Center LSD, Quaife and OBX Front LSD, KAAZ Rear LSD Differentials Carbotech, Porterfield and Axxis Ultimate high-performance Carbon Ceramic and Kevlar Ceramic brake pads APR Front Splitters and functional Rear Wings SCE is a stocking distributor of Motul racing oils and brake fluids New and Used Transmission Rebuild Parts, Cam Lockers, Billet Transmission Shift Forks, 300M Shafts, and more products to come. |
#74 (permalink) |
Resident rocket scientist
That's awesome. I look forward to hearing progress on this. Though I may not be a potential customer anytime soon, I think this is an excellent idea.
![]() 1993 3000GT FWD ATX TT - mods coming<---------------->2009 Honda Fit - 40 mpg ftw Topline Engineering ground wire kit Nov/Dec ground wire GB!!! |
#75 (permalink) |
Pro xfercase destroyer
Thanks for the update Philip - it is greatly appreciated!
I'd like to see an option for straight-cut gears. It isn't the tooth strength that I'm interested in (it could be argued that either design is similar for tooth strength) - it is reducing the side load against the case and bellhousing that I'm personally interested in.
-Matt
'95 3000GT Spyder VR4 (11.838@117.56) '93 3000GT VR4 (Project for 2009) '91 3000GT VR4 (Only a shell of its former self) ![]() |
#76 (permalink) | |
July 2003
Max
1994 3000GT VR-4. Hobbies... what are hobbies? Oh, those things people do when they're NOT working on their cars?
#77 (permalink) | ||
red '91 VR-4
)Roughly, is that correct?
![]() Quote:
#79 (permalink) | |
July 2003
Max |
#80 (permalink) | |
red '91 VR-4
LinkBacks (?)
LinkBack to this Thread: http://www.3si.org/forum/f151/dog-box-326381/
| Posted By | For | Type | Date | |
| New Dog Box Transmission for our cars - Florida's Mitsubishi 3000GT & Dodge Stealth Community! | This thread | Refback | 04-13-2008 10:04 AM | |
| New Dog Box Transmission for our cars - Florida's Mitsubishi 3000GT & Dodge Stealth Community! | This thread | Refback | 04-13-2008 09:53 AM | |
| New Dog Box Transmission for our cars - Florida's Mitsubishi 3000GT & Dodge Stealth Community! | This thread | Refback | 04-12-2008 06:01 PM | |
| Thread Tools | |
