#41 (permalink) |
Pro xfercase destroyer
A dogbox (also known as "crashbox") is a transmission like what is used in motorcycles. There aren't synchronizers between the gears, and the engagement of gears happens via interlocking "dog" plates. The dogs are kind of like squared teeth that are back-cut so they lock together when pressure is applied. Dogbox trannies typically use straight-cut gears instead of helical-cut gears like typical road cars use. The straight-cut gears have a tendency to whine during use.
When shifting a dogbox, you have to do it with authority or the dogs will grind against each other. The really nice thing about this sort of setup is that you can hold the gas to the floor, and just pull on the shifter and when the motor hits redline and the power is cut for a split second the gears should automatically slide into 2nd gear and then relock. That's how I shift my bike - just get going in 1st gear, then apply pressure upwards on the shifter with my foot, and when it hits the revlimiter it just flicks up into the next gear. If it isn't setup sequential though then the 2-3 shift might need a bit of clutch to go with it since the shift will take longer than a 1-2 or 3-4 shift. The drawback (other than the noise) is that you can't granny shift them - every shift has to be done quick so as to not round off the edges of the dogs. If you want to see one in action, watch just about any rally race in-car footage from any of the pros.
-Matt
'95 3000GT Spyder VR4 (11.838@117.56) '93 3000GT VR4 (Project for 2009) '91 3000GT VR4 (Only a shell of its former self) ![]() |
#42 (permalink) | ||
Dec. 2001
![]() 1991 Dodge Stealth R/T Twin Turbo MODS|ATR Downpipe|HKS Super Dragger|DN Pre Cat Elims|AEM WB02 Gauge|Ek2mfg Fuel Rail Loop|Polished Fuel Rail|Wrinkle Black Intake Mani|Mirror Red Valve Cover|Injector Harness Cover|Ohio Bob Short Throw Shifter|DN Intake Pipes|Palm Datalogger|TD04L 15G Turbos|EGR Block Off Plates|Vac Reduction|Evap Delete|Cruise Control Delete|A/C Delete|Battery Relocated|E2kmfg Poly Mounts|PTE 680 Injectors|Hotwired Walbro 255lph FP|Snow Performance Water/Meth Injection|Tein Coilovers|18x9 Saleen Replicas| 265/35/18 Sumitomo HTR II|New Shortblock|Rebuilt Heads|IPS FMIC|RPS Max Street|AEM EMS|AEM IAT|AEM 3.5 BAR| Next Up: Tuning AEM 1994 Dodge Stealth R/T Twin Turbo Under ConstructionTD05's & Much More |
#43 (permalink) |
165 mph and counting...
A dogbox for a car is a LOT different than for a typical motorcycle.
Motorcycles usually have two friction plates in between gears, and the gears and plates themselves are thin, allowing for slow shifting, while still being able to hold the power for quick downshifts and heavy throttle. I'd be curious to see how this would perform in our cars... I can't imagine it would be very streetable at all. Those rally cars running dogboxes are pretty brutal. However, I know the DSM dogbox does allow for some streetability, but the DSM's are much lighter so you don't have to be as precise with them to avoid stalling/jerking.
![]() 1991 Stealth Twin Turbo Mods: 13T turbos, Stillen downpipe, HKS Super Drager catback, Fidanza adjustable cam gears, UR flywheel, DXD-F, DSM sidemount intercoolers, front mount oil cooler, LS6 MAFT, DN Y-pipe, gutted precats, ported exhaust manifolds, Apexi AVC-R set to 1.0 kg/cm, Greddy BOV type S, Supra pump, and an Unorthodox racing pulley. |
#44 (permalink) |
Yup, a motorcycle gearbox is different than what you'd put on a car, but most of the principles are similar and how they react for shifting is somewhat similar.
The big thing is the lack of synchros as far as shift feel goes. If you want to downshift in a dogbox you should double-clutch, etc. |
#47 (permalink) | |
king of ghetto
Nope, pre-development cycle for production. Actual cost would include amorized development costs, and continued support. If you want a one-off, prepare to pay out over $120K, and little support. As for breaking it, welcome to the big leagues. ProDrive supplies (or more correctly: the team buys) 4 complete transmissions to every race for their IMSA 550. If you're not breaking shit, you're not getting faster.
pıdnʇs 'ɹǝʌo ǝɯ dılɟ
![]() Official member of the "I upgraded everything in my car and now it's slower than stock" club. |
#48 (permalink) | |
Corn Its whats for boost
if you aren't breaking shit, you aren't trying hard enough
AEM Factory Trained Tuner
![]() 91VR4-3.0L-Stock heads and Cams-762AWHP 747AWTQ 30psi E100 Daily Driver 10.63@121mph SLTT-10.9 @ 140MPH Stock NA motor and NA heads/Cams T4 AWD 9.21 @ 154.98 T2 FWD 10.19 @ 140.31 T4-159.23 MPH Ran on 6G72 3.1L! T4-995AWHP Uncorrected 6G72 3.0L C16 T2-820FWHP 3.1L 27psi C16 91VR4 Red-17Gs w/supporting mods-sold 93SLTT/T2 91VR4 Pearl White-sold 91VR4 Black-sold 92VR4 Sandstone-sold 94VR4 Green-sold 93VR4 Pearl White-sold NG09 Title Sponsor 3SX Performance 3SX Performance Service Email |
LinkBacks (?)
LinkBack to this Thread: http://www.3si.org/forum/f151/dog-box-326381/
| Posted By | For | Type | Date | |
| New Dog Box Transmission for our cars - Florida's Mitsubishi 3000GT & Dodge Stealth Community! | This thread | Refback | 04-13-2008 10:04 AM | |
| New Dog Box Transmission for our cars - Florida's Mitsubishi 3000GT & Dodge Stealth Community! | This thread | Refback | 04-13-2008 09:53 AM | |
| New Dog Box Transmission for our cars - Florida's Mitsubishi 3000GT & Dodge Stealth Community! | This thread | Refback | 04-12-2008 06:01 PM | |
| Thread Tools | |
