#1 (permalink) |
Just wondering what the difference is between the Quaife and OBX LSDs. I know the Quaife is almost twice as much, but as far as quality how do the two stack up? Anybody have any experience with the OBX?
#2 (permalink) |
king of ghetto
The Quaife is made more "sturdy", slightly heavier and generally "overbuilt". Not a technical explination, yes, but that's basically what Phil told me. I personally would spend the coin for the Quaife unit if you have plans for serious power. I think they both have warranties, but I haven't dealt with OBX at all, so I don't know if they are any good or not.
pıdnʇs 'ɹǝʌo ǝɯ dılɟ
Official member of the "I upgraded everything in my car and now it's slower than stock" club. |
#3 (permalink) |
Damage Control
OBX = Ebay garbage usually. Quaiffe overs a lifetime warantee, even if its broken while racing it. Thats worht the extra coin to me.
Kbizzle [11:25 P.M.]: this is most displeasing |
#4 (permalink) |
Mr. Cheese
My SL had a quaife LSD and it took a ton of abuse and never gave me any problems. I had pretty big tires on it too so it had lots of traction (265's), solid motor mounts and a stage 3 clutch and I'd do burnouts and launch the car hard and it took the abuse. Highly recommended if you're going to be making any power.
1992 Dodge Stealth RT-Twin Turbo
64,000 miles, Stored Winters, AEM Tru-Boost, Greddy Type S BOV, DNP Hardpipes, Palm MMCD, Tein S-Tech Springs, Brembo Rotors, MSD Wires, K&N FIPK, EGR Delete, Vacuum Reduction, Cianci 3 Gauge A-Pillar, 5zigen FN01R-C 18x9.5's wrapped in BFG KDW 265-35-18's. 13% Tint, 12 Disc CD changer, 3 1/2 inch Custom Exhaust. ![]() DD-Pearl White 92 Stealth TT-85,000 on it, BPU 270 awhp, 307 awtq on 8-23-08 |
#5 (permalink) |
AWD Road Racing Fanatic
Quaife is the top of the line. It's a benchmark. It has an impecable reputation and comes with a limited lifetime warranty.
OBX copies a lot of Quaife designs, including this one. I have inspected every one of them, and added Loctite to the bolts that hold it together, just like Quaife does. I believe OBX will be able to stand the same abuse. It offers the same warranty.
Supercar #1 - 1995 R/T TT
- 3SNG'08 Autocross 1st place and F.T.D. - 3SNG'05 Autocross 1st place and F.T.D. - 1:33 Lap Time at Gingerman - 2:35 Lap Time at Road America Supercar #2 - 1994 R/T TT ------------------------------ Supercar Engineering : http://supercar-engineering.com Ksport Suspension Kits Billet Transmission Shift Forks, 300M Shafts, LSD, Transmission Rebuild Parts STOPTECH Brake Kits, Big Reds, and custom brake upgrades bonanza! 3/S Open tracking parts, Carbotech, Porterfield and Axxis Ultimate high-performance Carbon Ceramic and Kevlar Ceramic brake pads, and more products to come. Already here: a Dog Box, SCE Torsen Center Diff, OBX and Quaife Front Diff, KAAZ Rear Diff, Dry Sump Oil System, Ohlins/Moton/KW/more Suspensions. |
#6 (permalink) |
Super Member
I had both of them in my hands and visually you can't tell the difference between the two. I might very well try out an OBX in my vr4 with its new setup.
1993 3000GT-VR4: AEM EMS, etc
663 awhp, 607 tq (retired tdo5-e16g's) 10.835@132.69 -26psi Now alive and kicking. Preparing to eat small children in '09 ![]() |
#7 (permalink) |
Do OBX and Quaife put out spec. sheets with regards to what materials and methods are used to make them? Is there any way of determining if they are indeed made of the same quality of steel, ie. 4340 etc.?
#8 (permalink) | |
* Let's agree to respect each others views, no matter how wrong yours may be.
** It could be that the purpose of your life is only to serve as a warning to others. *** When you earnestly believe you can compensate for a lack of skill by doubling your efforts, there's no end to what you can't do. **** There are no stupid questions, but there are a LOT of inquisitive idiots. |
#9 (permalink) |
cyber bully
I just saw this on supercar website and I was wondering what the difference was myself. I have to admit I am kind of excited about it. I have a 95 base with a TT conversion so I was planing to buy a used Quaife from a member on the boards then a friend made me an offer on a 6 speed that I just couldn't refuse. Now I need a TT clutch and a AWD LSD. I just cant bring myself to put that trans in without a LSD. I put the install on hold because of the price of the Quaife hoping to find a used one for a good price. Now with the price of the OBX I'm thinking I might be a little closer to getting this thing in.
#10 (permalink) |
Okay, here is one reason why you might want to choose one over the other. Quaife appears to have a better finish on the gear teeth. It costs money to produce a better tooth finish, so it makes sense that it is more expensive. From my personal experience I can tell that Quaife provides a more smooth and consistent operation from the very beginning. OBX seems to be more aggressive initially, due to the initially higher internal friction, but after about a week of driving it breaks in, the gear surfaces smooth themselves out, and you cannot tell the two apart.
Still, no special break-in is required for either diff. Philip |
