Go Back   3000GT/Stealth International Message Center > Supporting Vendors > Supercar-Engineering
Old 03-27-2008, 06:30 AM   #1 (permalink)
''the professor''
i3igpete's Avatar
Drives: GoPigGo v2.0
Trader Rating: (70)
i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7
Default canton accusump
wayne,
have you guys looked into offering a canton accusump setup? It's basically a regulated high-pressure reserve cylinder of oil that stores up oil when pressure is sufficient and discharges when pump pressure drops. I think it would go nicely with the pan, (or maybe in place of it if philip's tired of welding).
3 quarts of high pressure reserve oil would be pretty sweet if the oil pump decides to crap out on the end of a long straight and you need enough time to pull onto the grass.
Maddog Performance Engineering
We disrespect 9B's and the people that own them
i3igpete is offline   Reply With Quote
Old 03-27-2008, 10:16 AM   #2 (permalink)
Super Member
Boostaddict's Avatar
Drives: First e16g 3/S
Trader Rating: (36)
Boostaddict is an unknown quantity at this point
Default Re: canton accusump
I think this would be a great idea myself. I know the pans are a PITA to coordinate. I'll look into the idea and talk to Philip about it when I see him.
Quaife Front LSD for AWD
Ksport Suspension Kits
Specializing in 3/S Suspension, Billet Transmission Shift Forks, 300M Output Shafts, Front AWD and FWD LSD, Transmission Rebuild Parts, STOPTECH Brake Kits, Big Reds, and Custom Brake Upgrades! More Products to Come.
1993 3000GT-VR4: AEM EMS, etc
663 awhp, 607 tq (retired tdo5-e16g's)
10.835@132.69 -26psi
Boostaddict is offline   Reply With Quote
Old 03-27-2008, 01:25 PM   #3 (permalink)
Dago Red Vr-4 is an unknown quantity at this point
Wayne , I have been using one for years and its saved me a couple of times . I have mine plumbed into the oil pump body where the gauge sender is located . I had to tap it to NPT so I dropped the pan and removed the pump to insure no material got into the engine during the tapping process ,cleaned and re-installed . The accumulator sits under the battery tray . I just took the engine down for freshing up and found after 165,000 miles the crank was near perfect . All it needed was micropolishing and hence standard bearings went back in . Steve
Dago Red Vr-4 is offline   Reply With Quote
Old 03-28-2008, 06:21 AM   #4 (permalink)
been here way too long
Turbo Powered's Avatar
Drives: Slower-@#&! Points!
Trader Rating: (15)
Turbo Powered Level 1Turbo Powered Level 1
Curious what size/capacity fit where you mounted yours? Also what size turbos do you have and what boost do you usually run? When it "saved you" a couple times, what happened?
Turbo Powered is offline   Reply With Quote
Old 03-28-2008, 06:46 AM   #5 (permalink)
never a dull moment
DCIV's Avatar
Drives: 92 VR4
Trader Rating: (12)
DCIV level 6DCIV level 6DCIV level 6DCIV level 6DCIV level 6DCIV level 6
I am curious how long a 3qt one would last you. I guess its given the damage and psi released out at but I wouldnt guess to long.
Coop
To many mods to list.
Old 03-28-2008, 07:10 AM   #6 (permalink)
''the professor''
i3igpete's Avatar
Trader Rating: (70)
talked with a colleague that does lube circuits, 60-80 L/min is a typical pump flowrate for a 4 cylinder running at redline and full load. flow rate is roughly linear with engine speed.
so apparently just enough to clutch in, hit the brakes and shut down; if your oil pump blows up completely. Probably quite a bit more time if it's still "kind of" working.
Old 03-29-2008, 09:06 PM   #7 (permalink)
Turbo , I have a very old 1QT system installed under the battery tray . Its been there since 1994 and has never failed . I use it to pre-lube the engine prior to startup ,cold or hot ,also a side benefit is that if the oil pressure falls below a certain set point the accumulator will intervene to maintain that set point . It saved me when I let the oil level get a little low and I was blasting around some back roads and the pressure dropped due to sloshing and exposing the pickup . Currently I am looking at the 2 qt unit but i do not have an adequate space picked out yet since they are 4.250" in Dia . Additionally I use Mobil 1 and OEM filters since day one . One more thing Moroso also makes one like the Canton/ Accusump that is available through Summit . I have never used the Moroso but just to let you know there are options . Steve
Old 05-12-2008, 04:46 AM   #8 (permalink)
91 RT/TT
EvanH's Avatar
Drives: 91 RT/TT
EvanH is an unknown quantity at this point
BUMP for a great idea
EvanH is offline   Reply With Quote
Old 05-13-2008, 08:20 AM   #9 (permalink)
ely
ely's Avatar
Drives: 95 Stealth R/T TT
ely is an unknown quantity at this point
I think the same,that it would go nicely with the pan, also could be sold as a complete kit.
'99 Front Bumper, Philips HID's, Infinity Kappa 693.7I & Kappa Perfect 6.1 & Kappa Perfect 12VQ, Dietz Power Cap 1F, Pioneer HU, 2x Kenwood Amplifiers
Apexi AVC-R, K&N AirFilter, Supra pump hotwired, Tein Flex Coilover Suspension Kit, .... more to come
....and yes BORLA, is a romanian.
ely is offline   Reply With Quote
