Go Back   3000GT/Stealth International Message Center > Supporting Vendors > Maximal Performance
Old 06-17-2008, 07:40 PM   #1 (permalink)
Pearl White 3kGT
Jancas02's Avatar
Jancas02 is an unknown quantity at this point
Default Solids on a n/a ATX
I was wondering if anyone had installed solid mounts on an auto trans. Just curious if they caused anything abnormalities. I have a mildly built auto and was just wondering if I should worry about anything breaking. The vibrations are not an issue since I drove darksurfr car and honestly it felt badass.
Green '93 3k - sold
Jancas02 is offline   Reply With Quote
Old 06-23-2008, 07:33 AM   #2 (permalink)
Supporting Vendor
Maximal's Avatar
Drives: '91 Stealth "ES"
Trader Rating: (180)
Maximal Level 2Maximal Level 2Maximal Level 2
Default Re: Solids on a n/a ATX
I know there are a few auto's running them and I at least haven't heard of any complaints. I don't see any reason they would cause issues on an Auto.
Terry
Maximal is offline   Reply With Quote
Old 06-23-2008, 08:46 PM   #3 (permalink)
Engineering Student
Alex3000GT's Avatar
Drives: 92 3000gt base
Trader Rating: (12)
Alex3000GT Level 7Alex3000GT Level 7Alex3000GT Level 7Alex3000GT Level 7Alex3000GT Level 7Alex3000GT Level 7Alex3000GT Level 7Alex3000GT Level 7Alex3000GT Level 7
My G/F has had solids on her ATX for the past 10,000 miles.
No problems!
NG06 - DOHC NA - ATX --- 16.6 --- 85 MPH
NG07 - DOHC NA - MTX --- 15.7 --- 89 MPH 7.78 sec 0-60 3,044 lbs w/out driver
1992 3000GT
1991 Stealth
Alex3000GT is online now   Reply With Quote
Old 06-23-2008, 09:00 PM   #4 (permalink)
3/S Junkie
LiL Jon's Avatar
Drives: it like i stole it
LiL Jon is an unknown quantity at this point
i have solids on mine... but I have N/A MTX, I have absolutely no issues, I don't see why the ATX would be any different
side note, It makes a hell of a difference having those solids on
Kutani Red Pearl 1991 Dodge Stealth R/T #9 of 15 Identical... #73 of 265 Kutani Red Pearl
1994 Dodge Stealth R/T Luxury - Spun Bearing Aug '07 - Out
Life Begins At 100+ MPH
Get In... Sit Down... Shut Up... Hang On... No Limits Racing
LiL Jon is offline   Reply With Quote
Old 06-24-2008, 10:00 AM   #5 (permalink)
Pearl White 3kGT
Jancas02's Avatar
Thanks for all the replys, I will be getting the solids soon and will be posting my thoughts. I can't wait for these since my motors mounts are completely shot and banging on my hood and firewall
Old 06-26-2008, 02:14 AM   #6 (permalink)
Q-Bert
IronFish's Avatar
Drives: 1991 3000GT SL
IronFish is an unknown quantity at this point
I have had the solid mounts for 4+ years now. Never any issues. Everyone always told me they would cause damage or the drive would be intolerable due to the extra vibrations felt in the car. I have never thought the extra vibration was that bad.
1991 3000GT SL
ENGINE: 3.1L (bored .030), wiseco forged pistons, rebuilt heads with 5 angle valve job and '99 lifters, fidanza cam gears, webcams street-grind cams, Precision Turbo 525cc injectors, ported upper and lower intake plenum, UDP, 3KGT full length headers, 3KGT downpipe, test pipe, flowmaster 42 series, KN air filter with intake pipe, Maximal solid motor mounts, SAFC II, RIPP SDS (uninstalled)
SUSPENSION: 3sx front and rear strut bars, Addco front and rear sway bars, Tein Coilover system
BRAKES: Stillen brake pads, Stillen cross drilled rotors, 3sx SS brake lines,
TRANNY: Complete Rebuild by IPT, ElectroMatic Shift Box, 3200 stall Torque Converter, IPT valve body w/shift kit, alto end clutch, Kormex LSD
EXTERIOR: 17x8 Chrome Eagle 077s wrapped in Toyo Proxes, clear corner front turn signals
IronFish is offline   Reply With Quote
Old 06-26-2008, 09:21 AM   #7 (permalink)
Pearl White 3kGT
Jancas02's Avatar
Terry got the mounts! Thanks!
My mechanic said he will charge me $200 to install the mounts is that a good deal?
Old 06-26-2008, 09:32 AM   #8 (permalink)
Supporting Vendor
Maximal's Avatar
It's a piece of cake on an NA. Go buy a socket set and a long 3' extension and you'll be able to crack it out in an afternoon. Only tricky part is getting them to line up correctly and that just takes some patience.
Old 06-27-2008, 03:29 PM   #9 (permalink)
Pearl White 3kGT
Jancas02's Avatar
Alright so the install wasn't that bad. The side mounts came out fairly quick and the front mount was a little pain in the ass because my car is cali spec and the precat was in the way of two bolts. The pin on the front mount had to be cut because the pre cat was in the way and didnt allow enough room to pull it out, so instead of taking the precat out we just cut the bolt and replaced it. The rear was easy we just had to take the heat shield in order to pull the stock mount out. The install was done in 5 hours which included a trip to lowes to get a new bolt and washer, probaly could of done it quicker but we where taking our time cleaning the bolts and what not. Also we didnt have issues with things lining up we just installed the sides first and the front and rear just installed without any issues.
As far as my personal feelings on the mounts. I like how they felt on acceleration but they might cause more vibrations than I desired. Scott agree that they vibrated my car way more than his stealth TT. My guess is that its because I have an auto trans. When I'm idling it shakes like crazy and creates this muffled sound in the cabin but when I put it in neutral its less harsh, almost feels like his TT. Also theres a whinning noise during acceleration and it also sounds like I have an exhaust (Im 100% stock). The mounts are great well built, but I was just not expecting all these extra noises and vibrations(assume it was going to be like the TT that I test drove with solids)so Im no too happy but not too sad...lol I'll probaly just get use to it.
Old 06-27-2008, 06:43 PM   #10 (permalink)
Damage Control
Stealthee's Avatar
Drives: 1994 Stealth
Trader Rating: (77)
Bump your idle up a touch. I guarantee it will cure some of your issues.
I've had Terry's solids for almost a year now. Still love them.
