Go Back   3000GT/Stealth International Message Center > Supporting Vendors > Maximal Performance
Old 03-12-2008, 09:03 AM   #1 (permalink)
Mean Green's Avatar
Mean Green is an unknown quantity at this point
Mitsubishi Solid Mounts
I just ordered the solid mounts the other day and would like to know if anyone has any tips or tricks with installation so that when I get them in I wont have to tie up any loose ends further down the road.
-Chris
1993 Panama Green VR4 - Cream interior - Black TE-37's with Nitto NT555's - XTD Stage 4 clutch - Kenwood headunit - KYB GR2's - 2 Infinity Baselinks - Infinity door and rear speakers - Dejon "Y" Pipe - Blitz BOV - Optima Red Top - Maximal Solid Mounts - Brass shift bushings - 14psi - restoring the car one mod at a time.
**Also parting out a 91 TT with 57,XXX original miles with blown motor. Pm me for details**
Mean Green is offline   Reply With Quote
Old 03-12-2008, 12:44 PM   #2 (permalink)
Supporting Vendor
Maximal's Avatar
Drives: '91 Stealth "ES"
Trader Rating: (183)
Maximal Level 7Maximal Level 7Maximal Level 7Maximal Level 7Maximal Level 7Maximal Level 7Maximal Level 7Maximal Level 7Maximal Level 7Maximal Level 7Maximal Level 7
Default Re: Solid Mounts
Install is pretty straight forward as it's just a remove the old one put the solids in type thing. On a TT it can be difficult to get the rear stock mount out as the turbo is in the way. A lot of people have to loosen the turbo up to get it out...the solid one being smaller will slide right in though.
Don't tighten anything down until you get all the mounts in either. With them being solid there is less give when installing them and it will make it harder to get everything to line up. A jack underneath the bellhousing can help move the engine around and get it to line up with everything.
Once everything is in and all the bolts are in place loosely tighten everything down and you're good to go.
Terry
Maximal is offline   Reply With Quote
