Go Back   3000GT/Stealth International Message Center > Supporting Vendors > Maximal Performance
Old 05-08-2008, 06:23 PM   #1 (permalink)
Paid Member
Drives: 91 GTO SR
kylejw is an unknown quantity at this point
Default Sigh.... ANOTHER solid mount question...
I realize there are like 10 solid mount posts per week, but I looked through all of them and didn't see anyone asking my question. I'm pretty sure I will see when I do the install this weekend, but what are the 3 metal cylinders that came in the package for? I just don't want to start tearing my car apart only to be confused what they're for.
Thanks
kylejw is offline   Reply With Quote
Old 05-09-2008, 05:13 AM   #2 (permalink)
Kx125kid's Avatar
Drives: 1993 VR-4
Trader Rating: (16)
Kx125kid is an unknown quantity at this point
Default Re: Sigh.... ANOTHER solid mount question...
there spacers that go with the driver side mount they go on the 3 vertical studs between the mount and the nuts
Kx
3000GT STEALTH CLUB of NEW YORK
1993 MItsubishi 3000GT VR-4
1991 Dodge Stealth R/T
Http://www.3SNY.com
Kx125kid is offline   Reply With Quote
Old 05-09-2008, 07:37 AM   #3 (permalink)
Paid Member
Drives: 91 GTO SR
Awesome, thank you
Old 05-09-2008, 05:14 PM   #4 (permalink)
Kx125kid's Avatar
Drives: 1993 VR-4
Trader Rating: (16)
no problem
Kx
Old 05-12-2008, 05:08 PM   #5 (permalink)
Paid Member
Drives: 91 GTO SR
So I got them all installed, pretty damn easy by comparison to other things I've done... Only problem I had was the front mount falling on my face
I'm N/A so the rear mount actually ended up being the easiest with the help of my ratchet and 5 extensions
I damn love these things though, not just because of the badass feeling my car now has... but because they seem to have helped my transmission shifting. Can someone explain this? I mean it makes sense if the shifter was solidly attached to the tranny, but since there's cables I don't see why? Basically the transmission is the same notchiness as always, but the gears seem to slide in with more confidence.... hard to explain, but it's the same feeling people describe when they install solid shifter bushings.
Anyways, thanks Terry you rock. I'm now sporting solids, adjustable control arms, and theres a test pipe in a box in my room
Old 05-15-2008, 06:02 PM   #6 (permalink)
Supporting Vendor
Maximal's Avatar
Drives: '91 Stealth "ES"
Trader Rating: (180)
Maximal Level 2Maximal Level 2Maximal Level 2
Awesome...glad the install went well and you're happy with them.
Maximal is offline   Reply With Quote
