#31 (permalink) |
ZoomZoom?
Glad it got worked out, +1 that he should contact the BBB to withdraw his complaint.
97 Black 3000GT VR4
New stuff not installed, DR Stage 3 heads, IPS stage 3 shortblock with Pauter forged rods, CP pistons and more. ![]() Fast Stuff: IPS Stage 3 block with Pauter forged rods, DR Stage 3 heads with High Rev Valve Spring Kit and Titanium Retainers AND Rays head lift fix , IPS EVO 3 kit with turbo porting and Ceramic coating, IPS 272 Cams, IPS Fuel rails, fuel rail loop, Aeromotive A1000 FPR, PET 780CC Injectors, South Bend Stage 4 FE clutch, IPS NO-MAF intake pipes, 2 AEM Dry flow filters, AEM EMS, AEM map sensor, AEM IAT sensor, IPS intercooler kit w 750hp Spearco core, RPS flyweel, 2 HKS BOV, MSD 8.5MM wires, MSD Coils, Stillen downpipe, 3 inch custom exhaust W Apexi N1 tip, 3sx aluminum crank pulley, Walbro fuel pump, hotwire fuel pump kit, solid motor mounts, EGR block off Kit, red top Optimia battery, Flexalite twin 12" fans, Koyo aluminum radiator, polished front/back valve covers, polished plenum, polished throttle body, IPS polished coolant pipes, manifold / downpipe turbo hot side polished ceramic coating, Turbo intake side polished. Interior&Audio System: Corbeau CR1 Seats In Black, Corbeau Black 3Point Harnesses, Apexi AVC-R Boost Controller, Apexi Turbo Timer, Defi-Link Meter BF Gauges In White, Boost/Psi, Water Temperature, Oil Presure, AEM Wideband, SmokingVR4 Duel 10Inch Sub Box, 2 PPI 1000 Watts RMS Subs, Alpine IVA-D901 In Dash Flip Out Screen With Nav. Suspension: KYB Struts, Tien S. Tech Springs, 19X9 SSR D5R in bronze with a polished lip, 245/35/19 Toyo Proxes T1R, Proracer Racing Lug Nuts in red, Rear Strut Bar. Body: Viper alarm system, 8,000k HID. www.ipsmotorsports.net www.dynamicracing.com www.kormextrans.com |
