#12 (permalink) | |
Forum user
Good luck with your car and be sure that all is correct before leaving the shop becuse it will be like pulling teeth to get anything does happen.
1994 Mitsu 3000gt vr4 only 8,700 miles, Evo3 16g turbo's with tdo5 manifolds and down pipes, 8:1 wiseco forged pistons, pauter forged rods, 780 injectors, aem engine management, billet fuel rail, spec 3 plus clutch and pressure plate, Spec flywheel, aem filter, aem fuel pressure regulator, front mount intercooler, greedy profec boost controller, hks ignition amplifier, aftermarket oil cooler. alcohol injection.
#13 (permalink) | |
Forum user
Instead of going with a stroker I would give my opinion to only build the bottom end to be able to take more boost and turn up the boost. |
#14 (permalink) | |
Supporting Vendor (Gold)
Jeff |
#15 (permalink) |
This stroker is a 3.4 with stock bore right? Overbore would yeild 3.5x litres?
His - Red 93 RT/tt
Mods: Hallman's MBC @ 16 psi, turbo XS type H BOV, stillen dp, custom exhaust, Spec stage 2 clutch, RPS FW, 3sx lightweight crank pulley, BCP7RES-11 @ .030 gap, autometer gauges, slightly gutted mas, dsm SMIC's, ACPT 1 piece CFDS, Tein S springs, pte 580 inj's, safc neo/SITC, 13t's, hotwired walbro, maximal performance solid motor mounts, DR plenum spacer. Hers - BPU Green 94 vr4 |
#16 (permalink) |
sooo......rock105 is going to troll every thread forever and give sage advice. sounds great! Sorry, i'd rather keep my engine intact, run lower boost for the same power than beat the piss out of it and blow an engine...but what would I knwo...I haven't trashed 2 engines....
Anybody know where the Gutenaytor valve is located? I think mine's bad.
92 Stealth tt: Black on Black
Mods: IPS EVO 3 16G turbos.manifolds, Slotted and drilled rotors, Fittipaldi Force 18" Rims w/ Kuhmo Exsta Supra shoes, IPS Intake Pipes and TD05 FMIC, SS Oil feed lines, Fidanza Cam Gears, 3sx Light Weight Crank Pulley, IPS SS radiator pipes (cause like a racoon, i'm attracted to shiny objects), 3sx upper poly motor mount, TurboXS BOV, Some kinda big ass air filter, 550 cc injectors, super secret ss downpipe, Walbro 255 Fuel pump (Hotwired), Custom Timing belt cover (me, a dremel, and a wife saying "wtf! Do that in the Garage"), Apexi SAFC2, HKS EVC 5, AEM wideband o2, Blitz Turbo Timer, whatever boost gauge IPS Jeff gave me for free, nice spark plug wires and crap like that, and the all black interior conversion. "These damn cars are Japan's revenge for WWII" Custom trim for your electronics or gauges..Dash Vent gauge pods, DIN gauge pods, AFC's, Profec B's...you name it, I can make trim for it. Link:http://www.3si.org/forum/f4/custom-e...s-sale-433953/ |
#17 (permalink) | |
Forum user
