#41 (permalink) |
Supporting Vendor
Here are a few of the quick shots Mike took! Sorry you could not get a hold of us!
IPS Motorsports
BWright@ipsmotorsports.net 614-444-5884 AEM EMS Factory Certified Tuner -Brandon |
#42 (permalink) |
ZoomZoom?
Wow, tell mike I said thanks for the pic. Any ideal on when the motor will be dropped into the car? Or the price for the exhaust?
Thanks Jerry.
97 Black 3000GT VR4
New stuff not installed, DR Stage 3 heads, IPS stage 3 shortblock with Pauter forged rods, CP pistons and more. ![]() Fast Stuff: IPS Stage 3 block with Pauter forged rods, DR Stage 3 heads with High Rev Valve Spring Kit and Titanium Retainers AND Rays head lift fix , IPS EVO 3 kit with turbo porting and Ceramic coating, IPS 272 Cams, IPS Fuel rails, fuel rail loop, Aeromotive A1000 FPR, PET 780CC Injectors, South Bend Stage 4 FE clutch, IPS NO-MAF intake pipes, 2 AEM Dry flow filters, AEM EMS, AEM map sensor, AEM IAT sensor, IPS intercooler kit w 750hp Spearco core, RPS flyweel, 2 HKS BOV, MSD 8.5MM wires, MSD Coils, Stillen downpipe, 3 inch custom exhaust W Apexi N1 tip, 3sx aluminum crank pulley, Walbro fuel pump, hotwire fuel pump kit, solid motor mounts, EGR block off Kit, red top Optimia battery, Flexalite twin 12" fans, Koyo aluminum radiator, polished front/back valve covers, polished plenum, polished throttle body, IPS polished coolant pipes, manifold / downpipe turbo hot side polished ceramic coating, Turbo intake side polished. Interior&Audio System: Corbeau CR1 Seats In Black, Corbeau Black 3Point Harnesses, Apexi AVC-R Boost Controller, Apexi Turbo Timer, Defi-Link Meter BF Gauges In White, Boost/Psi, Water Temperature, Oil Presure, AEM Wideband, SmokingVR4 Duel 10Inch Sub Box, 2 PPI 1000 Watts RMS Subs, Alpine IVA-D901 In Dash Flip Out Screen With Nav. Suspension: KYB Struts, Tien S. Tech Springs, 19X9 SSR D5R in bronze with a polished lip, 245/35/19 Toyo Proxes T1R, Proracer Racing Lug Nuts in red, Rear Strut Bar. Body: Viper alarm system, 8,000k HID. www.ipsmotorsports.net www.dynamicracing.com www.kormextrans.com |
#44 (permalink) |
luvs spyda gal
lemme get this straight, u send this car out on january 31 and it is still not finished? Did i miss something in this post?
![]() Title Sponsor ![]() 6TH ANNUAL TEXAS 3S GATHERING, NOVEMBER 14-16, 2008 FORT WORTH |
#45 (permalink) |
Yes, you did.
92 Stealth tt: Black on Black
Mods: IPS EVO 3 16G turbos.manifolds, Slotted and drilled rotors, Fittipaldi Force 18" Rims w/ Kuhmo Exsta Supra shoes, IPS Intake Pipes and TD05 FMIC, SS Oil feed lines, Fidanza Cam Gears, 3sx Light Weight Crank Pulley, IPS SS radiator pipes (cause like a racoon, i'm attracted to shiny objects), 3sx upper poly motor mount, TurboXS BOV, Some kinda big ass air filter, 550 cc injectors, super secret ss downpipe, Walbro 255 Fuel pump (Hotwired), Custom Timing belt cover (me, a dremel, and a wife saying "wtf! Do that in the Garage"), Apexi SAFC2, HKS EVC 5, AEM wideband o2, Blitz Turbo Timer, whatever boost gauge IPS Jeff gave me for free, nice spark plug wires and crap like that, and the all black interior conversion. "These damn cars are Japan's revenge for WWII" Custom trim for your electronics or gauges..Dash Vent gauge pods, DIN gauge pods, AFC's, Profec B's...you name it, I can make trim for it. Link:http://www.3si.org/forum/f4/custom-e...s-sale-433953/ |
#46 (permalink) | |
ZoomZoom?
Thanks Jeremy, I hope she is going to run as well as she looks.
Yepo, it took me a long time to figure out what I wanted to do about the head lifting issue that some cars get. Once I figured it out, the place that got my heads took about a month and a half. ![]() |
#49 (permalink) |
That's looking purty.
You're setup is almost identical to mine. You will not be disappointed. What fuel setup did you decide to go with? My pump went bad there and I had it replaced with the Denso. That was good enough to support my power on the street but after awhile I got curious and put in tome race gas. The turbos really open up past the 18psi range. Didn't think there would be such a difference. I should of listened to Mike and bought the HKS DLI and maybe invested more into a better fuel pump setup. I would get blow out at 19-20psi. I bought and installed the HKS DLI and that got rid of all the spark issues (atleast up to 23psi, that's where I found my fuel limit). I'm installing a boost-a-pump today. That should band-aid things enough for now to reach 24-25psi hopefully. Jason
1995 3000GT VR-4 A bunch of useless mods later gets me 502awhp @ 14psi. For Sale. http://www.3si.org/forum/f10/1995-30...lorida-433269/
1998 3000GT VR-4 15Gs w/ supporting mods...SOLD!!! RIP ![]() |
#50 (permalink) | |
ZoomZoom?
