Go Back   3000GT/Stealth International Message Center > Supporting Vendors > Deft Racing
Old 07-23-2007, 02:43 PM   #1 (permalink)
netmechanic's Avatar
Drives: 93 93 98
netmechanic is an unknown quantity at this point
Default 52mm Prosport Peak/Hold Boost Guage
Got my boost guage installed and had a question regarding the peak warning function. Do you have to set that limit everytime you start the car or does it retain the setting until you change it?
1993 VR4
Exactly Identical 169
Mechanically Identical 895
Same Model+Option Package 940
Same Model+Build Date 140
#916
netmechanic is offline
Old 07-23-2007, 05:51 PM   #2 (permalink)
Drives: '95 3000GT Spyder TT
Trader Rating: (101)
deft spyder Level 7deft spyder Level 7deft spyder Level 7deft spyder Level 7deft spyder Level 7deft spyder Level 7deft spyder Level 7deft spyder Level 7deft spyder Level 7deft spyder Level 7deft spyder Level 7
Default Re: 52mm Prosport Peak/Hold Boost Guage
It retains it
DeftRacing.com | 3000GTSpyder.com | Wallpaper Pics | My Cardomain
RTericTT: bill.. your car doesnt launch. it stays in the same place as the earth rotates underneath it.
I have mad power to my wheel.
DigiiManDan3KGT: shouldnt that hood be NWS?
deft spyder is offline
Old 07-26-2007, 07:56 PM   #3 (permalink)
Drives: 93 93 98
Am I missing a key combination or something? Mine doesnt seem to do it. I hold the button down for approx 5 sec. then release and it goes to about 20 psi. Then I hold it down again and it starts moving, when it gets to 13 I release it and wait for it to go back into default mode. Works fine till I turn the car off then I have to reset it again the next time.
Old 07-31-2007, 11:17 AM   #4 (permalink)
I am McLovin!
O_ROD's Avatar
Drives: 1991 RT/TT
O_ROD Level 7O_ROD Level 7O_ROD Level 7O_ROD Level 7O_ROD Level 7O_ROD Level 7O_ROD Level 7O_ROD Level 7O_ROD Level 7O_ROD Level 7
Do you have the red wire hooked up to constant 12 volt/battery (connector C59, white wire) or to an ACC switched 12 volt?
Sounds like the gauge isn't getting any battery when the car is off, which it's supposed to to keep it's memory settings.
O_ROD is online now
