#31 (permalink) | |
Supporting Vendor
Yes you can re-install that, thats why we made it that size at the top.
![]() 93 RT TT 8.74@168.5mph @3600ft Worlds Quickest and Fastest 3000gt/stealth 95 3000GT VR-4 10.56@136mph- 714 AWHP & 607 AWTQ (dr-900's) (sold) 92 Stealth RT TT 10.69@133.45mph @3600ft (dr-800's) (sold) 95 RT TT 10.88@129.1mph @3600ft (sold) 95 RT TT 11.9@118mph (stock injectors) 2004 F350 Harley 14.4@90mph at 3600ft 2007 Charger SRT-8 12.3@120mph@3600ft, Heads/cam, NOS 548 RWHP 2001 Dodge Viper GTS Heads/cam 612 rwhp & 619 rwtq There are 2 ways to make a car fast. #1 use the Right combo of parts #2 Throw so much money at it that the car has no choice but to be fast. I choose #1 Click for US 3S Fastest ET list Better to be a racer for a moment then a spectator for a lifetime "Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education alone will not; the world is full of educated derelict."— John Calvin Coolidge |
#32 (permalink) | |
Forest Gump
I don't think the alumninum subframe bushings are going to add much vibration if you keep the stock diff mounts, shock mounts, and trailing arm mounts. There is a lot of rubber with them and I think they will dampen a lot of vibration. I think these mounts will really stiffer up the rear chassis, but the max benefit would to be also to add poly bushings at all the stock points.
![]() Power: DSM 13G/DR650 Combo, EVO 560cc injectors, SAFC I, K&N, Ebay Downpipe, ATR Dual Catback, no cats, DN Y-Pipe, HKS SSQV, HKS EVC 5 at 14.5PSI, Walbro 255 with AN Bulkhead 8.07 @ 85.55 1/8th mile 1.84 60FT Suspension: KYB GR-2 - Tein S-Techs, Crossdrilled/slotted rotors, AWS Delete Drivetrain: RPS Street Max, M.W. 300m O/S, Seattle F&R Poly Mounts, EK2 ExoCage Etc: Roller Bearing Short Shifter Smokinvr-4 Corner box, 10" Rockford Fosgate Punch sub, Eclipse Headunit Leatherseats.com Charcoal/Dove Grey Interior, 99 front end/lights/wing/sideskirts/doorcapsm Scanmaster 3 Maintenance New VSS, all 60K stuff, new 1st,2nd, 3rd syncro, trans seals, oil pump, rod and main bearings. Mobile 1 10w40, Redline MTL in trans, 85w90 Coastal GL5 in transfer case and rear |
