#21 (permalink) |
Captain Slow
Nice! If anybody has these installed on a autocross/road course car please post up if you noticed some handling benefit. I was actually thinking of making these myself. Smaller slip angles = good.
Matt-would you sell just the fronts of the rear subframe by any chance? I think just adding a front set would really help the car oversteer. Also, how bad has cabin vibration increased with these installed? |
#22 (permalink) |
Supporting Vendor
I have not made any front ones yet. I welded my fronts solid quite a wile ago. But making a nice set of front solid bushings is on my "to do" list.
![]() 93 RT TT 8.74@168.5mph @3600ft Worlds Quickest and Fastest 3000gt/stealth 95 3000GT VR-4 10.56@136mph- 714 AWHP & 607 AWTQ (dr-900's) (sold) 92 Stealth RT TT 10.69@133.45mph @3600ft (dr-800's) (sold) 95 RT TT 10.88@129.1mph @3600ft (sold) 95 RT TT 11.9@118mph (stock injectors) 2004 F350 Harley 14.4@90mph at 3600ft 2007 Charger SRT-8 12.3@120mph@3600ft, Heads/cam, NOS 548 RWHP 2001 Dodge Viper GTS Heads/cam 612 rwhp & 619 rwtq There are 2 ways to make a car fast. #1 use the Right combo of parts #2 Throw so much money at it that the car has no choice but to be fast. I choose #1 Click for US 3S Fastest ET list Better to be a racer for a moment then a spectator for a lifetime "Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education alone will not; the world is full of educated derelict."— John Calvin Coolidge |
#23 (permalink) |
ok quick question on the bushings. why dont you make the upper mounting point flat on the front upper bushings instead of having the 1/4 stick up that could crush?
i was looking at that design and the front uppers kinda seem a little unsafe since t-6061 would be weaker than steel in that area. Last edited by SnakeSkinner : 08-20-2008 at 08:19 AM. |
#24 (permalink) | |
I ♥ JDM Hoes Too!
I have crazy wheel hop in front, I wish you had these for the front.
#25 (permalink) | |
Supporting Vendor
6060T6 is alot stronger then you think, cars like Corvettes use Cast aluminum for nearly all of there suspension components that's is ALOT weaker then 6061. It's holding up fine in a 1000+hp 8 second car, and it fore sure stronger then the rubber it replaces. |
#27 (permalink) | |
Forest Gump
As far as I can tell all the rubber ring does is keep dirt out.
![]() Power: DSM 13G/DR650 Combo, EVO 560cc injectors, SAFC I, K&N, Ebay Downpipe, ATR Dual Catback, no cats, DN Y-Pipe, HKS SSQV, HKS EVC 5 at 14.5PSI, Walbro 255 with AN Bulkhead 8.07 @ 85.55 1/8th mile 1.84 60FT Suspension: KYB GR-2 - Tein S-Techs, Crossdrilled/slotted rotors, AWS Delete Drivetrain: RPS Street Max, M.W. 300m O/S, Seattle F&R Poly Mounts, EK2 ExoCage Etc: Roller Bearing Short Shifter Smokinvr-4 Corner box, 10" Rockford Fosgate Punch sub, Eclipse Headunit Leatherseats.com Charcoal/Dove Grey Interior, 99 front end/lights/wing/sideskirts/doorcapsm Scanmaster 3 Maintenance New VSS, all 60K stuff, new 1st,2nd, 3rd syncro, trans seals, oil pump, rod and main bearings. Mobile 1 10w40, Redline MTL in trans, 85w90 Coastal GL5 in transfer case and rear |
#28 (permalink) |
resident evil
Thats true but having a ring of rubber has the abilty to dampen because certain frequencies are absorbed by the different material in contact. Its like putting your hand on a noisy box fan and changing the pitch of the sound
#30 (permalink) |
resident evil
your saying on your car, you can take that rubber puck and spin it around without it being squashed between the car and subframe? What I am saying is that NVH as transmitted into the floor thru attached connections can be quelled by the simple contact of two materials. You know, like spraying rubber on a metal panel. The whole metal bushing comes to a small nub which is in direct contact with the upper frame mounting point, but its surrounded by a thick rubber washer which has inherent frequency damping properties. Its like a continuous copper pipe which vibrates when water throttles thru it. If you wrap the pipe, its not the thickness of the material wrap that blocks sound, its the ability of a material in contact with another to alter the natural frequency in it that normally lets it produce a standing wave. Its physics, but I am just a EE, and its been over a decade since I wa a Freshman.
