#11 (permalink) |
3SX FTL
I really wish you had these when I had my rear subframe off the car doing the AWS delete.
Did you ever do an AWS delete on your white car?
1993 "dove gray metallic" Stealth R/T Turbo
Car is FOR SALE - 12.5k - PM me 6-speed transmission conversion, 2g front brake conversion, AWS delete with SK VR4 radius rod mod(BIG thanks to Joe G.'s website! )Kormex front LSD, Port matched Upper Intake -> Ported and port matched lower intake -> DR stage ]l[ heads, DR650Rs, ARC2 w/ 87mm MAF $ ARM1, Denso 255 hotwired, 720cc inj. fed by a Home made dual feed system for $800 w/ single hotwired intank pump, DR Weldin DSM sidemounts, DNP Y-pipe, 3SX poly motormounts, Vac hose reduction,, Chipped stock ECU -9000rpm rev limiter, Blitz DSBC in stock tape deck, VDO boost gauge, GREDDY EGT gauge, ATR downpipe - Borla catback w/ custom 3" flanges (3" all the way through), RPS flywheel, RPS clutch, Tein S-tech springs, Saner front and rear sway bars, Cusco adj. rear sway bar, 3SX adj. upper control arms, STEDEBANI front poly suspension bushings, 1995 VR4 front brake caliper conversion, Stillen Rotors,SCE extended wheel studs WELDED IN - THANKS SUPERCAR ENGINEERING! in NEW OEM hubs, Porterfield R4S pads, SILKOLENE brake fluid, Pro N1s w/ S03 Potenzas, 17x9 FNCRO1NFC01RN 5Zigens w/ NITTO 555Rs, POR15 on everything and a ton of new stock stuff... Car is FOR SALE - 12.5k - PM me |
#14 (permalink) |
Supporting Vendor
bushings installed
![]() 93 RT TT 8.74@168.5mph @3600ft Worlds Quickest and Fastest 3000gt/stealth 95 3000GT VR-4 10.56@136mph- 714 AWHP & 607 AWTQ (dr-900's) (sold) 92 Stealth RT TT 10.69@133.45mph @3600ft (dr-800's) (sold) 95 RT TT 10.88@129.1mph @3600ft (sold) 95 RT TT 11.9@118mph (stock injectors) 2004 F350 Harley 14.4@90mph at 3600ft 2007 Charger SRT-8 12.3@120mph@3600ft, Heads/cam, NOS 548 RWHP 2001 Dodge Viper GTS Heads/cam 612 rwhp & 619 rwtq There are 2 ways to make a car fast. #1 use the Right combo of parts #2 Throw so much money at it that the car has no choice but to be fast. I choose #1 Click for US 3S Fastest ET list Better to be a racer for a moment then a spectator for a lifetime "Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education alone will not; the world is full of educated derelict."— John Calvin Coolidge |
#16 (permalink) | |
Supporting Vendor
#18 (permalink) |
Woot!
Are you going to make some for the front?
We also need to find a way to make the bushings in the front control arm. As these cars get older having to buy a new arm is crazy... These look great! Have you ran down the track with them in? I am curious if you really can tell a difference.
1995 Dodge Stealth R/T TT, Dark Green ext, Dark Int, 1 of 20 available to the US.
Mods: 13T/E3 16G turbos, FMIC 3" in/out, Spec Stage 3 clutch, RPS Billet Aluminum Flywheel, Gutted front and rear precat, test pipe, MSD 8.5mm SC Wires, 3rd Gen lifters, EGR Delete, 3SX EGR Block off plates, Blitz DD BOV, Hotwire Walbro 255 Fuel pump, Map ECU, Dual Pillar pod w/ AEM Wideband and AEM Tru Boost, Halo Hybrid Data logger, Supercar Engineering 1/2 billet aluminum Shift fork, fresh 1/2/3 friction rings, custom solid engine mounts, 3" Straight pipe exhaust single out. Looks: DCC Conversion, White face glow gauges. Sound: Infinity components up front, infinity 10" sub in back with Smokin' VR4 corner sub box, Pioneer HU. Myspace Must go faster project underway. E85 powered Front E3 16G installed, next is the rear one! Equal length headers custom made. |
#19 (permalink) | |
Warning: I'm an asshole
Matt - Nice bushings! I was just thinking the other day it would be nice to see some solid bushing sets out there. Any chance you'll be making some more for the rear diff & front suspension also?
1992 3000GT VR4
![]() ![]() --Completely rebuilt 5/06-4/07. Everything new. For a list see: http://www.3si.org/forum/showthread.php?t=372579 --First time on dyno: 364AWHP@16psi with a 10.3AFR (now tuned at 11.4-11.6 with timing control, time for another dyno run soon) --Mods: DR Stage I heads, 3rd gen lifters, TD04L 13Gs, DSM SMICs, PTE 550s, Apexi SAFC, Apexi SITC, Walbro FP, IPO hotwire, Robbeck adapter & AEM FPR, 3SX underhood fuel gauge, 3SX fuel rail loop, DN Y-pipe, HKS SSQ BOV, K&N FIPK, Greddy Profec Spec S, AEM WB02, Autometer C2 boost, egt, oil press & water temp gauges, MSD wires, NGK BCP7ES's, TEIN FLEX coilovers, Maximal performance control arms, solid engine mounts & powdercoating, RPS Streetmax Clutch, RPS Flywheel, NBT Tranny (cryotreated OS, shift forks & rails), updated speedo gear, solid shifter bushings, full 2nd gen brake conversion, 3SX SS brake & clutch lines, Carbotech Panther+ pads in the front & Bob Cats in the rear, 3SX clutch vac delete, EGR delete, vac reduction, Ebay DP, gutted pre cats, Bronze FN01RCs 5Zigen 18x8.5 + 30 offset, Pirelli P-Zeros, engine dress up kit, Bigtyla ground wire kit. --Daily Driver: 2000 Malibu, 6cyl, auto |
