Go Back   3000GT/Stealth International Message Center > Supporting Vendors > Dynamic Racing
Old 08-22-2008, 06:09 PM   #31 (permalink)
Supporting Vendor
SnakeSkinner's Avatar
Trader Rating: (32)
SnakeSkinner Level 7SnakeSkinner Level 7SnakeSkinner Level 7SnakeSkinner Level 7SnakeSkinner Level 7SnakeSkinner Level 7SnakeSkinner Level 7SnakeSkinner Level 7SnakeSkinner Level 7SnakeSkinner Level 7SnakeSkinner Level 7
Default Re: Solid rear subframe bushings
Originally Posted by wraith View Post
your saying on your car, you can take that rubber puck and spin it around without it being squashed between the car and subframe? What I am saying is that NVH as transmitted into the floor thru attached connections can be quelled by the simple contact of two materials. You know, like spraying rubber on a metal panel. The whole metal bushing comes to a small nub which is in direct contact with the upper frame mounting point, but its surrounded by a thick rubber washer which has inherent frequency damping properties. Its like a continuous copper pipe which vibrates when water throttles thru it. If you wrap the pipe, its not the thickness of the material wrap that blocks sound, its the ability of a material in contact with another to alter the natural frequency in it that normally lets it produce a standing wave. Its physics, but I am just a EE, and its been over a decade since I wa a Freshman.
Yes you can re-install that, thats why we made it that size at the top.
93 RT TT 8.74@168.5mph @3600ft Worlds Quickest and Fastest 3000gt/stealth
95 3000GT VR-4 10.56@136mph- 714 AWHP & 607 AWTQ (dr-900's) (sold)
92 Stealth RT TT 10.69@133.45mph @3600ft (dr-800's) (sold)
95 RT TT 10.88@129.1mph @3600ft (sold)
95 RT TT 11.9@118mph (stock injectors)
2004 F350 Harley 14.4@90mph at 3600ft
2007 Charger SRT-8 12.3@120mph@3600ft, Heads/cam, NOS 548 RWHP
2001 Dodge Viper GTS Heads/cam 612 rwhp & 619 rwtq
There are 2 ways to make a car fast.
#1 use the Right combo of parts
#2 Throw so much money at it that the car has no choice but to be fast.
I choose #1
Click for US 3S Fastest ET list
Better to be a racer for a moment then a spectator for a lifetime
"Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education alone will not; the world is full of educated derelict."— John Calvin Coolidge
SnakeSkinner is offline   Reply With Quote
Old 08-22-2008, 06:17 PM   #32 (permalink)
Forest Gump
cbehnken's Avatar
Drives: 1992 Stealth TT
cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7
No, you can't spin the rubber washer, but I doubt it has any of the dampening functions that you hope.
I don't think the alumninum subframe bushings are going to add much vibration if you keep the stock diff mounts, shock mounts, and trailing arm mounts. There is a lot of rubber with them and I think they will dampen a lot of vibration.
I think these mounts will really stiffer up the rear chassis, but the max benefit would to be also to add poly bushings at all the stock points.
Power: DSM 13G/DR650 Combo, EVO 560cc injectors, SAFC I, K&N, Ebay Downpipe, ATR Dual Catback,
no cats, DN Y-Pipe, HKS SSQV, HKS EVC 5 at 14.5PSI, Walbro 255 with AN Bulkhead 8.07 @ 85.55 1/8th mile 1.84 60FT
Suspension: KYB GR-2 - Tein S-Techs, Crossdrilled/slotted rotors, AWS Delete
Drivetrain: RPS Street Max, M.W. 300m O/S, Seattle F&R Poly Mounts, EK2 ExoCage
Etc: Roller Bearing Short Shifter Smokinvr-4 Corner box, 10" Rockford Fosgate Punch sub, Eclipse Headunit
Leatherseats.com Charcoal/Dove Grey Interior, 99 front end/lights/wing/sideskirts/doorcapsm Scanmaster 3
Maintenance New VSS, all 60K stuff, new 1st,2nd, 3rd syncro, trans seals, oil pump, rod and main bearings.
Mobile 1 10w40, Redline MTL in trans, 85w90 Coastal GL5 in transfer case and rear
cbehnken is offline   Reply With Quote
