Go Back   3000GT/Stealth International Message Center > Supporting Vendors > Dynamic Racing
Old 10-01-2008, 10:50 AM   #1 (permalink)
97SLeeper's Avatar
Drives: 97 sl
97SLeeper is an unknown quantity at this point
Default running 16t safely
sup im plannin on gettin 16t turbos for my car when im done with my swap soo that means im trying to figure out how to run these turbos safely. my goals for this car is to have it dd(well whenever i wanna drive it, cause i do have a beater) at 400 to 450hp those numbers i picked because at that high a hp i can run with anything thats around here. i wanna get this right the first time so any advice an expierience is appreciated its a 97 sl soon to be fwdtt. thanks
97SLeeper is offline   Reply With Quote
Old 10-01-2008, 10:52 AM   #2 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (66)
Default Re: running 16t safely
Hotwired Walbro 341 (255lph) fuel pump.
450cc or 550cc injectors.
AEM or Aeromotive AFPR.
SAFCII etc piggyback fuel controller.
Datalogger.
Wideband o2 sensor, boost gauge.
94 VR-4: 11.8 @ 116, 17psi, pump, 13Ts Nov 2008 ROTM
Old 10-01-2008, 11:19 AM   #3 (permalink)
97SLeeper's Avatar
Drives: 97 sl
wow all in a nutshell huh. why would u give a choice between 450cc or 550cc injectors, are those soley my choice? and is this what everyone is running thats has my setup an hp in mind.
Old 10-01-2008, 11:20 AM   #4 (permalink)
Here for the tuna.
lawdogg's Avatar
Trader Rating: (66)
Here you go, read this:
Tech: My take on injectors vs. timing control vs. HP with the stock ECU
Ok sorry DR, here ends my hijack.
Old 10-01-2008, 05:38 PM   #5 (permalink)
Supporting Vendor
SnakeSkinner's Avatar
Trader Rating: (32)
SnakeSkinner Level 7SnakeSkinner Level 7SnakeSkinner Level 7SnakeSkinner Level 7SnakeSkinner Level 7SnakeSkinner Level 7SnakeSkinner Level 7SnakeSkinner Level 7SnakeSkinner Level 7SnakeSkinner Level 7SnakeSkinner Level 7
Depends on how much boost and how much power you want to make. I am running these turbos on my 95 RT TT with stock injectors at 15psi of boost everyday and the car ran 11.9@118mph.
mods I have on that car
DR16T's
Boost controler
Denso pump
Air intake
Down pipe
Exhaust
Clutch/flywheel
UD pulley
Now to run more boost/make more power
Larger injectors 450's or 550's would work the 450's would be good up to about 450 whp.
Some kind of piggy back fuel control
a A/F guage
93 RT TT 8.74@168.5mph @3600ft Worlds Quickest and Fastest 3000gt/stealth
95 3000GT VR-4 10.56@136mph- 714 AWHP & 607 AWTQ (dr-900's) (sold)
92 Stealth RT TT 10.69@133.45mph @3600ft (dr-800's) (sold)
95 RT TT 10.88@129.1mph @3600ft (sold)
95 RT TT 11.9@118mph (stock injectors)
2004 F350 Harley 14.4@90mph at 3600ft
2007 Charger SRT-8 12.3@120mph@3600ft, Heads/cam, NOS 548 RWHP
2001 Dodge Viper GTS Heads/cam 612 rwhp & 619 rwtq
There are 2 ways to make a car fast.
#1 use the Right combo of parts
#2 Throw so much money at it that the car has no choice but to be fast.
I choose #1
Click for US 3S Fastest ET list
Better to be a racer for a moment then a spectator for a lifetime
"Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education alone will not; the world is full of educated derelict."— John Calvin Coolidge
SnakeSkinner is offline   Reply With Quote
Old 10-02-2008, 11:31 AM   #6 (permalink)
Twin Turbo Owner
97mits3kgtSOHC's Avatar
Drives: 95 Pearl White VR4
Trader Rating: (95)
97mits3kgtSOHC Level 397mits3kgtSOHC Level 397mits3kgtSOHC Level 397mits3kgtSOHC Level 3
DR16T's
Boost controler
Denso pump
Air intake
Down pipe
Exhaust
Clutch/flywheel
UD pulley
a A/F guage
what is the best dr16ts have done?
im just curious bc my car still is not done and i bought my 16ts and stage2 heads from you a little while ago
ill be running
16ts with stage 2 heads
dsbc for boost
evo560ccs
fmic
dnp intake pipes
3" downpipe to a 3" dualshot catless
aem fpr
safc2 and wideband for tuning
97mits3kgtSOHC is offline   Reply With Quote
Old 10-02-2008, 01:11 PM   #7 (permalink)
Supporting Vendor
Trader Rating: (32)
ill be running
dsbc for boost
evo560ccs
fmic
dnp intake pipes
aem fpr
at the track I'm not sure, but I would expect realy lo 11's with supporting mods
Old 10-04-2008, 08:24 AM   #8 (permalink)
1st NG08 / 2nd NG07 Drags
Drives: 93 VR-4
neverenoughhp level 6neverenoughhp level 6neverenoughhp level 6neverenoughhp level 6neverenoughhp level 6neverenoughhp level 6
low 11 sec should be hard if you try. 10s are possible even.
11.4 @ 125 w/DR500, DR Stage III heads, 50 Shot, Weight reductions, and no traction.
neverenoughhp is offline   Reply With Quote
