Go Back   3000GT/Stealth International Message Center > Supporting Vendors > Dynamic Racing
Old 06-10-2008, 03:04 PM   #1 (permalink)
Paid Member
jba3's Avatar
Drives: mitsu's stock up ^_^
jba3 Level 7jba3 Level 7jba3 Level 7jba3 Level 7jba3 Level 7jba3 Level 7jba3 Level 7jba3 Level 7jba3 Level 7jba3 Level 7
Default Identifying DR500 turbos?
Is there any easy way to tell if a set of turbos I bought is DR500 turbos? (Aside from bolting them on and seeing how they dyno)
I got a set from a member on here and want to make sure they are truly DR500s. I had a bad experience on another forum where someone misrepresented a turbo and I got screwed on the deal.
Thanks.
Before you "go big or go home"...
http://www.3si.org/forum/f1/philosop...g-cars-400850/
If my posts have been helpful or informative, or even entertaining, rep is appreciated.
Old 06-10-2008, 08:14 PM   #2 (permalink)
Ross
Drives: 1995 VR4
Trader Rating: (7)
rossfashow Level 2rossfashow Level 2rossfashow Level 2
Default Re: Identifying DR500 turbos?
do the wheels appear clipped?
http://dynamicracing.com/product_image.php?imageid=8
well it is hard to tell. I know dr650's are easy
http://dynamicracing.com/product_image.php?imageid=9
I <3 Boost.
1995 VR4 MoneyPit Edition. DBB DR-1000
rossfashow is offline   Reply With Quote
Old 06-11-2008, 12:47 PM   #3 (permalink)
Paid Member
jba3's Avatar
I wish I knew.
The DR500 vs 9B pics look the same to me. The DR650 I see the difference though.
Old 08-16-2008, 04:32 PM   #4 (permalink)
Devoted Darkling
ukyo's Avatar
Drives: Like John M
Trader Rating: (7)
ukyo is an unknown quantity at this point
Originally Posted by jba3 View Post
I wish I knew.
I know you posted this a while back, but it's easy to tell. Just compare them to 9Bs. The inlet to the compressor on the DR500 will be larger on the internal diameter and the visible part of the compressor wheel will be obviously larger.
Hope that helps...
--Travis (AIM: ukyo1714)
97 Eclipse GSX: Daily Driver (aka, SLOW)
94 3000GT VR-4: 12.835 @ 109.40 (I need a better tune...)
97 Supra TT: 13.363 @ 112.40 (100 octane / street tires)
"Wise men wonder while strong men die" -- Breaking Benjamin
ukyo is offline   Reply With Quote
Old 08-18-2008, 10:22 AM   #5 (permalink)
Paid Member
jba3's Avatar
Hope that helps...
It does, other than I don't have any 9bs off yet to compare it to. I think stock inlet is 36mm, so I'll check and see. Thanks!
Old 09-02-2008, 03:10 PM   #6 (permalink)
Paid Member
jba3's Avatar
Hope that helps...
I measured the inlet to the compressor, and it's the same on the front 9B of my car, and the front turbo I purchased. When you say internal diameter, you mean right next to the compressor wheel, right? I can't see that part very well, as the stock 9B is still bolted on the car.
Old 09-04-2008, 08:59 PM   #7 (permalink)
Paid Member
jba3's Avatar
Pics:
Old 09-05-2008, 02:32 PM   #8 (permalink)
L_P
Woot!
L_P's Avatar
Drives: '95 Dodge Stealth TT
Trader Rating: (29)
L_P Level 3L_P Level 3L_P Level 3L_P Level 3
Pull the compressor housing off and measure the wheel. Inducer and exducer post those numbers. That will be the sure fire way. It does look as though the one you posted appears to be milled out doesn't have the taper you find on the 9Bs but it is hard to see in the pictures. also post the turbine too. most people don't clip the wheel of a 9B.
1995 Dodge Stealth R/T TT, Dark Green ext, Dark Int, 1 of 20 available to the US.
Mods: 13T/E3 16G turbos, FMIC 3" in/out, Spec Stage 3 clutch, RPS Billet Aluminum Flywheel, Gutted front and rear precat, test pipe, MSD 8.5mm SC Wires, 3rd Gen lifters, EGR Delete, 3SX EGR Block off plates, Blitz DD BOV, Hotwire Walbro 255 Fuel pump, Map ECU, Dual Pillar pod w/ AEM Wideband and AEM Tru Boost, Halo Hybrid Data logger, Supercar Engineering 1/2 billet aluminum Shift fork, fresh 1/2/3 friction rings, custom solid engine mounts, 3" Straight pipe exhaust single out.
Looks: DCC Conversion, White face glow gauges.
Sound: Infinity components up front, infinity 10" sub in back with Smokin' VR4 corner sub box, Pioneer HU.
Myspace
Must go faster project underway. E85 powered
Front E3 16G installed, next is the rear one!
Equal length headers custom made.
L_P is offline   Reply With Quote
