#12 (permalink) |
SOHC you in the FACE
If you have to slow the turbos down, please go stage 5 instead of clip. They arent much more expensive then your whole dyno trip
![]() 500hp per stage 3 in a .63 housing is... a LOT. 500 on a stage 5 though would still have plenty of room left. Pretty sure some DSM guys used to get near 600 on a single stage 5. I am amazed you got away with what you did on the stage 3. Pretty sure they are not happy. Your stock intake seems to have been one of the best bandaids ever on so many levels (saving you thousands on fuel and turbos) ![]()
Brent
1992 Duster -12.7@114 - 14psi boost -13.9@107.4 - 5psi - 6g72 3.13L "built" SOHC, Precision T67 P-trim, Tial 38mm open dump, 3" downpipe, 20x12x3" evo style intercooler, 7:1 compression, balanced, shot peened rods, heavily ported heads (+40% on flowbench), Ferrea Competition Plus +2 +1 stainless valves, Nielson Vintage 278 duration custom turbo cams, RPW Cam gears, Custom Ram Style short runner intake manifold, Walbro 255hp, 6*47# injectors, +0.096" Forged Venolias, Total Seal chrome gapless top rings, Fidandza Flywheel, Clutchnet 3 puck solid hub, OBX Helical LSD, Zeitronix wideband/EGT/Boost sensors, 100watt DevilsOwn Meth Kit. 1994 Spirit - 13.987@101.89 - 5psi- 6g72 SOHC, K27 Turbo ![]() |
#13 (permalink) |
Corn Its whats for boost
Crazy Power, Nice Work!
AEM Factory Trained Tuner
![]() 91VR4-3.0L-Stock heads and Cams-762AWHP 747AWTQ 30psi E100 Daily Driver 10.63@121mph SLTT-10.9 @ 140MPH Stock NA motor and NA heads/Cams T4 AWD 9.21 @ 154.98 T2 FWD 10.19 @ 140.31 T4-159.23 MPH Ran on 6G72 3.1L! T4-995AWHP Uncorrected 6G72 3.0L C16 T2-820FWHP 3.1L 27psi C16 91VR4 Red-17Gs w/supporting mods-sold 93SLTT/T2 91VR4 Pearl White-sold 91VR4 Black-sold 92VR4 Sandstone-sold 94VR4 Green-sold 93VR4 Pearl White-sold NG09 Title Sponsor 3SX Performance 3SX Performance Service Email |
#14 (permalink) |
Crimson Jihad
Congrats! Hope you get the surging problem fixed.
CAUTION: Over Boosting May Cause Accidental Orgasm.
![]() 1993 Mitsubishi 3000gt VR-4 1994 Mitsubishi 3000gt SL mtx..... I miss her! Dyno: 243awhp/280awt On stock boost(~8psi) mods: K&N/Greddy type-RS (Badly Heatsoaked + Boost Leak). Mods: K&N filter, HKS SSQV, Redline motor oil 10w40, IPS 3" DP, Custom single shot, SSR GT7's, Tein S-tech,MSD 8.5 Super conductor wires, NGK |X Iridium spark plugs. Waiting install: Blitz DSBC, , Greddy fatt, Apexi Safc2, Apexi S-itc, Maximal mounts, FMIC, RobBecks 13t's, Maf-t, z06 maf, evo9 560cc, Denso supra pump. Contemplating: Small ones |
#15 (permalink) | |
Supporting Vendor
Never thought I would be looking for a way to add some lag to my car. lol
![]() 93 RT TT 8.74@168.5mph @3600ft Worlds Quickest and Fastest 3000gt/stealth 95 3000GT VR-4 10.56@136mph- 714 AWHP & 607 AWTQ (dr-900's) (sold) 92 Stealth RT TT 10.69@133.45mph @3600ft (dr-800's) (sold) 95 RT TT 10.88@129.1mph @3600ft (sold) 95 RT TT 11.9@118mph (stock injectors) 2004 F350 Harley 14.4@90mph at 3600ft 2007 Charger SRT-8 12.3@120mph@3600ft, Heads/cam, NOS 548 RWHP 2001 Dodge Viper GTS Heads/cam 612 rwhp & 619 rwtq There are 2 ways to make a car fast. #1 use the Right combo of parts #2 Throw so much money at it that the car has no choice but to be fast. I choose #1 Click for US 3S Fastest ET list Better to be a racer for a moment then a spectator for a lifetime "Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education alone will not; the world is full of educated derelict."— John Calvin Coolidge Last edited by SnakeSkinner : 06-11-2008 at 08:49 AM. |
#16 (permalink) |
Forest Gump
very nice, I'm glad your leg is better also.
![]() Power: DSM 13G/DR650 Combo, EVO 560cc injectors, SAFC I, K&N, Ebay Downpipe, ATR Dual Catback, no cats, DN Y-Pipe, HKS SSQV, HKS EVC 5 at 14.5PSI, Walbro 255 with AN Bulkhead 8.07 @ 85.55 1/8th mile 1.84 60FT Suspension: KYB GR-2 - Tein S-Techs, Crossdrilled/slotted rotors, AWS Delete Drivetrain: RPS Street Max, M.W. 300m O/S, Seattle F&R Poly Mounts, EK2 ExoCage Etc: Roller Bearing Short Shifter Smokinvr-4 Corner box, 10" Rockford Fosgate Punch sub, Eclipse Headunit Leatherseats.com Charcoal/Dove Grey Interior, 99 front end/lights/wing/sideskirts/doorcapsm Scanmaster 3 Maintenance New VSS, all 60K stuff, new 1st,2nd, 3rd syncro, trans seals, oil pump, rod and main bearings. Mobile 1 10w40, Redline MTL in trans, 85w90 Coastal GL5 in transfer case and rear |
#17 (permalink) |
Supporting Vendor
here is the dyno chart, as you can see I even tryed going WOT and starting the pull later in the RPM band on the 1031 pull to see if it would slow the spool. It only effected the power down low because it had less time to spool to that RPM, but after 4500rpm the boost just slams up to max boost any way. I even tryed bringing the car up to 5000rpm at part throttle on one pull and just nailing it from there, that did not work either boost just slammed on and it surged right away.
I think I need to add about 4-500 rpm worth of lag and I think I will have problem solved ![]() ![]() The 993 is the smooth pull with the intake pipes off. (it surged a tinny bit at about 135mph, but nothing like with the intake pipes on) |
