Go Back   3000GT/Stealth International Message Center > Supporting Vendors > Dynamic Racing
Old 05-20-2008, 06:03 PM   #1 (permalink)
Supporting Vendor
SnakeSkinner's Avatar
Trader Rating: (35)
SnakeSkinner Level 4SnakeSkinner Level 4SnakeSkinner Level 4SnakeSkinner Level 4SnakeSkinner Level 4SnakeSkinner Level 4SnakeSkinner Level 4SnakeSkinner Level 4SnakeSkinner Level 4SnakeSkinner Level 4SnakeSkinner Level 4
Default Dynoed my car again 971hp, and proved a point.
I felt that my draw threw ARC-2 with the STOCK rubber "Y" that the mass pushes into going to 2.5" intake pipes were realy holding me back, so I decided to test it.
I had come up with a new cam grind that falls in between my street and race grinds and thy had been sitting here waiting for me to test out. So I desided to install them and see if the power still flattened out right around 950hp like it was with the street cams.
My 1st Dyno pull was with nothing changed other then the cams. (and that it was 100deg this day in the Dyno room VS 85 deg the last time, and I now have nelson's Oil pump gears installed). The car made slightly more peek hp (963 vs 955) but it was just a blip, the lines prity much traced each other after peek power you could not even tell the lines apart.
So Next I pulled off the Air filter (even knowing that for sure the pipes, and the Y were going to be way more restrive then the filter was) and it made slightly more HP at 971 after getting the tune right for the Filter not being on the MAS (anybody that has ever pulled a filter off a Hot wire MAS knows it changes the tune) So the filter was a slight restriction, but the big one is still to be removed. It still amases me that the stock rubber "Y" that the MAS pushes into can even suport 971 hp, seeing how it was designed to only what 240 at the wheels?
OK time to try and set the ARC-2 up blow threw..... stay tuned
93 RT TT 8.74@168.5mph @3600ft Worlds Quickest and Fastest 3000gt/stealth
04 Lambo Gallardo
95 RT TT 604 awhp 611 awtq (DR750's, and stock motor)
2004 F350 Harley 14.4@90mph at 3600ft
95 3000GT VR-4 10.56@136mph- 714 AWHP & 607 AWTQ (dr-900's) (sold)
92 Stealth RT TT 10.69@133.45mph @3600ft (dr-800's) (sold)
95 RT TT 10.88@129.1mph @3600ft (sold)
2001 Dodge Viper GTS Heads/cam 612 rwhp & 619 rwtq (sold)
There are 2 ways to make a car fast.
#1 use the Right combo of parts
#2 Throw so much money at it that the car has no choice but to be fast.
I choose #1
Click for US 3S Fastest ET list
Better to be a racer for a moment then a spectator for a lifetime
"Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education alone will not; the world is full of educated derelict."— John Calvin Coolidge
SnakeSkinner is offline   Reply With Quote
Old 05-20-2008, 06:31 PM   #2 (permalink)
SOHC you in the FACE
Ondontii's Avatar
Drives: Mrs. Officer
Ondontii Level 1Ondontii Level 1
Default Re: Dynoed my car again 971hp, and proved a point.
Good to see you proving a point and backing it up with useful numbers/info. Hopefully you are able to collect similar useful info when you get more extreme with your Arc 2 setup and intake.
p.s.
Brent - Great Depression Racing
1992 Duster 11.54@125 22psi BONE Stock 6g72 12 valve - 12.7@114 14psi boost -516whp 519ft/lb 20psi (Old 3.13L built shortblock) - Precision 6765, Tial 38mm open dump, 3" open downpipe, 20x12x3" evo style intercooler, Stock 10:1 diamante 12 valve shortblock with regapped rings. heavily ported heads (+40% on flowbench), Ferrea Competition Plus +2 +1 stainless valves, Nielson Vintage Racing 278 custom turbo cams, RPW cam gears, Custom Ram Style short runner intake manifold, 12 Gal Jaz Fuel Cell, Dual external Walbro GSL392 255HPs, Dual 5/16" feed lines, Trick Flow AFPR, 3 puck solid hub & 3300# DD plate, OBX Torsional Diff, Zeitronix wideband/EGT/Boost, 2100cc 3 nozzle DevilsOwn Meth. Running on 4.0 BAR Megasquirt II, 47# Inj, E70 Fuel
1994 Spirit - 13.987@101.89 - 5psi- 6g72 SOHC, K27 Turbo
http://videos.streetfire.net/video/9...-on_649313.htm
Ondontii is offline   Reply With Quote
Old 05-20-2008, 06:37 PM   #3 (permalink)
Supporting Vendor
Trader Rating: (35)
p.s.
I have some 3" intake pipes with twin filters already made, I have a 80MM C&L MAS that is designed to be used blow threw, now I just got to find a good spot and cut my IC piping and install the mas. I ordered all 4 different calibration tubes for the MAS from C&L so I think no matter what I will be able to get the tune right.
Old 05-20-2008, 06:57 PM   #4 (permalink)
The dark shall be with us
Devilmightcry's Avatar
Drives: 93' VR4
Trader Rating: (13)
Devilmightcry is an unknown quantity at this point
man 29 more WHP and you are there. good to see you are still trying to make it faster with ARC-II. ohh don't put the mas in front of the tranny behind the radiator. i did that and it was hitting my shifting linkage.
P.M me if you need new JDM MR final gear. $600+ shipping
Devilmightcry is offline   Reply With Quote
Old 05-20-2008, 07:50 PM   #5 (permalink)
Corn Its whats for boost
Import Power's Avatar
Drives: Vicki Insane
Trader Rating: (217)
Very nice.
Any way you can get the RPM instead of MPH on the graph?
91VR4-3.0L-Stock heads and Cams-811AWHP 747AWTQ Daily Driver 10.57@141mph
T4 AWD 9.21 @ 154.98
T2 FWD 10.19 @ 140.31
T2-820FWHP 3.1L 27psi C16
NG09 and NG10 Title Sponsor
3SX Performance
3SX Performance Service Email
Carolina 3S Forum
Old 05-20-2008, 10:46 PM   #6 (permalink)
OMGOMGOMGOMG
J-Ville VR-4's Avatar
Drives: 91 VR-4
Trader Rating: (13)
J-Ville VR-4 is an unknown quantity at this point
Cool stuff! I'm curious to see how different tuning will be with a blow through setup, and how much more power you will gain.
How much more power do you think your cranked up 720's and meth can support?
Jake - 91 VR-4
J-Ville VR-4 is offline   Reply With Quote
Old 05-20-2008, 11:10 PM   #7 (permalink)
the 3S whisperer
gltasn's Avatar
Drives: 95 mitz 3kgt vr4
Trader Rating: (6)
gltasn is an unknown quantity at this point
make sure and do a big thread on this arc2 blow thru! i would love to convert from the splitter. ive got my 87mm mas and hope your tune is good with this size. i even have a place to splice it in. we are all ears! j sin
"If I was as slow as you, they'ed bury me!" terry canfield(dad)
gltasn is offline   Reply With Quote
Old 05-21-2008, 02:42 AM   #8 (permalink)
Ondontii's Avatar
Matt, how are you going to take care of your lack of fuel? I see your peak numbers requiring a lot more fuel. I hope you are not tempted to stay a restrictor plate racer
Old 05-21-2008, 03:25 AM   #9 (permalink)
Ondontii's Avatar
Matt, I have a gearing excel Spreadsheet that Frank @ turbomopar.com made.
There are a few things wrong with the original so the 5 speed tranny options (way at the bottom of the list) dont work on the original download but I fixed the spreadsheet so the 5 speed data works.
If you have microsoft excel I can email you the file. I will save it setup for your car. It also has the 6 speed tranny info.
Old 05-21-2008, 03:31 AM   #10 (permalink)
Ondontii's Avatar
You are making 900hp 626ft/lb @ 7550 rpms
You are making 950hp 907ft/lb @ 5500 rpms
You are making 700hp 813ft/lb @ 4500 rpms
Your motor goes crazy after 4000 rpms.
