Go Back   3000GT/Stealth International Message Center > Supporting Vendors > Dynamic Racing
Old 08-06-2009, 07:13 PM   #1 (permalink)
VR4Joe's Avatar
Drives: 95' VR4 and 95' NA
VR4Joe is an unknown quantity at this point
Default ARC2 Help!
I know you guys are the best at the arc2, esp Matt.
I need alittle help, i just hooked my arc2 up to my car and can only get it to idle, everytime i give it gas, and then let go of it, it stalls out
My mods are...
15g
550's
Hot wire denso Pump
FPR at 35 with vac line
HKS SMIC
I just need a good base, i tried the numbers on stealth316 and i can't idle correctly.
Right now i have
Low +6 clicks
Mid -7
High -2
Accel +2
Where do i go from here? I idle at about 14-15afr and at about 600rpms which seems pretty low.
Any time i get into gear, give it gas i move alittle, once i let go of the gas, i lean out and stall.
Make your car pictures into your own custom posters
http://www.3si.org/forum/f25/group-b...6/#post5315711
VR4Joe is offline   Reply With Quote
Old 08-06-2009, 08:10 PM   #2 (permalink)
Supporting Vendor
SnakeSkinner's Avatar
Trader Rating: (35)
SnakeSkinner Level 4SnakeSkinner Level 4SnakeSkinner Level 4SnakeSkinner Level 4SnakeSkinner Level 4SnakeSkinner Level 4SnakeSkinner Level 4SnakeSkinner Level 4SnakeSkinner Level 4SnakeSkinner Level 4SnakeSkinner Level 4
Default Re: ARC2 Help!
My mods are...
15g
550's
Hot wire denso Pump
HKS SMIC
Right now i have
Low +6 clicks
Mid -7
High -2
Accel +2
Well to start with do you have a ARC-2 GP R5? (look on the back of the unit)
93 RT TT 8.74@168.5mph @3600ft Worlds Quickest and Fastest 3000gt/stealth
04 Lambo Gallardo
95 RT TT 604 awhp 611 awtq (DR750's, and stock motor)
2004 F350 Harley 14.4@90mph at 3600ft
95 3000GT VR-4 10.56@136mph- 714 AWHP & 607 AWTQ (dr-900's) (sold)
92 Stealth RT TT 10.69@133.45mph @3600ft (dr-800's) (sold)
95 RT TT 10.88@129.1mph @3600ft (sold)
2001 Dodge Viper GTS Heads/cam 612 rwhp & 619 rwtq (sold)
There are 2 ways to make a car fast.
#1 use the Right combo of parts
#2 Throw so much money at it that the car has no choice but to be fast.
I choose #1
Click for US 3S Fastest ET list
Better to be a racer for a moment then a spectator for a lifetime
"Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education alone will not; the world is full of educated derelict."— John Calvin Coolidge
SnakeSkinner is offline   Reply With Quote
Old 08-06-2009, 08:27 PM   #3 (permalink)
VR4Joe's Avatar
Yes i do. I was just driving in my driveway, going forward and backwards, if i go any higher than 2k rpms the car stalls. The car is running really rich and if i try to lean it it stalls as well. I can't even adjust the mid, she stalls if i lean or richen.
Old 08-06-2009, 10:12 PM   #4 (permalink)
Supporting Vendor
Trader Rating: (35)
Did you get it from us? if not was it a NEW unit or somthing you baught used.
Your best bet will to be FIRST make sure EVERYTHING is wired in and hooked up correctly.
Then call me from a cel phone wile inside the car.
Old 08-06-2009, 10:13 PM   #5 (permalink)
VR4Joe's Avatar
I also have an SAFC hooked up as well, i wired both of them just like the stealth316 diagram showed.
It seems like 1600-17000rpms while driving the car just boggs and stalls. I haven't even been able to get out of 1st gear
Old 08-06-2009, 10:14 PM   #6 (permalink)
VR4Joe's Avatar
When is the best time to call you up, i know you're a pretty busy guy.
Old 08-06-2009, 10:26 PM   #7 (permalink)
Supporting Vendor
Trader Rating: (35)
I would remove the AFC no need for that to be there.
Old 08-07-2009, 06:55 PM   #8 (permalink)
VR4Joe's Avatar
I tried calling you today, but i don't believe you work on fridays. I uninstalled the AFC and it's still doing the same thing, i got it to idle fine, but when i put into 1st and start to drive slowly, it's fine. Once i reach about 1600 rpms she goes crazy, bogs, and then stalls out. During this my AEM Wideband is also going crazy reading really really rich and then leans out untill the unit gives me the three dashes.
I then did a vac test and found no leaks, she holds air like a champ. What could be the problem??
Again my current settings are
Low+7 clicks
Mid -7
High -2
Accel +2
Old 08-07-2009, 09:49 PM   #9 (permalink)
Supporting Vendor
Trader Rating: (35)
Low+7 clicks
Mid -7
High -2
Accel +2
What MAS are you running? 83mm? 92mm?
If you are running the black 92mm your high is WAY off for 550's it's going to be more like +8ish
Old 08-08-2009, 01:06 AM   #10 (permalink)
VR4Joe's Avatar
I have the Ford 83mm MAS
It's got a 4" diameter because i just got a filter for it.
Can you see if i have the correct pin numbers for all the connections. Grey Haze gave me these numbers for the hybrid ECU just to make sure i installed this correctly
AirTemp Pin#72
Baro Pin #95
IPS Pin #87
Air Flow Pin #90
For the ARC2 ground, do i hook it up to the ECU ground Pin 26 or the sensor ground PIn 92???
