Go Back   3000GT/Stealth International Message Center > Supporting Vendors > MVP Motorsports
Old 08-03-2007, 12:21 PM   #1 (permalink)
Paid Member
jba3's Avatar
Drives: mitsu's stock up ^_^
Trader Rating: (15)
jba3 Level 5jba3 Level 5jba3 Level 5jba3 Level 5jba3 Level 5jba3 Level 5
Default lowering springs for a VR4 spyder?
I've heard you can mix and match the Tein S-Tech and H-Tech springs to get a good lowering on the VR4 spyders. Can you put together a special set for that, and how much would it be?
Thanks!
Originally Posted by ImNotSpeeding View Post
when you turn your car on, does it return the favor?
Hi, my name is James, and I'm a VR4 addict
If my posts have been helpful or informative, or even entertaining, rep is appreciated.
Old 08-03-2007, 01:47 PM   #2 (permalink)
Supporting Vendor
chops is an unknown quantity at this point
Default Re: lowering springs for a VR4 spyder?
If you mean have the fronts as s-techs and the rears as h-tech or the other way around you cannot do that unless you purchase a set of each.
Regards,
Robert
www.MVPmotorsports.com
940-683-8282 x20
Robert Del Angel
Master Distributor for:Volk, Blitz, Brian Crower, Koyo, Brembo, Stillen, Power Enterprise, HKS, Greddy, Blitz, RPS, Fidanza, Apex, Map ECU,Tein, Sparco....and so many more!!!
chops is offline   Reply With Quote
Old 08-03-2007, 02:13 PM   #3 (permalink)
Crimson Jihad
Disrupter's Avatar
Drives: An Angry Demon!
Trader Rating: (12)
Disrupter Level 3Disrupter Level 3Disrupter Level 3Disrupter Level 3
My friend has s-tech's on his Spyder, and the ride is amazingly like stock, but handles a lot better and ofcourse no more wheel gap. The ride was a bit firmer too.
CAUTION: Over Boosting May Cause Accidental Orgasm.
1993 Mitsubishi 3000gt VR-4
1994 Mitsubishi 3000gt SL mtx..... I miss her!
Dyno: 243awhp/280awt On stock boost(~8psi) mods: K&N/Greddy type-RS (Badly Heatsoaked + Boost Leak).
Mods: K&N filter, HKS SSQV, Redline motor oil 10w40, IPS 3" DP, Custom single shot, SSR GT7's, Tein S-tech,MSD 8.5 Super conductor wires, NGK |X Iridium spark plugs.
Waiting install: Blitz DSBC, , Greddy fatt, Apexi Safc2, Apexi S-itc, Maximal mounts, FMIC, RobBecks 13t's, Maf-t, z06 maf, evo9 560cc, Denso supra pump.
Contemplating: Small ones
Disrupter is offline   Reply With Quote
