Go Back   3000GT/Stealth International Message Center > Supporting Vendors > MVP Motorsports
Old 10-12-2009, 07:54 PM   #1 (permalink)
Supporting Vendor
chops is an unknown quantity at this point
Default AEM Water/Methanol Injection Kits!!!
END OF YEAR SALE!
AEM WATER/METHANOL INJECTION KITS
** SALE RUNS - 10/12/09 THRU 12/31/09 **
MSRP = $439
Sale Price = $339.79 with free shipping.
AEM Water/Methanol Injection Kits reduce air inlet temperatures which allows users to increase boost pressure (and advance timing on forced induction gas applications) to create more power by utilizing the cooling effects of the system under heavy load. The kit is offered in 2 configurations: a 1-Gallon kit for racecar applications, and a 5- Gallon HD kit for Diesel applications or racecars requiring extended range. Both kits include all the elements necessary to do water/methanol injection right, including a standard fluid level sensor for the tank, recirculation-style pump, feature-loaded controller, and complete hardware for installation on practically any diesel or gas application. For users who intend to use a custom or existing reservoir, AEM also offers a �tankless� pump and jet kit. There are no hidden costs or additional components required.
How it Works
Once the AEM Water/Methanol Kit is installed, a boost-dependent, variable-flow progressive controller allows the user to determine the amount of water/methanol mixture (up to 50%) to feed into the inlet stream from the fluid reservoir. The controller commands a high-pressure, recirculation-style 150-PSI pump that delivers the mixture. Overall flow adjustments at the inlet are made via one of three different-sized jets (included) that are designed to match most engine power requirements.
Recirculation-Style Pump
AEM's recirculation-style pump offers improved performance, reliability and a much smoother, quieter operation when compared to older switched-style pumps. With the use of a new internal bypass design, AEM's upgraded pump eliminates erratic on and off switching/pulsing and ensures consistent fluid delivery for optimum performance. With durability and reliability in mind, AEM has designed the pump with a Santoprene diaphragm and EPDM seals to withstand the harshest of alcohol mixes.
Boost Safe!
All AEM Water/Methanol controllers include a Boost Safe feature. This feature allows users to retard timing or reduce boost via a ground output if the system runs out of fluid or detects a controller error, ensuring fail-safe operation of the engine whether the system is engaged or not. Critical safety features are integrated into the system to virtually eliminate any chance of failure, including an integral fluid level sensor in the reservoir, internal controller diagnostics and an LED dash light to warn of low fluid level or error codes (including short circuits.
Key Features
  • Universal kit includes everything you need for installation
  • Boost Safe feature lets you retard the timing or reduce boost via a low side output if the system runs out of fluid or detects a system error
  • Recirculation-Style, controller-driven 150-PSI pump provides boost-dependent variable flow
  • One- and five-gallon tanks with integral fluid level sensors available
  • LED dash light included for system status and low fluid warning
  • Methanol compatible (up to 50% in solution with water)
  • Includes three different-sized jets to match your power requirement
Contact us today for other great deals on all products.
***Free Shipping is only valid in the Continental United States, if you are a resident of AK, HI, or are International customer please contact MVP for an updated discounted shipping quote.**Limited time offer only, Texas State Sales tax does apply to residents of Texas***
Regards,
Robert
www.MVPmotorsports.com
940-683-8282 x20
Robert Del Angel
Master Distributor for:Volk, Blitz, Brian Crower, Koyo, Brembo, Stillen, Power Enterprise, HKS, Greddy, AP Racing, RPS, Fidanza, Apex, Map ECU,Tein, Sparco....and so many more!!!
chops is offline   Reply With Quote
Old 10-24-2009, 02:20 PM   #2 (permalink)
Minty
Alt0id's Avatar
Drives: '94 3000GT SL
Trader Rating: (14)
Alt0id Level 1Alt0id Level 1
Default Re: AEM Water/Methanol Injection Kits!!!
I need...
1994 Mitsubishi 3000GT SL Twin Turbo
10:1 - 9b turbos - MR downpipe - KN FIPK - 360cc injectors - Prosport Wideband - Prosport Boost gauge - ATX to MTX
Coming soon - Meth injection
In the works:
ATX - MTX
http://www.3si.org/forum/f117/auto-m...n-more-483060/
Alt0id is offline   Reply With Quote
Old 10-29-2009, 02:07 PM   #3 (permalink)
Supporting Vendor
You can order through the following link:
Engine Performance Parts - 3000GT & Stealth
Regards,
Robert
Old 10-29-2009, 03:03 PM   #4 (permalink)
jeettao's Avatar
Drives: '99 3000GT VR-4
jeettao is an unknown quantity at this point
Regards,
Robert
I scoured the internet this past summer to find the absolute cheapest price I could on the AEM kit. I eventually found it for about 355 shipped after about 4 hours of searching.
So, needless to say, this is a good deal. I'm not going to kick myself for not waiting 6 months to save 15 bucks, but if I were buying this today, I'd certainly go this route. Jeettao pricing approved.
jeettao is offline   Reply With Quote
Old 10-30-2009, 07:34 PM   #5 (permalink)
Supporting Vendor
HAHA thanks buddy! This is for sure a great deal that we are happy to post up thanks to AEM!!!
Regards,
Robert
Old 11-17-2009, 11:27 AM   #6 (permalink)
Track Whore
Trader Rating: (24)
Phalse is an unknown quantity at this point
Ordered the kit today along with a aem uego wb02, great price on the meth kit, needed the wb02 anyway. Looking forward to ending my dependency on race gas to run reasonable boost.
Phalse
DSM & 3000GT/ Stealth Veteran
95 Stealth TT - ongoing repair, no times yet. Mods: IPS downpipe & singleshot exhaust, intake filter, dsm 450s, hotwire fuel pump, mbc @ 15psi
Phalse is offline   Reply With Quote
Old 11-17-2009, 11:33 AM   #7 (permalink)
Supporting Vendor
Processing now, will ship out ASAP!! Thanks for the order sir.
Regards,
Robert
Old 11-17-2009, 02:36 PM   #8 (permalink)
Track Whore
Trader Rating: (24)
Looking forward to putting up some before and after results of meth on the
3s. Thanks for the good deal and fast shipping.
Old 11-17-2009, 03:16 PM   #9 (permalink)
Supporting Vendor
Anytime sir!
Regards,
Robert
Old 11-19-2009, 11:17 AM   #10 (permalink)
Track Whore
Trader Rating: (24)
Wow that was fast. Ordered Tuesday mid morning, in hand thurs morning. You guys kick ass.
I love it when stuff shows up before the weekend so you actually have time to install it.
