Go Back   3000GT/Stealth International Message Center > Supporting Vendors > 3SX Performance
The Title Sponsor of the 2010 3S National Gathering
Old 06-24-2009, 08:38 AM   #1 (permalink)
Lexiconix's Avatar
Drives: 92 Dodge Stealth ES
Lexiconix is an unknown quantity at this point
Default Question about 3SX's solid mount inserts
Is it safe to assume that these inserts will fit in factory mounts?
Lexiconix is offline   Reply With Quote
Old 06-24-2009, 12:01 PM   #2 (permalink)
The Afro King
duBz's Avatar
Drives: on two wheels
duBz Level 1duBz Level 1
Default Re: Question about 3SX's solid mount inserts
It is very safe to assume that as we use stock cores to build our mounts.
But unless you have a 50 ton press...it can be pretty hard to do yourself.
Josh
87 Starion (Sold)
3 1G DSMs all sold! - No more Dizzims!
99 Saab 9-5 ...something different
08 Ninja ZX-6R
duBz is offline   Reply With Quote
Old 06-24-2009, 01:20 PM   #3 (permalink)
Corn Its whats for boost
Import Power's Avatar
Drives: Vicki Insane
Trader Rating: (217)
You may be able to do it with a 25 ton press. Be careful. They go POP and can hurt ya.
-Chris
91VR4-3.0L-Stock heads and Cams-811AWHP 747AWTQ Daily Driver 10.57@141mph
T4 AWD 9.21 @ 154.98
T2 FWD 10.19 @ 140.31
T2-820FWHP 3.1L 27psi C16
NG09 and NG10 Title Sponsor
3SX Performance
3SX Performance Service Email
Carolina 3S Forum
Old 06-24-2009, 05:59 PM   #4 (permalink)
Lexiconix's Avatar
hmmm 50 ton press... that might prove difficult for me to obtain access to. Not sure if my father's work has one to deal with this. Guess I'll be buying the stock mounts then as I don't have the extra 300 for the core charge for the solid mounts and cannot have the car down for more than a day's time.
Old 06-24-2009, 08:59 PM   #5 (permalink)
Pro Bearing Spinner
Comp-U-Geek's Avatar
Drives: 93 3k, 2x Subie
Trader Rating: (9)
Comp-U-Geek is an unknown quantity at this point
Well, though this is not the widely accepted method of "pressing" the inserts into the mounts this is how I did it without a press. (As a side note, this was with another retailer's version of the poly inserts so the hardness may be different)
Get some heavy duty hose clamps (or t-bolt clamps if you got em) large enough to fit around the poly piece. Use Vaseline on the surface of the mount and the poly, then tighten the hell out of a hose clamp about 1/4" up from the bottom of the poly. Set the poly insert on the opening for the mount and beat with a rubber mallet. Once the poly is in enough to touch the hose clamp, move the hose clamp up another 1/4" and repeat until the whole thing is in there. The Vaseline is key to getting them to go in there though.
Chris
TX07 - 1st Place Fastest NA
TX07 - 1st Place Most NA WHP
NG08 - 1st Place AutoX FWD Stock
TX08 - 1st Place Quickest NA
TX08 - 1st Place Highest HP NA
NG09 - 1st Place AutoX FWD Stock
NG09 - 1st Place Drags FWD
TX09 - 1st Place Quickest NA
TX09 - 1st Place Highest HP NA
10/24/2009 - 220WHP 222WTQ (6g74, 93.5mm bore, ported heads, stock 3L cams, open DP )
02/17/2007 - 14.700 @ 96.1mph (3.5 with everything else stock at the time)
03/22/2008 - 14.644 @ 94.48 (drag radials, 3.5 on crappy tune with upgraded fuel system)
Comp-U-Geek is offline   Reply With Quote
Old 06-25-2009, 10:32 AM   #6 (permalink)
3Si Co-Founder
SUTHNR's Avatar
Drives: Everywhere
Trader Rating: (10)
SUTHNR is an unknown quantity at this point
Chris
He said Vaseline makes it go in....
Sorry... Had to.
EricB
Eric "SUTHNR" Bowden's Garage (click to visit)
* 1993 Dodge Stealth R/T - NG09 Best All-Round 3S - NA POWA!!
The 222 HP Stereo... The MOST modified slowest naturally aspirated FWD Stealth out there.
* 2008 Toyota Tundra Pick'm'up Truck
Mods: Right Foot FTW!
* 2005 Chrysler PT Cruiser Convertible High Output Turbo
Mods: The Wife FTW!
* My stereo site lives here: The 222 HP Stereo...
* My personal venture:
Edgy Elegance Photography - Weddings, Home Sales, Automotive, etc!
* I love taking and creating Panorama Pictures: Check out my Panorama Gallery
* The 3000GT/Stealth Collectibles Site: Ultimate 3S Collectibles Archive
* Visit 3SX for record setting parts at www.3SX.com
NG09 Pics LOADED!
3SX 1/4 Mile Times
3SX T2 FWD 3S 10.19 @ 140.31
3SX T4 AWD 3S 9.214 @ 154.98
Also T4 AWD 3S 9.339 @ 159.23
3SX twitter | 3SX FaceBook
SUTHNR is offline   Reply With Quote
Old 06-25-2009, 07:16 PM   #7 (permalink)
Pro Bearing Spinner
Trader Rating: (9)
Sorry... Had to.
EricB
Hahaha, someone had to say it!
Chris
Old 06-30-2009, 08:17 AM   #8 (permalink)
Lexiconix's Avatar
Guess I'll be using Comp-U's method here along with a jack press I have here at my work's fab shop. Owner said I could pull the car into the building... I'm like "You sure?"... Needless to say the entire building will hear the car pulling in as the flex pipe on the down pipe is torn loose. :-) I'll be sure to give a good rev before shutting it down.
Old 07-08-2009, 09:27 AM   #9 (permalink)
Supporting Vendor
SteveVR4's Avatar
Trader Rating: (18)
SteveVR4 Level 4SteveVR4 Level 4SteveVR4 Level 4SteveVR4 Level 4SteveVR4 Level 4SteveVR4 Level 4SteveVR4 Level 4SteveVR4 Level 4SteveVR4 Level 4SteveVR4 Level 4SteveVR4 Level 4
I wouldn't use Vaseline to install them as that can also help the new ones come back out. You could use really soapy water if you wanted to.
Steve
www.3SX.com
SteveVR4 is offline   Reply With Quote
Old 07-13-2009, 12:29 PM   #10 (permalink)
Lexiconix's Avatar
VERY VALUABLE lessons learned today. Don't spend all your money until your DD problems are fixed, if a vendor says it requires "Professional" install... more than likely it means unless you have access to a fabrication and automotive shop, you do not have the means to install said parts. Last but not least... Just because it looks relatively easy by logic... does not mean it is easy.
Story in short...
I bought 3SX's Polyurethane Solid Mount inserts, asked 1 question... (where in reality I should have asked several questions before buying because had I known what I know now vs then... I would have bought a full set of OEM Mounts and be done with it.) I pull out the driver side upper mount easily once I had the motor jacked up to alleviate the weight. Being all happy that it was that easy to get out, I go inside and grab something to eat. I come back out and take a look at the mount itself, that's when the reality of things set in on me.... I could not figure out how to get the pins or the core itself out. So I proceed to cut out the rubber part with a jigsaw which then led to figuring how how to get the outer ring of the core out... after several attempts... it really dawned on me... I can't do it (not without the proper equipment) and yet I am mechanically inclined. I piece everything back together and put it back in. Currently it's holding but I know that I cannot push it beyond driving like my grandmother does until I get a set of OEM mounts now.
Let this be a lesson to you folks out there who are new to autocrossing, aftermarket modifications and so forth... ASK PLENTY OF QUESTIONS AND DO PLENTY OF RESEARCH AND DO NOT SPEND ALL OF YOUR MONEY UNTIL YOUR GOAL IS FINISHED.
Any rate... anyone here able to tell me an "easy" way of getting the old rubber cores out... or is that pretty much impossible without the press or buying new pins?
