Go Back   3000GT/Stealth International Message Center > Supporting Vendors > 3SX Performance
Old 06-21-2008, 08:48 AM   #1 (permalink)
Smash, Bang, AND Pow
stryfe's Avatar
Drives: The Drivewaysitter
Trader Rating: (9)
stryfe Level 1stryfe Level 1
Default Bearing-loaded short throw shifter install issue
I installed this yesterday:
Short Shifter - Bearing-Loaded 3000GT/Stealth*-*Mitsubishi 3000GT*/*Dodge Stealth
The throw is fine, but even with the adjustment on the select cable all the way out, the bottom of the shift lever arm hits the base of the shifter assembly where it connects to the plate. I found threads on other similar shifters, but not specifically the one I purchased.
When I put my stock shifter back in without changing the adjustment I have no problems with shifting. Looking at the shifters side-by-side the bottom of the short throw arm looks to sit 1/4in-1/2in closer in than the stock unit.
I can take pictures of it installed if needed, but I needed to go someplace and I have reinstalled the stock unit.
Any suggestions?
'92 3000GT VR4
13T's: 428awhp / 434awtq --- 12.44@114.76mph
13Ts | FMIC + PPE pipes | 550CC | 3" Exhaust | PST 1pc CFDS
EMU | Stock Chromies FTW | Spec Stage 3+
stryfe is offline   Reply With Quote
Old 06-21-2008, 09:23 AM   #2 (permalink)
calibornn1979's Avatar
Drives: Carro Rapido Rojo
Trader Rating: (14)
calibornn1979 Level 3calibornn1979 Level 3calibornn1979 Level 3calibornn1979 Level 3
Default Re: Bearing-loaded short throw shifter install issue
I see your problem. As far as i know the 91 and 92 and early 93 cars have a differant shifter base. In 93 they started comming with the shorter shifter and the base is differant. Im sure with a little fabrication you can make it work. Or get a shifter base from a 93+ car and you will be set.
Rob Beck 13T WRX turbos, DSM Sidemounts, DEJON Y-Pipe, DEJON Turbo intake pipes, KN Filters, Synapse Syncronic BOV, MSD Wires, Maximal Solid motor mounts, AEM EMS, AEM Duel UEGO, AEM Boost Solinoid, AEM AIT, AEM MAP Sensor, Stillen Down Pipe, Pit Road M 3.5 inch Titanium Catback, Seattle Roller Bearing Short Throw Shifter, Tein S-Tech, 3SX Rear camber arms, 3SX Stage 2 Clutch, 3SX light crank pully, Nelson Transfercase Bracket, RC 680cc Injectors, Walbro fuel Pump, Fidanza Flywheel
calibornn1979 is offline   Reply With Quote
Old 06-21-2008, 10:38 AM   #3 (permalink)
stryfe's Avatar
Trader Rating: (9)
they sell one for 91-92 (what i purchased) and another version for 93+. i wonder if a have the 93+ version instead? half an inch difference on the angle and there would be no issue with mine, i think.
