Go Back   3000GT/Stealth International Message Center > Supporting Vendors > 3SX Performance
Old 05-01-2008, 10:48 PM   #51 (permalink)
streamlnauto's Avatar
Drives: 1993 VR-4
streamlnauto is an unknown quantity at this point
Default Re: 3SX TD05 Kit install?
more of the install posted here-
3SX TD05 Kit Install/Progress
streamlnauto is offline   Reply With Quote
Old 05-05-2008, 07:33 AM   #52 (permalink)
ozdave2's Avatar
Drives: 92 STEALTH TT
ozdave2 is an unknown quantity at this point
I have an exhaust leak as well when engine is cold. Was only running in at low rpm. Leaked sealed very quickly after cold start. Need to pull the engine to fix so leaving for the moment to see how it goes.
Engine was getting too warm on full dyno tune above 5500 rpm to run to full revs. Running Motec.
Fuel pump issue discovered on road run at higher rpm; this is being fixed at present.
I believe 260 kw at wheels at 5500.
ozdave2 is offline   Reply With Quote
Old 05-06-2008, 10:16 AM   #53 (permalink)
3000GT@UAE is an unknown quantity at this point
With 3sx TD05 kit? what psi?
3000GT@UAE is offline   Reply With Quote
Old 05-06-2008, 10:28 AM   #54 (permalink)
starquest 2875's Avatar
Drives: VR-4
starquest 2875 is an unknown quantity at this point
I too have an exhaust leak. I have to pull the motor out as well to fix it.
it sounds like shit. any body else has this problem?
starquest 2875 is offline   Reply With Quote
Old 05-07-2008, 01:03 AM   #55 (permalink)
Drives: 1993 VR-4
you shouldn't need to pull the motor, you can get the manifolds off with the engine in the car, check them with a straightedge to see if they are straight, its fairly inexpensive to have a machinist mill the flanges.
Old 05-07-2008, 07:23 AM   #56 (permalink)
ozdave2's Avatar
Yes with the 3SX TD05 kit. Running with 550 injectors, HKS intercoolers, borla exhaust, fidanza flywheel, SPEC stage 3 plus clutch, 3SX custon underdrive pulley.
Old 05-07-2008, 07:03 PM   #57 (permalink)
ozdave2's Avatar
Got dyno sheet. Numbers were 283awkw at 5458. Set at 1 bar.
Old 05-07-2008, 07:28 PM   #58 (permalink)
Corn Its whats for boost
Import Power's Avatar
Drives: Vicki Insane
Trader Rating: (210)
Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7
what is that in HP?
AEM Factory Trained Tuner
91VR4-3.0L-Stock heads and Cams-762AWHP 747AWTQ 30psi E100 Daily Driver 10.63@121mph
T4 AWD 9.21 @ 154.98
T2 FWD 10.19 @ 140.31
T2-820FWHP 3.1L 27psi C16
91VR4 Red-17Gs w/supporting mods-sold
93SLTT/T2
91VR4 Pearl White-sold
91VR4 Black-sold
92VR4 Sandstone-sold
94VR4 Green-sold
93VR4 Pearl White-sold
NG09 Title Sponsor
3SX Performance
3SX Performance Service Email
Old 05-07-2008, 08:25 PM   #59 (permalink)
Drives: 1993 VR-4
283 kilowatts = 379 awhp
Still sounds low, should be in the mid 400's at least.
Old 05-08-2008, 04:39 AM   #60 (permalink)
yeah, that sounds low. I think most of the 3SX TD05 setups we dyno are in the 400s at that psi
