Go Back   3000GT/Stealth International Message Center > Supporting Vendors > 3SX Performance
Old 01-16-2008, 09:13 PM   #41 (permalink)
I'm a Troll
enorac Negative 1
Default Re: 3SX TD05 Kit install?
Originally Posted by SteveVR4 View Post
Those pieces just slip ogether and go to your wastegate. No welding required
On the interrnal wastegates, when the turbo is bolted up the flapper chamber is closed which will prevent them form bypassing. Most people do use a spot weld on the flapper just for added protection.
Hope this helps.
I'm almost afraid to not weld them, doesnt that pipe see upwards of 50 psi? how can it not leak?
enorac is offline   Reply With Quote
Old 01-17-2008, 05:09 AM   #42 (permalink)
Corn Its whats for boost
Import Power's Avatar
Drives: Vicki Insane
Trader Rating: (210)
Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7
Slip exhaust sections are common. DN has used them on their setups forever.
T4 and T2 has used/developed this kit for upwards of 2 years in one variation or another as we were testing/fitting/changing it until we came to our final production kit. They never leaked out of the WG slip fitting.
You shouldn't have any issues using the slip fitting on the WG.
AEM Factory Trained Tuner
91VR4 Black-5027s-3.0L-Stock heads and Cams- 770AWHP 670AWTQ uncorrected 33psi E90 Daily Driver
T4 AWD 9.21 @ 154.98
T2 FWD 10.19 @ 140.31
T2-820FWHP 3.1L 27psi C16
91VR4 Red-17Gs w/supporting mods-sold
93SLTT/T2
91VR4 Pearl White-sold
91VR4 Black-sold
92VR4 Sandstone-sold
94VR4 Green-sold
93VR4 Pearl White-sold
NG09 Title Sponsor
3SX Performance
3SX Performance Service Email
Old 01-19-2008, 04:58 AM   #43 (permalink)
starquest 2875's Avatar
Drives: VR-4
starquest 2875 is an unknown quantity at this point
If possible can some one show me a pic of where they install the waste gate vacume hoses. where did they tap it into to get vacum for both waste gates.
for this TDO5 kit. or just explain where they tap it to.
thanks
starquest 2875 is offline   Reply With Quote
Old 01-20-2008, 01:42 AM   #44 (permalink)
3000GT@UAE is an unknown quantity at this point
I ll take some pics today and will post them tomorrow
3000GT@UAE is offline   Reply With Quote
Old 01-20-2008, 06:33 AM   #45 (permalink)
Drives: VR-4
thanks
Old 04-20-2008, 08:14 PM   #46 (permalink)
streamlnauto's Avatar
streamlnauto is an unknown quantity at this point
I had no problems with the kit with the exception of the rear wastegate tube as well, but this is a great kit and well worth the money.
My suggestion with the oil return lines, for the front line use 1 90 degree and 1 45 degree fitting rather than the 2 90's, and one straight and one 45 degree on the rear ones, the lines would fit perfect and have absolutely no struggles getting them onto the oil pan and turbo adapters. the length is spot on for both.
I will post pics of my install, I am anal as hell about everything, I had them ceramic coated as well, custom coolant lines etc. No sense of not going balls out on this kit
My note on turbo clocking, I just removed the v band clamp, popped out the one alignment pin and put it back together, took like 5 min, I see no reason to pop the snap ring out since the center cartrige is lined up about the way it needs to be already.
streamlnauto is offline   Reply With Quote
Old 04-20-2008, 08:33 PM   #47 (permalink)
Panda Master
maTT's Avatar
Drives: with one foot.
Trader Rating: (19)
maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7
Glad everything is coming together for you. We put down 633AWHP on a customer car with this kit last month
I no longer work for 3SX however I still strongly recommend them for your 3S parts and service needs!
maTT is offline   Reply With Quote
Old 04-28-2008, 07:13 AM   #48 (permalink)
I have an exhaust leak. I will check it soon. could be the rear headers
Old 04-28-2008, 08:12 AM   #49 (permalink)
The Afro King
duBz's Avatar
Drives: on two wheels
duBz Level 7duBz Level 7duBz Level 7duBz Level 7duBz Level 7duBz Level 7duBz Level 7duBz Level 7duBz Level 7
Keep us posted with what you find.
Josh
87 Starion (Sold)
90 Talon TSi (Sold)
91 Galant VR4 1346/2000 (Sold)
93 Talon TSi (Sold) No more Dizzims!
02 Ninja 250 (Sold)
08 Ninja ZX-6R
duBz is offline   Reply With Quote
Old 05-01-2008, 09:36 PM   #50 (permalink)
Some install pics-
