#11 (permalink) |
Panda Master
Remove the actuator so you can clock the comp housing to fit your needs. One of my favorite things about this kit is that you can do that. I have mine clocked to use all the stock i/c pipes.
#12 (permalink) |
2nd Place NG08 DRAGS
Matt, did you have to clock them alot? Do you think you could take a pic of the front to show where yours is? I think the back does not move, but the front compressor housing has to turn.
Thanks, Shane
![]() 1994 Stealth TT, 1 of 10, Mods- 3.1l 8.5:1 ross pistons, pauter rods, gtpro head gaskets, apr studs, DR stage 3 heads with street grind cams, high rev springs and 3gen lifters ,3SX TD05 kit with EVO III 16G's, PTE 680cc Injectors, SAFC II, Emanage Ultimate, Denzo Fuel Pump, LM-1 Wideband, Intrax Springs, DN Downpipe, Alamosports SMIC's and Hardpipes,Blitz DSBC Boost Controller, K & N Aircharger, 3" split dual exhaust- Straight pipes, Greddy Type-S BOV, Fidanza Flywheel, SS Brakelines,Hotwired fuel pump |
#15 (permalink) |
Never finished
as far as the clocking, im not familiar with it, am i to loosen the metal band between the compressor and turbine housings?? I dont wanna screw this up. Never dealt with taking apart turbos before so lil bit of an expierience 4 me.
99 Chevy Silverado 2500
93 3000GT VR4 So far: 3sx TD05 E16g Turbo Kit, polished Greddy FMIC with IPS tdo5 extensions, Poopra pump, 3sx pulley, MSD wires, NGK coppers, Maximal powdercoated valve covers, polished plenum, Tial Q bov, Hallman Pro RX MBC, Maximal solid mounts, Maximal test pipe, JIC catback, Tein s-techs, Mod-Express 8k HID, Nelson TC bracket, PST CFDS, Fidanza flywheel, RPS Max street, Deft CF hood. Still Need: AEM EMS, injectors. |
#16 (permalink) |
If you look on www.stealth316.com it should have a right up on clocking the turbo. You can clock or rotate the compressor housing, however, then you need to worry about getting the wastegate to sit right, probably have to make something custom. Anyways, yest take the clamp off, then take the compressor housing off, look for metal pin that locks it in place, keeps it from turning, then drill the metal pin out.
(edit): Correct, I didn't take into account the 3SX kit is externally wastegated. I'm still thinking in the realm of the Titan kits where I had to clock my compressor housings.
1998 VR4: SS Downpipe, Borla Cat-Back, Open Element Air Filter, ACPT CFDS, DN Intake Pipes, Front & Rear Strut Tower Bars, Deftracing 575 Hood, Blitz DSBC, Vacum Redution, Krank Vents, Titan Headers w/ Big TD05 16G Turbos,
#17 (permalink) | |
Panda Master
) is that you do not have to mess with lining up the actuators with the comp housing and flapper arm ![]() |
