Go Back   3000GT/Stealth International Message Center > Supporting Vendors > 3SX Performance
Old 12-23-2007, 06:13 AM   #1 (permalink)
3000GT@UAE is an unknown quantity at this point
Default 3SX TD05 Kit install?
I received the 3sx kit and noticed that the pipe that goes from the rear turbo manifold to the wastegate flange is not welded! Are we supposed to weld that on or just connect them together and bolt the wastegate on to the pre cat?
3000GT@UAE is offline   Reply With Quote
Old 12-23-2007, 07:01 AM   #2 (permalink)
Default Re: 3SX TD05 Kit install?
And the wastegates can I just remove the internal wastegate actuator or when I remove it do i have to weld something on the turbo?
Old 12-23-2007, 07:16 AM   #3 (permalink)
Team Negro #001
Jeremy R's Avatar
Drives: 6 String bass' Nuts!
Trader Rating: (15)
Jeremy R is an unknown quantity at this point
I know for a fact that you can removed the stock turbo actuator off of the turbo, not sure what to tell you about the wastegate thing though.
Jeremy R is offline   Reply With Quote
Old 12-23-2007, 07:35 AM   #4 (permalink)
Supporting Vendor
SteveVR4 is an unknown quantity at this point
Those pieces just slip ogether and go to your wastegate. No welding required
On the interrnal wastegates, when the turbo is bolted up the flapper chamber is closed which will prevent them form bypassing. Most people do use a spot weld on the flapper just for added protection.
Hope this helps.
Steve
www.3SX.com
SteveVR4 is offline   Reply With Quote
Old 12-23-2007, 09:01 AM   #5 (permalink)
Thanks Steve it clears alot of things
Old 12-23-2007, 09:05 AM   #6 (permalink)
Never finished
1viciousVR4's Avatar
Drives: Nowhere Fast
Trader Rating: (28)
1viciousVR4 is an unknown quantity at this point
Yeah i just got my kit, i was wondering the same thing. Thanx
99 Chevy Silverado 2500
93 3000GT VR4
So far: 3sx TD05 E16g Turbo Kit, polished Greddy FMIC with IPS tdo5 extensions, Poopra pump, 3sx pulley, MSD wires, NGK coppers, Maximal powdercoated valve covers, polished plenum, Tial Q bov, Hallman Pro RX MBC, Maximal solid mounts, Maximal test pipe, JIC catback, Tein s-techs, Mod-Express 8k HID, Nelson TC bracket, PST CFDS, Fidanza flywheel, RPS Max street, Deft CF hood.
Still Need: AEM EMS, injectors.
1viciousVR4 is offline   Reply With Quote
Old 12-23-2007, 09:24 AM   #7 (permalink)
So I can remove the stock turbo actuator off of the turbo without welding anything on the turbo?
Old 12-23-2007, 11:02 AM   #8 (permalink)
king of ghetto
Highboosted's Avatar
Drives: '94 Stealth Turbo
Trader Rating: (28)
Highboosted is an unknown quantity at this point
Yes. but I personally would tack a weld on the flapper to keep it closed before removing the actuator.
Compressed version:
LEXAN WINDOW GROUP BUY!!!!!!!!!!!!!!!!!!!!!!!!!!!!
"If the wings are traveling faster than the fuselage,
it's probably a helicopter and therefore, unsafe."
"Helicopters dont fly, they beat the air into submission."
"Basic Flying Rules; Try to stay in the middle of the air. Do not go near the edges of it. The edges of the air can be recognized by the appearance of ground, buildings, sea, trees and interstellar space. It is much more difficult to fly there."
"Flashlights are tubular metal containers kept in a
flight bag for the purpose of storing dead batteries."
"If something hasn't broken on your helicopter, it's
about to."
"Progress in airline flying: now a flight attendant
can get a pilot pregnant."
Aircraft Mechanics are Plane Nuts
Highboosted is offline   Reply With Quote
Old 12-23-2007, 10:15 PM   #9 (permalink)
Baby Ferrari
mistercvr4's Avatar
Drives: 91 3KGT VR4
mistercvr4 is an unknown quantity at this point
Yo congrads on the kit, I'm sure you guys will luv it. I surely DO.
91 VR4 aka Baby Ferrari
3SX Custom TDO5 Header w/ EVO3 16g; AEM EMS;
DN Intercooler Piping Kit; DSM SMIC; MSD 8.5 wires; SAFC II; Greddy Profec II; Greddy Turbo Timer; Walbro 255 fuel pump; 3SX HP Short Shifter; Tein "H" springs; Fidanez Flywheel; 3SX Pulley; Spec 3+ Clutch; Fidanez Adj Racing Cams; Turbonetics Raptor BOV; Autometer Boost,Oil, A/F & EGT Gauge; 3SX Stage 3 Ported and Polished Heads w/Ross Piston(.040); WebCam Racing Cams 3S NA Weld; Gen3 Lifters; 3SX Motor Mounts; EGR Blockoff Plates; Pro-M Kit 3S/EVO Draw-Thru w/filter; AEM A/F 52mm Gauge w/ O2 6in1;RC 750 injectors; Krank Vent System; Fuel Rail Adapter Kit w/loop; 3SX TT Control Arm Chamber New Stock Mistu Gen2 Crank w/STD Bearing; PST 1 Piece CFDS.
3SX 1gen Bumper w/99 kaze lip
mistercvr4 is offline   Reply With Quote
Old 12-24-2007, 08:44 AM   #10 (permalink)
Team Negro #001
Jeremy R's Avatar
Trader Rating: (15)
it shouldn't matter if the actuator is on or off if you're welding the flapper.
