Go Back   3000GT/Stealth International Message Center > Supporting Vendors > 3SX Performance
Old 06-30-2008, 11:34 PM   #71 (permalink)
ozdave2's Avatar
Drives: 92 STEALTH TT
ozdave2 is an unknown quantity at this point
Default Re: 3SX TD05 Kit install?
Originally Posted by Import Power View Post
Wastegate pressure-14psi
maTT's car
3SX TD05 kit
660 inj
MafT
SAFC II
DSM SMICS w/stock pipes
PST 1 pc CF driveshaft
stock cams slight pocket port on heads stock valves
Walbro pump
3" exhaust
Looks like MaTT is getting to boost limit around 3500 rpm; I am only around 7 psi; what would that indicate. regards
ozdave2 is offline   Reply With Quote
Old 07-01-2008, 02:26 AM   #72 (permalink)
ozdave2's Avatar
Actually not getting 5 psi T 3500 RPM!
Old 07-01-2008, 04:53 AM   #73 (permalink)
Corn Its whats for boost
Import Power's Avatar
Drives: Vicki Insane
Trader Rating: (210)
Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7
Matt's car is odd, we aren't sure why it boosts faster and has more low end torque than most any other TD05 car we have tested. Could be the pocket ported only heads with stock cams?
AEM Factory Trained Tuner
91VR4-3.0L-Stock heads and Cams-762AWHP 747AWTQ 30psi E100 Daily Driver 10.63@121mph
T4 AWD 9.21 @ 154.98
T2 FWD 10.19 @ 140.31
T2-820FWHP 3.1L 27psi C16
91VR4 Red-17Gs w/supporting mods-sold
93SLTT/T2
91VR4 Pearl White-sold
91VR4 Black-sold
92VR4 Sandstone-sold
94VR4 Green-sold
93VR4 Pearl White-sold
NG09 Title Sponsor
3SX Performance
3SX Performance Service Email
Old 07-01-2008, 05:56 AM   #74 (permalink)
2nd Place NG08 DRAGS
94TTinga's Avatar
Drives: 1994 Stealth TT
Trader Rating: (9)
94TTinga Level 794TTinga Level 794TTinga Level 794TTinga Level 794TTinga Level 794TTinga Level 794TTinga Level 794TTinga Level 794TTinga Level 7
I am hitting 16 psi (what I have it set to) @ 3650-3700. You can feel it start building @ 3-3200 and then it just sets you back in the seat when it all kicks in.
Shane
1994 Stealth TT, 1 of 10, Mods- 3.1l 8.5:1 ross pistons, pauter rods, gtpro head gaskets, apr studs, DR stage 3 heads with street grind cams, high rev springs and 3gen lifters ,3SX TD05 kit with EVO III 16G's, PTE 680cc Injectors, SAFC II, Emanage Ultimate, Denzo Fuel Pump, LM-1 Wideband, Intrax Springs, DN Downpipe, FMIC ,Blitz DSBC Boost Controller, K & N Aircharger, 3" split dual exhaust- Straight pipes, Greddy Type-S BOV, Fidanza Flywheel, SS Brakelines,Hotwired fuel pump
94TTinga is online now   Reply With Quote
Old 07-16-2008, 08:37 PM   #75 (permalink)
ozdave2's Avatar
Looks like I have found my problem. Both intercoolers were leaking so system was not holding pressure. Also found all four cams out by one tooth. Has to be retuned. Will let you know results. Thanks for everyone's help.
Old 07-17-2008, 05:23 AM   #76 (permalink)
That will do it.
Keep us updated!
Old 08-22-2008, 11:35 PM   #77 (permalink)
streamlnauto's Avatar
Drives: 1993 VR-4
streamlnauto is an unknown quantity at this point
Just about ready to fire it up, its been 3 years, I am excited, yet nervous all at the same time-
streamlnauto is offline   Reply With Quote
Old 08-23-2008, 04:38 AM   #78 (permalink)
3 yrs? Wow..Let us know how it goes! She will be a hoot to drive after not having her for 3 years.
-Chris
Old 08-23-2008, 09:24 PM   #79 (permalink)
Keeps 3Ses on the road
xteekayx's Avatar
Drives: anything that rolls
Trader Rating: (15)
xteekayx Level 3xteekayx Level 3xteekayx Level 3xteekayx Level 3
has anyone thought about getting the header flanges cut because they prolly got warped while welding?...
Toy:
-= '95 RT/TT =-
xteekayx is offline   Reply With Quote
Old 08-24-2008, 08:53 AM   #80 (permalink)
We install a number of the kits at the shop. They are normally as flat as any other aftermarket header flange we run across. But with any aftermakrket header there are a few out there that are a little off. I have take a torch to a few while in the press and nudged them back to flat. They were so slight a mill could have cleaned it up to straight.
