Go Back   3000GT/Stealth International Message Center > Supporting Vendors > 3SX Performance
Old 05-08-2008, 05:17 AM   #61 (permalink)
ozdave2's Avatar
Drives: 92 STEALTH TT
ozdave2 is an unknown quantity at this point
Default Re: 3SX TD05 Kit install?
The car was only run to 5458 rpm due to insufficient cooling on the dyno with the claim that it had more to go. What rpm should power output peak?
ozdave2 is offline   Reply With Quote
Old 05-08-2008, 06:08 AM   #62 (permalink)
Play that Funky Music
Import Power's Avatar
Drives: Vicki Insane
Trader Rating: (209)
Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7
maTT did 430AWHP uncorrected at 14psi
3SX TD05 kit
MAF-T/SAFC II
DSM Sidemounts w/stock IC pipes.
Stock cams
AEM Factory Trained Tuner
T4 AWD 9.21 @ 154.98
T2 FWD 10.19 @ 140.31
T4-995AWHP Uncorrected 6G72 3.0L
91VR4 Red-17Gs w/supporting mods-sold
93SLTT/T2
91VR4 Pearl White-sold
91VR4 Black-sold
92VR4 Sandstone-sold
94VR4 Green-sold
93VR4 Pearl White-sold
91VR4 Black-5027s-3.0L-Stock heads and Cams- 614AWHP 557AWTQ uncorrected 24psi Daily Driver
3SX Performance
3SX Performance Service Email
Old 05-08-2008, 06:23 AM   #63 (permalink)
ozdave2's Avatar
At what rpm was max power?
Old 05-08-2008, 07:55 AM   #64 (permalink)
Wastegate pressure-14psi
maTT's car
3SX TD05 kit
660 inj
MafT
SAFC II
DSM SMICS w/stock pipes
PST 1 pc CF driveshaft
stock cams slight pocket port on heads stock valves
Walbro pump
3" exhaust
Old 05-08-2008, 07:58 AM   #65 (permalink)
don't mind the date on the bottom left, that is when I turned the runfile into a JPG
Old 05-08-2008, 01:43 PM   #66 (permalink)
ozdave2's Avatar
Thanks for that.
I only have 550 injectors; would that be the major shortfall.
Regards
Old 05-15-2008, 09:57 PM   #67 (permalink)
3000GT@UAE is an unknown quantity at this point
No it shouldn t be the injectors, becuase you are only at 1 bar. They should be ok till around 24psi with TD05 kit on pump gas + meth (correct me if I'm wrong) and you are only at 14psi. You should check for vacuum leaks cause that sounds pretty low
Originally Posted by ozdave2 View Post
Thanks for that.
Regards
3000GT@UAE is offline   Reply With Quote
Old 05-16-2008, 06:55 AM   #68 (permalink)
ozdave2's Avatar
Running on 98 RON; no meth.
Old 06-02-2008, 02:13 PM   #69 (permalink)
starquest 2875's Avatar
Drives: VR-4
starquest 2875 is an unknown quantity at this point
Originally Posted by streamlnauto View Post
you shouldn't need to pull the motor, you can get the manifolds off with the engine in the car, check them with a straightedge to see if they are straight, its fairly inexpensive to have a machinist mill the flanges.
Your right, I didn't have to pull the motor out to fix the leaks. I was just fustrated.
the leaks that I have or had ( it's in work right know) was the rear wastegate gasket and the turbo to manifold gasket. I got metal gasket on know.
I should be up and running by thursday.
overall this kit is not bad at all. I didn't have any major issues.
starquest 2875 is offline   Reply With Quote
Old 06-12-2008, 11:32 PM   #70 (permalink)
streamlnauto's Avatar
streamlnauto is an unknown quantity at this point
Tell you whats a real PITA, trying to get to the bottom bolt on the rear wastegate with the kit and engine in the car, I fought with that thing for a good 3 hours lol!!!.
streamlnauto is offline   Reply With Quote
