Go Back   3000GT/Stealth International Message Center > 3SI Knowledge Base > 3SI wikipedia Discussions
Old 06-29-2004, 08:13 AM   #11 (permalink)
New User
white 91 is an unknown quantity at this point
Default Re: How to check the wiring on your oil preasure sensor.
Originally Posted by stevep
There should be a inner splash shield (Called a Side Under Cover in the manual and Engine Room Side Cover LH MB640781 in CAPS) running from the body structure to the left suspension member. There is another on on the RH side closing up that wheel well from the engine compartment (it's MB640782).
According to CAPS it is the same part for every 3S.
Steve
Thanks Steve
The only way to access the sensor is from underneath the car or remove the panels. It looks real simple with the panels missing, but with them in place you can't see what is shown in that picture, It looks simple without the panels but I'm sure they serve a purpose. All I can see is the axle coming out of a slot in the panel, cannot see into the engine compartment at all.
white 91 is offline   Reply With Quote
Old 01-11-2005, 10:43 PM   #12 (permalink)
hangsout w/ his wang out
Evil's Avatar
Drives: while gettin head
Evil is an unknown quantity at this point
If you have a busted CV boot the grease can cause the gauge to drop to zero. Pull the connector off wipe clean and should work. Not really high tech or anything, but I figured i'd add some input in a problem I had once...
92 Fiji Blue 3000GT VR4 --GONE-- (13.66 @ 100 Bone Stock 1.89 60') / 06 Suzki sv650s
"Your spoiler moves up and down, but you have to crank your sunroof? "
Evil is offline   Reply With Quote
Old 03-12-2005, 08:23 PM   #13 (permalink)
ILuv92StealthTT's Avatar
Drives: '96 Jeep GC
Trader Rating: (11)
ILuv92StealthTT is an unknown quantity at this point
Thanks for the tip! My oil pressure gauge hasn't worked for a while, so I looked down there and, sure enough, the wire was hanging off. I stuck it back on and it works like a charm. Thanks a lot!
ILuv92StealthTT is offline   Reply With Quote
Old 03-13-2005, 08:01 PM   #14 (permalink)
This, too, shall pass.
JoshAnker's Avatar
Drives: 95 Stealth
Trader Rating: (28)
JoshAnker Level 2JoshAnker Level 2JoshAnker Level 2
Glad my post was of service
JoshAnker is offline   Reply With Quote
Old 03-15-2005, 07:45 AM   #15 (permalink)
doctordrew
Drives: 91 stealth n/a SOHC
doctordrew is an unknown quantity at this point
for the SOHC motors the sensor is right on top of the oil filter....i did mine today...i was looking where the DOHC sensor was (in the pictures) and it wasnt there, but i found it.. thanks for the post!! i would have had NO IDEA
red 91 stealth base ADR Kasai 18"-8, sumiotumo htrz 2 tires, eibach pro kit, kyb gr-2, K&N FIPK, magnaflow muffler, no resonator. interior blue neons.JL Audio 10W3v2-D4, alpine mono channel v-power amp pioneer speakers. beltronics 955.
doctordrew is offline   Reply With Quote
Old 05-08-2005, 02:38 PM   #16 (permalink)
da507hotboy's Avatar
Trader Rating: (10)
da507hotboy is an unknown quantity at this point
any of you guys know if this is different for JDM engines?
da507hotboy is offline   Reply With Quote
Old 05-10-2005, 07:07 AM   #17 (permalink)
Boosted...
jwilly's Avatar
Drives: 93 ES and TT
Trader Rating: (22)
jwilly is an unknown quantity at this point
hey my gauge is working but my light is on. sure the gauge is crap but it is in the "good" range and fluctuates with the revs. i also have oil too. im guessing the sender has a problem since i have put 150 miles on the car with no spun bearings. i cleaned the sender but maybe its bad?
1993 ES - sold
1991 ES - Parted out
1993 TT - toast
1998 Base - Parting out *red*
1993 ES - sisters car
1991 ES - parting out *black*
jwilly is offline   Reply With Quote
Old 07-29-2005, 05:48 PM   #18 (permalink)
brutten's Avatar
Drives: 91-VR4 95-Spyder-VR4
Trader Rating: (23)
brutten is an unknown quantity at this point
Default Re: Oil Gauge Read zero? Read me! (How to check your oil pressure sender)
[quote=JoshAnker]So this is a common problem with our cars... The oil LIGHT in the dash isn't on.
Thanks for the pictures and the Tip!
brutten is offline   Reply With Quote
Old 11-11-2005, 06:28 AM   #19 (permalink)
lordssob's Avatar
lordssob is an unknown quantity at this point
My gauge has come unplugged, however I can't find where to plug it in, are there 2 prongs? one on each side. There is a piece of metal where the light is plugged in but there is no place for the gauge, did it break off? if I am just stupid can someone post pics on where it goes? Thanks.
Travis
lordssob is offline   Reply With Quote
Old 01-07-2006, 12:57 PM   #20 (permalink)
3kgtvr4guy's Avatar
Drives: 92 VR4
3kgtvr4guy is an unknown quantity at this point
I know this is an old Thread, but could someone help me with this. My stock gauge was reading very high. Then a couple of days, it started dropping very slow to the very bottom. I would repeat this when I got in the car to go somewhere. I looked down there, and of course I have a busted boot. So, I pulled the plug off wiped it clean and stuck it back on.
Will any aftermarket gauge do?
Do I need to replace factor sensor as well?
What kind of aftermarket sensor will fit?
Thanks
3kgtvr4guy is offline   Reply With Quote
« Idle Problems | - »
