Go Back   3000GT/Stealth International Message Center > 3SI Knowledge Base > 3SI wikipedia Discussions
LinkBack (1) Thread Tools
Old 09-24-2002, 03:07 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
WikiBot is an unknown quantity at this point
Default How to check your oil pressure sender
This is an automatically generated introductory discussion post for the article How_to_check_your_oil_pressure_sender
WikiBot is offline   Reply With Quote
Old 09-24-2002, 03:07 PM   #2 (permalink)
This, too, shall pass.
JoshAnker's Avatar
Drives: 95 Stealth
Trader Rating: (31)
JoshAnker Level 2JoshAnker Level 2JoshAnker Level 2JoshAnker Level 2JoshAnker Level 2
Default How to check the wiring on your oil pressure sensor.
So this is a common problem with our cars... The oil LIGHT in the dash isn't on, but the Gauge in the middle shows ZERO oil pressure!
Well it happened to me, and I found lots of help when I searched, but I'm a TOTAL newbie when it comes to 3/S's, so I wasn't happy with the pictures I found.
So I took my own, and now I'm posting 'em to help you.
I was told it's an easy fix with your car on a jack or lift, or that I could take the tire off. I didn't have to do EITHER! I just layed down next to the drivers side front tire, and I could SEE and REACH the loose wire. Here's pics.
When I looked, here's the first thing I saw...
Note the wire hanging loose.
If you're disoriented, or have no clue what ANYTHING is, here's the picture again, with the front drivers-side TIRE in the picture, so you can get your bearings. (It's on the right side, you might have to scroll your browser.)
Okay, take that little wire hanging loose, and slide the connecter onto the brass colored little round thing. (It's the oil sender unit). Make it look like THIS:
The tire is in there again, so you can get your bearings.
Here's the final picture, with instructions and all the right parts pointed out with an arrow.
Okay, I hope this helps some newbie someday, and like someone told me... don't you DARE pay to have this one fixed! Do it yourself!
I took these pics myself, and they're of my car, so they're not copyrighted or anything... Feel free to use them if you have a 3/S site with a fix for this problem.
Good luck, everyone, and enjoy your car without worrying about that oil gauge!
JoshAnker is offline   Reply With Quote
Old 05-26-2004, 05:34 PM   #3 (permalink)
Indy here we come 06/2010
Alan92RTTT's Avatar
Drives: 1992 RT/TT
Alan92RTTT Level 2Alan92RTTT Level 2Alan92RTTT Level 2Alan92RTTT Level 2Alan92RTTT Level 2Alan92RTTT Level 2
Default Re: How to check the wiring on your oil preasure sensor.
If you have the reverse problem. No oil light at startup but your guage works. The sensor for the light is the same area and is probably suffering from a similar issue.
Click here for all your NG10 information needs
Alan(3SI#601)alan92rttt@mi3si.org Michigan 3SI.
1992 Dodge Stealth RT/TT
My Snake Eyes, 13g Turbos, 450cc DSM injectors, Walbro 255 Fuel Pump, Autometer Boost Guage, Greddy peak/hold EGT, Apexi S-AFC, K&N FIPK, Clean Cats, 3rd Gen Lifters, JVC SX990 CD/MP3 Receiver, JVC CH-X200 12 Disc Changer.
1998 3000GT SL
Alan92RTTT is offline   Reply With Quote
Old 05-27-2004, 12:27 AM   #4 (permalink)
Aurora3000GT's Avatar
Drives: 1992GT olds. aurora
Aurora3000GT is an unknown quantity at this point
very cool, thanks, i was trying to work on the car and it just stopped working, couldn't figure out why as i had oil...thanks
Aurora3000GT is offline   Reply With Quote
Old 06-01-2004, 01:46 PM   #5 (permalink)
Like a Rat out of Water
Wombat's Avatar
Drives: '91 VR-4
Trader Rating: (58)
Wombat is an unknown quantity at this point
Just wanted to add a little something...
If this wire continually falls off and you find yourself doing this same procedure over and over again, like I had to...take a pair of pliers and gently squeeze the connector. After I did this, my the connector actually "snapped" on the oil pressure sender and it has yet to fall off
2008 Kawasaki Z1000 - Because two wheels are more fun!
2001 Jeep Cherokee Sport - Daily beater
1999 Jeep Cherokee Classic - Yea, another one
1998 Jeep Cherokee Sport - Why do I have so many of these?
1991 3000GT VR-4 - 13T, 550cc, E-manage, Walbro 255, AEM FPR
Wombat is offline   Reply With Quote
Old 06-02-2004, 01:05 AM   #6 (permalink)
Billygoat
Drives: 91 ES, 92 TT, 94 RT
Trader Rating: (10)
stevep is an unknown quantity at this point
Looks like it's time to replace that sway bar link or at least put a new boot on and tighten the nut
stevep is offline   Reply With Quote
Old 06-25-2004, 09:38 PM   #7 (permalink)
is dominating the race!
Deathsled's Avatar
Drives: some sort of TT
Trader Rating: (21)
Deathsled Level 2Deathsled Level 2Deathsled Level 2Deathsled Level 2Deathsled Level 2
There are 2 sensors? One for the gauge and one for the oil light in the dash? I always figured they shared the same sensor. Maybe I should check the connection on my oil light sensor.
'10 SOUTHEAST DRAG DAY // MAR 7, 2010 // SOUTHEASTDRAGDAY.COM
1991 Stealth RT/TT : 1992 base Stealth : 1996 3000GT VR4
Deathsled is offline   Reply With Quote
Old 06-28-2004, 10:51 PM   #8 (permalink)
white 91 is an unknown quantity at this point
Do you have missing panels or did you remove them to take the pictures ?
I can't see any of that on my 91, there are splash panels covering everything,
I can see the axle coming out of a panel but that's it, I know I can remove them, just curious if mine is the norm or what?
Thanks
Jack
white 91 is offline   Reply With Quote
Old 06-28-2004, 11:02 PM   #9 (permalink)
JoshAnker's Avatar
Drives: 95 Stealth
Trader Rating: (31)
Hrm... when I lay down on the ground and put my head under the wheel, I was able to see exactly what I took the picture of. Although the car I took those pictures on was used and with high mileage.... But I don't know of any panels that should be blocking that. Maybe someone else can give a more educated opinion:
TTT.
Old 06-29-2004, 02:14 AM   #10 (permalink)
Billygoat
Trader Rating: (10)
Originally Posted by white 91
Do you have missing panels or did you remove them to take the pictures?
There should be a inner splash shield (Called a Side Under Cover in the manual and Engine Room Side Cover LH MB640781 in CAPS) running from the body structure to the left suspension member. There is another on on the RH side closing up that wheel well from the engine compartment (it's MB640782).
According to CAPS it is the same part for every 3S.
Steve
LinkBacks (?)
LinkBack to this Thread: http://www.3si.org/forum/f121/how-check-your-oil-pressure-sender-323961/
Posted By For Type Date
I have a 95 Mitsubishi 3000GT and the oil light is on. I bought a new sensor but can This thread Refback 04-16-2008 03:55 AM
