#21 (permalink) | |
NG09: The Comeback Tour
Thread copied to wiki's how to section http://www.3si.org/wiki/index.php/Ho...ressure_sender
NG07 T-Shirts For Sale
NG08 Stuff from Cafepress ![]()
#22 (permalink) |
This, too, shall pass.
thanks Alan. If you happen to read this, and this thread will stay, can you change the title of the thread to "pressure" instead of "preasure" please.
Interested in the famous "Bandit" movies featuring a Stealth RT/TT? I have all 4 on DVD! PM me for info! Google logo thread | 3Si Area of Expertise thread | 3S Audio FAQ 3si faces page | 99 Front-End conversion page | 3S Quicklist walkthrough for removing your spoiler | walkthrough for changing your ATX fluid |
#24 (permalink) |
If you install a aftermarket oil pressure gauge (electric type / not mech) you will need to install a new sender unit. The gauge and sender are married, and the stock sender will not work with your aftermarket gauge. If you gauge did not come with a sender then you need to find the correct one that goes with your gauge.
Most senders are 1/8 inch NPT thread. Our cars need Metric Thread. you can buy the adaptor online (3sx charges 17 bucks!) i found mine for 5 bucks at a local shop called 'Central Hydrolics' none of my local autopart stores had them but lucky for me a local auto parts store employee knew what store did have it. You will most likely also need a 'elbow' as most sender units are 'bigger then a freaking sweet potato' You do not need to drain your oil to remove and install a new sender, or to just remove yours for cleaning. Oil will come out, about 1/4 of a cup (kitchen measurement) so keep a paper cup handy to catch the mess. Here is a pic of my dirty one. i pulled it off and cleaned it and it works alot better now. If anyone would like to add this info the wiki feel free....im wikiliterate ![]()
Vi Veri Veniversum Vivus Vici.
#26 (permalink) |
Chatters
Maybe you'll be lucky like me and find out that you only have one sensor down there. I had to uncap the other sensor hole, that I think someone had loctited in place, and get an adapter to put in the gauge sensor. But, It got fixed, just took a little more effort than I thought it would.
#27 (permalink) |
Black Beast Rebuild 93%
I noticed that wire hanging when I had everything apart over winter. I test drove it for the first time today and had 0 oil pressure on the gauge. It was running good and didn't have any dummy lights on.
I'm glad this was an easy fix! Thanks |
