Go Back   3000GT/Stealth International Message Center > Modifications and Technical Support > Miscellaneous > Interior
Old 05-04-2008, 08:40 PM   #1 (permalink)
jdshookup's Avatar
Drives: 92 Dodge Stealth R/T
jdshookup is an unknown quantity at this point
Default Window Regulator help...
Tomorrow I am going to go through the process of swapping out my bad drivers side window regulator with a used one that is in working condition. I was just wondering if anyone had any tips on how to go about doing this type of thing. It'll be a new job for me!
jdshookup is offline   Reply With Quote
Old 05-04-2008, 10:54 PM   #2 (permalink)
Drives: 1990 GTO
aussie_will is an unknown quantity at this point
Default Re: Window Regulator help...
You can follow the first few parts of the doco here:
Mitsubishi 3000GT VR4 Garage Page
aussie_will is offline   Reply With Quote
Old 05-05-2008, 04:31 AM   #3 (permalink)
jdshookup's Avatar
Oh, thank you! I had saw this page awhile back, but I couldn't find it for the life of me!
Old 05-05-2008, 12:37 PM   #4 (permalink)
jdshookup's Avatar
Okay... quick question. I got it installed and it works and everything... however I have an auto down switch, and it doesn't go down all the way if I tap it once, like it should. Also, there is a spot where the window kinda gets off track and then jumps back on track... any ideas?
Old 05-05-2008, 02:30 PM   #5 (permalink)
RTBOOST
Street_Chally73's Avatar
Drives: '91 Stealth R/T TT
Trader Rating: (6)
Street_Chally73 is an unknown quantity at this point
Chances are your switch is worn out at the contact points. You may be able to get it to work properly by pulling it apart and cleaning it with electronic parts cleaner, but chances are you'll need to find a working switch. As for the looseness in the window, you should be able to tighten up one of the 'feeler' guides (they press against either the front or rear of the window) to tighten it more on the tracks.
'73 Dodge Challenger 340.............................(X)
'91 Firestorm Red Stealth R/T TT...................(X)
Street_Chally73 is online now   Reply With Quote
Old 05-05-2008, 02:38 PM   #6 (permalink)
est. sept, 2000
91vr4n00maxima's Avatar
Drives: slow 97 VR4
91vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 7
youre clicking the switch past the one touch detents right?
97 VR4 12.417@111.16 9b time. whats next?
95 mark viii. 14.35@98
03 cobra vert. 4 mods=118mph traps
91 stealth TT. td05 18G, heads/cams, 3000lbs
91vr4n00maxima is offline   Reply With Quote
